CAPWAP and LAG
DAVIES604
Level 3
Level 3
Can someone answer whats probably a simple question please, I can't quite find an answer that I'm happy with and I've not really got much WiFi experience.
If I have an AP with a single physical connection to a switch, and the path from the switch to the WLC involves aggregated ports along the way, and the WLC is configured for LAG to it's neighbour switch, will a separate tunnel be created between the AP and WLC for each client/connection to utilise the full potential bandwidth, or will connections initiated from the AP always use the same tunnel connection?
Thanks.
5 Replies 5
Scott Fella
I think you need to just look at how LAG works alongside etherchannel mode on. Basically its source destination ip that will determine what port on the switch and WLC the traffic will be placed on. This has nothing to do with CAPWAP as the AP and WLC will create a tunnel again based on the etherchannel mode on. Same thing for client traffic src-dst-ip.
-Scott
Hi Scott, thanks for the reply. I read a Cisco doc that stated all traffic including client traffic is sent down the capwap tunnel, my question really was, which I think you’ve answered, is does a new tunnel get created each time and so can make use of the load-balancing across etherchannels along the path, in other words does a single AP create multiple tunnels for all connected clients? Thanks
No... the Capwap is a single connection from ap to controller. This is transparent to any user traffic.
-Scott
Also read into Flexconnect if you expect client traffic to become an issue (it rarely is).
specifically flexconnect LOCAL SWITCHING 🙂
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
