Changing WCS Port
nshoe18
Is there a way to change a port number for WCS that is already installed and running from say port 80 to port 82?
5 Replies 5
ericgarnel
Level 7
Level 7
Are you running windows or Linux?
the apache conf files are buried under the WCS-X.x.x/ directory. For the ssl port under Linux, edit ssl.conf under /opt/WCS4.2.110.0/webnms/apache/ssl (or whatever your version is)
for port 80, edit httpd.conf under
/opt/WCS4.2.110.0/webnms/apache/conf
The files should be the same in either OS, but the locations are different
It is windows. I will give it shot. Thank you.
Easiest way is to take a backup. Then uninstall WCS, reinstall it and set the correct port during installation. Then perform a restore.
That seems like a lot of work compared to editing a conf file and restarting the service
That is the only supported way of changing HTTP port in versions 5.1 and below. Starting with v5.2, this setting is available under Administration --> Settings.
