iphone can not connect to SSID using PEAP with Microsoft AD
Ali mosbah Abdo
hello
i confiure new SSID authentecetd using Microsoft Active Directory , i used in my profile PEAP , its works fine with SAMSOUNG phones , but not with Apple Devices.
please any suggesting.
i dont not use any certificate until now , is it necessary ?
Ali
Are you using a controller based wireless network or autonomous access point and what code versions are being used?
John
**Please rate posts you find helpful**
5 Replies 5
johnd2310
Level 8
Level 8
What error do you get with the Apple Devices?
John
hello
the error " unable to joint network"
John
i used controller based wireless , code 7.6
Make sure Fast SSID change is enabled on the wireless controller. Check that the Apple device is running the latest software. Upgrade the sotware on the wireless controller since  7.6 is deferred code.
John
