Cisco 1231 AP software upgrade Problem
Nelixuk2003
Community Member
Hi all
I have a Cisco 1231 Access point and I am trying to upgrade the software, however I cant seem to get it to work. I have tried a couple of newer versions of software from the download pages of the Cisco site, I have tried using the HTTP upgrade method as well as the TFTP method and niether of them work.
When I try using the HTTP method it says it is upgrading, but stops after about 10 Secs with a message saying that the upgrade process was interupted, If I use the TFTP option it just seems to sit there with the timer on the screen, I have even left it running over night, I have also tried disabling the Radio before upgrading.
The current software information is as follows:
Product/Model Number: AIR-AP1231G-E-K9
Top Assembly Serial Number: XXXXXXXXXXX
System Software Filename: c1200-k9w7-tar.122-13.JA3
System Software Version: 12.2(13)JA3
Bootloader Version: 12.2(8)JA
System Uptime: 20 hours, 46 minutes
Rob Huffman
Hi Derek,
There seems to be a number of Radio issues related to IOS upgrade to 12.3(8)JA but I don't know if they have been fixed in 12.3.(8)JEA? I t almost looks like your best bet would be 12.3(7)JA2. Have a look;
Changes to the Default Configuration Radios Disabled and No Default SSID
In this release, the radio or radios are disabled by default, and there is no default SSID. You must create an SSID and enable the radio or radios before the access point will allow wireless associations from other devices. These changes to the default configuration improve the security of newly installed access points.
Enabling MBSSIDs Without VLANs Disables Radio Interface
If you use the mbssid configuration interface command to enable multiple BSSIDs on a specific radio interface but VLANs are not configured on the access point, the access point disables the radio interface. To re-enable the radio, you must shut down the radio, disable multiple BSSIDs, and re-enable the radio. This example shows the commands you use to re-enable the radio:
AP1134(config)# interface d1
AP1134(config-if)# shut
AP1134(config-if)# no mbssid
AP1134(config-if)# no shut
http://www.cisco.com/en/US/docs/wireless/access_point/1130/release/notes/b38jearn.html#wp227969
CSCsc79121 Bug Details
First Found-in Version 12.3(8)JA
Symptom:
After upgrading IOS on an access point, a radio interface mail fail to come up.
"show interface" may show the interface to be down/down, with a MAC
address of all zeros:
Dot11Radio0 is down, line protocol is down
Hardware is 802.11B Radio, address is 0000.0000.0000 (bia 0000.0000.0000)
Conditions:
This is seen after upgrading to IOS 12.3(8)JA.
Workaround:
Downgrade to IOS 12.3(7)JA2.
CSCsd84198 Bug Details
Symptom:
802.11B Radio will stay in down/down after upgrade to 12.3(8)JA
Conditions:
Cisco AP1210
Further Problem Description:
"show controller" will have zeroes in MAC address, bia address and software
version fields.
To confirm this issue, downgrade to the previous version, shut down radio
interfaces, repeat upgrade and then re-activate radio interfaces. Radios should
be up them. This is not a workaround since it is not oprerationaly scalable in
mid to large environments.
Hope this helps!
Rob
Please remember to rate helpful posts.....
14 Replies 14
Rob Huffman
Hi Derek,
I'm not sure what release you are trying, but I am guessing something like 12.3.(8)Have a look at the following;
Software upgrades fail when you use the web-browser interface to install Cisco IOS Release 12.3(8)JA2 on 1200 series access points. The image size exceeds the access point's 4-MB restriction for software upgrades. Use TFTP to upgrade your access point to this release. For complete instructions on using TFTP to upgrade access point software, see the "Working with Software Images" section in the Cisco IOS Software Configuration Guide for Cisco Aironet Access Points. Click this link to browse to that document:
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1100/accsspts/i1232ja/i1232sc/index.htm
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_release_note09186a00806a61e6.html#wp17722
As far as the TFTP goes, make sure that a personal firewall isn't preventing the file transfer.
Hope this helps!
Rob
Thanks for the info Rob
I have seen this before and followed the instructions to the letter. still no joy i'm afraid.
I have checked and the XP firewall is disabled. When I enter the address of the TFTP server and the path/filename details and click upgrade the 3 lights on the front of the unit do the following:
The top light illuminates green and flashes off every 2 secs
the second light stays static red for 45 Secs
The third light does nothing.
After 45 Secs the top light goes static green and the second light goes rapid flashing (Green), at the same time I get an error on the screen saying
ERROR:
Upgrade error:File not found, server not found or invalid file format.
I have been trying to upgrade to 12.3(2)JA2 I have also tried 12.3(7)JA1
Hi Rob
Thanks for the links, I have read them and I think I have identified the problem, I will give it another try tonight when I get home and let you know how I get on.
Thanks Again
Derek
I managed to get the software upgraded to the most recent release, 12.3(8)JEA eventually after a few try's
I now have a different problem in thqt I do not seem to be able to enable the radio, anyone got any ideas
Thanks for all your help so far
Derek
Well, I managed to get it all sorted and my AP is up and running again with the latest software installed.
Thanks to rob for all your help.
Derek
Rob Huffman
Hi Derek,
Symptom:
Conditions:
Workaround:
Symptom:
Conditions:
Cisco AP1210
version fields.
Hope this helps!
Rob
smicale
Community Member
I am having this same issue and I would love some help on getting my 1200 AP upgraded. I have tried up grading to c1200-k9w7-tar.123-8.JEA.tar. I am having no luck with it. I am new to using TFTP so this could be where my problem is. I downloaded the document for how this is done, but I am confused. Do I need to wipe my AP clean before flashing the upgrade? Also when I downloaded the file from the website it is a .tar file. Do I need to extract that to my TFTP directory or do I just place the .tar file in the TFTP directory? Can someone write out what I need to do to upgrade this with the proper commands. I know once I see it and do it once it is going to be a no brainer.
Thanks!
It's been a while since I did this but if I remember rightly, simply place the .tar file in the TFTP folder, the TFTP software should find it once it's in there and extract it itself.
Yes I have placed the .tar file there and maybe I am doing something else wrong. Do you remember what the commands were that you used? Did you erase what was already there before you did the upgrade?
-Scott
Have a look at this link
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/b1238ja/1238jasc/s38trb.htm#wp1048378
Look under "Using the CLI". There are also 3 links earlier in this thread, the 3rd one was the most help to me when I was having problems. To be honest I cant remember exactly what I did I just remember that these links helped me sort it.
Dont forget that the AP's IP address and the TFTP servers IP are important to get right otherwise they wont see each other.
Hope this helps
Hey I got it working. Seems my problems was that on my TFTP server I set the root folder for c:\TFTP-Root and when I was giving the command of archive download-sw /overwrite /reload tftp://192.168.1.122/tftp-root/filename.tar. I didn't need to add in the tftp-root folder name and it was looking in the wrong place. Once I removed the and did it like this archive download-sw /overwrite /reload tftp://192.168.1.122/filename.tar then it worked like magic.
Thanks for your help!
-Scott
Hope you got this sorted, I used Solarwinds TFTP client to fix my problem
DId'nt see your last post, glad you got it sorted mate.
Don't forget to rate this thread
