Catalyst (DNA) for Break/Fix Techs
74501
Community Member
Hello All,
I am a new NOC tech, and my enterprise APs run on Catalyst. Does anyone have any learning resources for maximizing Catalyst functions for troubleshooting wireless outages? Most of the learning material I've been able to find is focused on design, which is not what I am looking for.
2 Accepted Solutions
balaji.bandi
Check the below videos start with :
https://www.youtube.com/watch?v=QfDsdhYxkJM
https://www.youtube.com/@CiscoCatalystCenter
you can more troubleshooting using Assurance, depends how your network configured, if the Netflow and Telemetry enabled on the Wireless most of the problems can be identified with Wireless, again what kind of deployment is this, Wireless with Sd-Access ?
there is good live presentation help you :
https://www.ciscolive.com/c/dam/r/ciscolive/global-event/docs/2024/pdf/BRKEWN-2306.pdf
BB
If you are not running SDA already, you'll need to make sure that you are running on Advantage Licensing to play with Assurance as far as I know, that said... Assurance is the term you should search for in your studies!
balaji.bandi
BB
Perfect. Thank yoU!
Thanks for the response, Julian.
