Change initial tags for APs connecting to 9800 WLCs
Martin Zipperer
is there any way to change the tags an AP comes up with on the 9800 WLC?
Instead of using "default-policy-tag" it should be auto assigned some other tag available on the WLC.
Cheers
Martin
JPavonM
As all new APs are registered in the controllers with their MAC address ad the suffix AP before that, you can create a Regex filter to auto-assign tag profiles like this:
ap filter name DEFAULT-TAGS1
  ap name-regex ^AP.*
   tag policy CORP
   tag rf EMEA-OFFICE-SD
   tag site OFFICE-SITE
Then check your are allowing AP Filters to assign tags as second source:
wlc# sh ap tag sources
Priority Tag source
0 Static
1 Location
2 Filter
3 AP
4 Default
-Jesus
*** Please Rate Helpful Responses ***
5 Replies 5
Rasika Nayanajith
You have to register those AP to 9800 & then you can change those tag values
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213911-understand-catalyst-9800-wireless-contro.html
Rasika
*** Pls rate all useful responses ***
Rafael E
The only thing I can think of is using EEM script.
I haven't done it so not sure it will work.  So maybe based on AP name you can assign specific AP tags.
Saludos,
Rafael - TAC
JPavonM
  ap name-regex ^AP.*
   tag policy CORP
Priority Tag source
0 Static
1 Location
2 Filter
3 AP
4 Default
-Jesus
This looks promising :) thank you all for the answers!
Hi all,
Also two things should be done:
1) After created a tag should be activated with the configuration mode command:
device(config)#ap filter priority 2 filter-name TAG-FILTER-NAME
2) Revalidate the AP tag sources. The AP tag priority become active only after this priviledge exec mode command is configured.
device# ap tag-sources revalidate
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/newconfigmodel/b_catalyst-9800-configuration-model/m_configuring-tags.html
Hope to help.
