CAPWAP state: DTLS Teardown
I have a problem with AP 1815i as it continuously disjoin the controller 9800 and restart and then loop in same action as shown in attached logs.
These are the port configuration
Access switch
interface gi1/0/21
description To-WLC
switchport mode trunk
switchport trunk allowed vlan 5,6,50
switchport trunk native vlan 50
interface gi1/0/15
description To-AP
Core Switch
ip dhcp pool DATA-pool
network 192.168.6.0 255.255.255.0
default-router 192.168.6.254
dns-server 192.168.100.1 192.168.100.2 8.8.8.8
ip dhcp pool WLC-Mgm-pool
network 192.168.50.0 255.255.255.0
default-router 192.168.50.254
option 43 hex f205.c0a8.3264.01
33 Replies 33
Drop Cause Packets Octets
Wls Capwap unsupported link type Error 0 0
Wls Capwap invalid tunnel Error 0 0
Wls Capwap input config missing Error 0 0
Wls Capwap invalid TPID Error 0 0
Wls Capwap ingress parsing Error 0 0
Wls Capwap invalid FC subtype Error 0 0
Wls Capwap SNAP Invalid HLEN Error 0 0
Wls Capwap Invalid SNAP Error 0 0
Wls Capwap ipv4 tunnel not found Error 106409 43615807
Wls Capwap ipv6 tunnel not found Error 0 0
Wls Capwap tunnel header add Error 0 0
Wls Capwap mobility tunnel header add Error 0 0
Wls Capwap MOU tunnel header add Error 0 0
Wls Capwap mobility MOU tunnel header add Error 0 0
Wls Capwap tunnel ipv4 header add Error 0 0
Wls Capwap tunnel ipv6 header add Error 0 0
Wls Capwap multicast tunnel header add Error 0 0
Wls Capwap multicast tunnel ipv4 header add Error 0 0
Wls Capwap multicast tunnel ipv6 header add Error 0 0
Wls Capwap v4 encap type disabled Error 28 13220
Wls Capwap v6 encap type disabled Error 0 0
Wls Capwap v4 input UIDB invalid 0 0
Wls Capwap v6 input UIDB invalid 0 0
Wls Capwap ingress dot3 ingress processing Error 0 0
Wls Capwap tunnel ingress unsufficient packet data 0 0
Wls Capwap tunnel ingress invalid capwap version Error 0 0
Wls Capwap tunnel ingress capwap hlen Error 0 0
Wls Capwap ingress fragment capwap payload length Error 0 0
marce1000
         -  Could you also check if the regulatory domain of the AP and controller (configured)   match ?
 M.
I'm seeing a very similar issue with the same controller 9800 but with AP CW9166i. I'm currently running version 17.9.4a.
In the radioactive trace of the AP I see error message related to site-tag. I'm also seeing the same error as above "Wls Capwap ipv4 tunnel not found Error", the counter is incrementing right now while one AP is actively having the problem.
(ERR): Failed to get the site-tag-name
(ERR): Failed, to get ap join profile from site tag in discovery
Any news on this ?
It's a new AP model and a different version of software so you're probably better off opening a new thread with all the relevant details rather than reviving this old one.
That said, there do still seem to be quite a number of bugs affecting APs in 17.9.  You're probably better off downgrading back to 17.9.4 so that you can install the SMUs and APSPs which fix a number of issues which are not fixed in 17.9.4a.
And then if you still see the problem - open a TAC case.  Things to try which will probably clear the problem but not stop it from recurring at some point in the future:
1. Change the AP to a different site tag and profile (they can have the same settings, just different names).  That should load-balance it onto a different WNCd process and then when it's stable change it back to the original site tag and profile.  You should do a capwap restart "ap name <apname> reset capwap" to make sure the tag and profile changes take effect each time.
2. reboot the AP
If you decide to open a TAC case best to keep it in the broken state so they can get all the debugs, traces and packet captures they need.
