CCX Issues with Cisco AIR-AP3802I-B-K9 Access Points
emnyman1027
Anyone have any issues with CCX based RTLS environments when using AP3802I series access points? Other models such as the 1142's and 3500s work fine. Code is on the older side 8.2 but I've also tried 8.5 without any success. I've also tried both 5508 and 5520 WLC controllers. It seems isolated to the access point hardware but I can't figure out what. Anyone have any suggestions?
Leo Laohoo
Provide more useful information other than this because we do not know what "issues" are encountered.
It does not seem like CCX works or there is additional configuration needed for this series.. We have several CCX based RTLS tags that work just fine except in areas where there are 3800 series access points. There is just no signs of any CCX traffic.
One thing I did notice is the error message with CCX on the b radio. It just so happens the RTLS tags all us the b radios.
Command Outputs
(Cisco Controller) >show advanced 802.11a ccX global
  802.11a Client Beacon Measurements:
    enabled with (interval=60) seconds
(Cisco Controller) >show advanced 802.11b ccX global
  802.11b Client Beacon Measurements:
(Cisco Controller) >show advanced 802.11a ccX ap BUILD-N-17-0478
Cisco CCX not customized for this AP radio
(Cisco Controller) >show advanced 802.11b ccX ap BUILD-N-17-0478
Cisco CCX not customized for this AP radio                                                        *this is the 1142
(Cisco Controller) >show advanced 802.11a ccX ap BUILD-N-17-0DBC
(Cisco Controller) >show advanced 802.11b ccX ap BUILD-N-17-0DBC
Error finding a slot in Cisco AP of the given radio type.                                 *this is the 3802
(Cisco Controller) >show ap ccx rm BUILD-N-17-0478 status
B Radio
  Beacon Request................................. Disabled
  Channel Load Request........................... Disabled
  Frame Request.................................. Disabled
  Noise Histogram Request........................ Disabled
  Path Loss Request.............................. Disabled
  Interval....................................... 60
  Iteration...................................... 0
A Radio
(Cisco Controller) >show ap ccx rm BUILD-N-17-0DBC status
A Radio
B Radio is missing
