Change power level at AP3802
Leftz
Level 4
Level 4
Hi WLC 5520 with AP3802I has the below screenshot. We want to change Power level, but it cannot be changed as it is grayed out. Anyone has some suggestions? Thank you
3 Accepted Solutions
Leo Laohoo
Maybe because the Regulatory Domain does not match?
Leftz
Level 4
Level 4
Thank you Leo! I checked Regulatory Domain. Its -B. It should be right
Post the complete output to the following commands:
  • WLC:  sh sysinfo
  • AP:  sh version
6 Replies 6
Leo Laohoo
Leftz
Level 4
Level 4
  • WLC:  sh sysinfo
  • AP:  sh version
Leftz
Level 4
Level 4
removed
Arshad Safrulla
Hi, Are you trying these changes under Wirelsss>>Dual Band Radios
you may be trying to work in the XOR antenna, if you have this in 5Ghz it always works in the lowest power level possible. I doubt you will not be able to change it.
Leftz
Level 4
Level 4
Hi Arshadsaf, Thank you for your reply. I got it. Let me share it. Go to Radio Role Assignment -----> check Manual first
