12-04-2020 12:34 AM - edited 07-05-2021 12:51 PM
Hello community,
I've short question, because i can't find a solution for my problem:
I want to manage to wlan controllers Cisco 3504 on location 1 and Cisco Catalyst 9800-CL on location 2. Is there a posibility / a tool to managed them centralized (create new SSIDs, change Passwords etc.)? I also found Cisco DNA, but is this the only way to do such a thing?
PS: We're planing to replace the C3504 with a C9800-CL.
Thanks in advanced
Markus
12-04-2020 01:06 AM
Prime Infra can able to help you. but new world is DNAC.
12-04-2020 01:32 AM
If budget is an issue and with only 2 controllers, it is better to use CLI because it is a lot faster.
