CAP3502I-A-K9 error: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP
dtolson01
My boss has tasked me with setting this thing up in our Win2012 Server environment and I'm having a hell of a time getting it going. I would appreciate any help. Thanks.
here is my terminal dump:
r WRDTR,CLKTR: 0x8200083f 0x40000000
r RQDC ,RFDC : 0x80000033 0x00000215
using  eeprom values
using MCNG ddr static values from serial eeprom
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x8200083f, 0x40000000
RQDC, RFDC : 0x80000033, 0x00000215
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
64bit PCIE devices
PCIEx: initialization done
flashfs[0]: 4 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31739904
flashfs[0]: Bytes used: 2311680
flashfs[0]: Bytes available: 29428224
flashfs[0]: flashfs fsck took 9 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 60:73:5c:47:a6:ee
Ethernet speed is 100 Mb - FULL duplex
Loading "flash:/ap3g1-rcvk9w8-mx/ap3g1-rcvk9w8-mx"...###########################                                      ################################################################################                                      ################################################################################                                      #####################################
File "flash:/ap3g1-rcvk9w8-mx/ap3g1-rcvk9w8-mx" uncompressed and installed, entry point: 0x4000
executing...
enet halted
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C3500 Software (AP3G1-RCVK9W8-M), Version 12.4(23c)JA5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 30-Apr-12 13:33 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 4 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 31481856
flashfs[1]: Bytes used: 2311680
flashfs[1]: Bytes available: 29170176
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 1 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3502I-A-K9    (PowerPC460exr) processor (revision A0) with 81910K/49152K bytes of memor                  y.
Processor board ID FGL1635S2QG
PowerPC460exr CPU at 666Mhz, revision number 0x18A8
Last reset from power-on
LWAPP image version 7.0.112.74
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 60:73:5C:47:A6:EE
Part Number                          : 73-14857-01
PCA Assembly Number                  : 800-38797-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC16326UFL
Top Assembly Part Number             : 800-32891-02
Top Assembly Serial Number           : FGL1635S2QG
Top Revision Number                  : B0
Product/Model Number                 : AIR-CAP3502I-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:09.333: *** CRASH_LOG = YES
Base Ethernet MAC address: 60:73:5C:47:A6:EE
*Mar  1 00:00:09.613: %LWAPP-3-CLIENTEVENTLOG: Unable to open event log file flash:/event.log
*Mar  1 00:00:09.613: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 0 messag                  es)
*Mar  1 00:00:11.639: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:11.648: %SYS-5-RESTART: System restarted --
*Dec 13 07:34:52.015: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Dec 13 07:34:52.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed stat                  e to up
*Dec 13 07:35:00.141: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 192.1                  68.1.153, mask 255.255.0.0, hostname AP6073.5c47.a6ee
AP6073.5c47.a6ee>
*Dec 13 07:35:12.956: %CDP_PD-2-POWER_LOW: All radios disabled - INJECTOR_DETECTED_PD AIR-AP1142N-A-                  K9     (0000.0000.0000)
Translating "CISCO-CAPWAP-CONTROLLER.eastbay.local"...domain server (192.168.1.201)
*Dec 13 07:36:12.983: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
mohanak
If for some reason Option 43 is NOT working for you, I had luck by issuing the following cmd on the APs (means you need console + username/password to log in to the APs!):
capwap ap ip default-gateway DEFAULT-GTWY
capwap ap ip address IP-ADDRESS SUBNET-MASK (for the AP)
This allowed the AP to bring up its IP interface and then find a controller.
You can also try adding a 3rd line:
capwap ap controller ip address IP-ADDRESS SUBNET-MASK (of the controller)
I have occasionally found that rebooting the AP after setting those above 3 cmds helps...the AP will do some some CAPWAP discovery and then revert to the settings you just put.
