CBW150ax and CBW151axm
brvadebo
I bought recently CBW150ax and CBW151axm to improve my wifi network at home. In the AP the client user names are indicated as 'unkown'. I wonder if I can edit somewhere the username to something meaningfull for me.
Many thanks in advance,
Johan
marce1000
  - I guess this would depend  on ,  if there are any authentication schemes used on the access points ,
 M.
Thank you for your reply. I can imagin that this is indeed the way to go. Only, I have been looking how to setup authentication schemes on my AP. Since I'm not that familiar with this stuff, I couldn't find out how/where to put this authentication scheme file. I read already a lot of Cisco documents but always I ran into another issue (i.e. setting up a CLI interface with my AP).
Is there a simple answer for this? Otherwise I leave it as it is.
Johan
I don't see any option to set the usernames.
Your simplest option for authentication is guest network - but you might find it irritating having to login to your WiFi though:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/csbap/CBW_WiFi_6/Admin_Guide/b_cisco_business_wifi_6_admin_guide/m_4_wireless_settings.html#Cisco_Concept.dita_dbf04af5-9a75-4754-9e6b-f6bbaefd734c
Other authentication mechanisms will generally require a radius server and/or external web auth service.
