Cisco 1262AP
Tracy Beekman
Hi all,
I have asked before, but still having a problem that I guess I am not getting.  I have a 1262.  I have two antenna.  One that is omni at 5Ghz for outside and another that is a 2.4Ghz omni.  I can connect to the 2.4Ghz inside the building but for some reason am not able to see the 5Ghz side.  Here is the config I have on the device.  As you can see, both radio interfaces are up and it is a very simple config....does anybody see what I am doing wrong?  Thanks in advance for the help.
version 12.4
no service pad
service password-encryption
hostname DuncanvilleParksAP
logging rate-limit console 9
enable secret 5 $1$LImF$hW8sBN5nFexsqD8KHgc.31
no aaa new-model
clock timezone -0600 -6
clock summer-time -0500 recurring
ip domain name duncanville.com
dot11 syslog
dot11 ssid DuncanvilleParks
   authentication open
   guest-mode
username admin secret 5 $1$zOOH$g1pySQP9sHqiBFsW/oIO10
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
antenna gain 0
station-role root
world-mode dot11d country-code US both
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 port-protected
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
antenna gain 0
dfs band 3 block
speed  basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 10.10.10.2 255.255.255.0
no ip route-cache
ip default-gateway 10.10.10.1
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
28 Replies 28
what is the downtilt on the antenna?  If it's mounted high and it's pointed straight up, the eplane may not be reaching down to where the clients are.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
there is no downtilt on the antenna.  It is point straight up.  It is omnidirectional.  Should that put out a 360 spray or am I naive to think that??
well, 360 out from the antenna yes.  but it's not straight down.
take a look at the guide for the antenna, especially the e-plane pattern.
http://www.cisco.com/en/US/docs/wireless/antenna/installation/guide/ant5160v.html
HTH,
Steve
HTH,
Steve
I am using my iPhone to try and find the signal.
iPhone 3 or 3S does not have 802.11a antenna.
I have tried it at different places, but usually 3 to 4 hundred feet away from the building the atenna is mounted on.
This could be your culprit as wifi is not designed to go that far even with external antenna like the 5160V.    How HIGH from the ground is this antenna mounted?
So, what I haven't said is that the extension cable I am using is 200ft.
I am no electrical or radio engineer but this is very, very long.  The longer the cable the higher the signal loss.  And you're even operating WITHOUT a signal booster.
Yes....as you and Steve have been helping me with this and giving more information, I have been researching more on that info (odd how you can't seem to find answers until someone points you in that direction).  With a 200ft coax, that is up to 60% signal loss.  Cisco says up to 822 ft signal radius in perfect conditions, I have essentially cut that down to 300 ft with the cable and with it mounted high on a building with no tilt, I would get absolutely nothing.  I was under the impression that the antenna put out a 360 degree spherical signal, but have seen that that is not true.  I am going to take the antenna down tomorrow, plug directly in to the AP and see what I get.  I should have a GREAT signal on my iPhone then.  I have a 4S.  After I have proven that it is the cable causing most of the problems, I will more than likely purchase a 100ft ULL cable from Cisco (I have to get it out of the building somehow), put some tilt on it, and lower it.    Would yall recommend a signal booster either way for it though?  My thoughts are a definite yes, but it is always good to hear a yes or no from the experts.  Again, I can't thank either of you enough for your help and advice.  I would still be scratching my head.  Hopefully as I get more into this, I will be able to give the great tips and advice that you both have.
Tracy
200' of LMR400 on the 5ghz will give you approximately 20db of loss.  So if your TX power is at 20db + your 6db antenna gain, you have and actual EIRP of 6db of signal.  That equals to around 3mW for your TX power.  300' you would have around 30db of loss so you would have a -4db signal:)  You also need to take a db off for every connector inline.
Now if you were running LMR600 (real thick cable) you would have around 13.6db loss at 200'.
http://www.timesmicrowave.com/cgi-bin/calculate.pl
-Scott
You will most likely to be the second person I've known (since this year) to employ a signals booster.  But it won't benefit anything.
The reason is simple:  Let's say you put your antenna on a tower and you have a signal booster.  Fine at, say 200 feet away, the iPhone can "hear" the signal, however, the antenna cannot "hear" the return from the iPhone.   Wireless is an I-can-hear-you-can-you-hear-me system.  If the WAP can't hear the return then there's no-snowball-chance-in-he1l this is going to work.
Tracy Beekman
Alrighty....so, I took the 5GHz antenna down and plugged it directly into the AP.  Got nothing!!  Disabled the 2.4GHz radio, and got nothing again.  So, it would seem, that even though the 5GHz side is showing as up, it is not Tx or Rx.  Soooo.......   Do that make sense to anybody?
just to be safe, can you snap a picture of the AP with the antenna connected?
HTH,
Steve
HTH,
Steve
Ummm...Im not sure if I should reply with a gleeful "You betcha" or be completely offended?
If you really would like me to, I can, but I assure you that the antenna was plugged in to the correct spot, and on the off chance that it was a bad antenna port, I tried A, B, and C ports on the 5GHz side.
I"m not trying to be offensive, it just helps me when I can see.  But if you had the antenna on the 5GHz A or B and didn't see anything, then it could be the antenna or the AP.
HTH,
Steve
HTH,
Steve
Oh...I wasn't offended at all, or thinking you were trying to be.  So, I was leaning towards a "bad" device as well.  I don't think the antenna is even a question right now.  I was standing over the AP with my iPhone trying to connect with the 5GHz side and didn't see it at all.  So, it would seem all of this for a BAD device!!  You know, Foxconn is only a 4 hour drive from me.  Wonder what they would think if I personally brought it down to them!!!!!!  LOL
I'll agree with Steve's request.  Please take a picture.  This setup is getting mighty odd!
Stupid question:  Did you (or anyone), by any chance, crank DOWN the power of the radio?
The power was not touched.  I set everything up as far as range and throughput through the web interface of the device.  Both of the radios was set for "best for range", but with the problem of me standing right over the AP with my phone trying to connect and not seeing it at all and with Steve saying it as well, I think the radio on the 5Ghz side must be bad.  I have contacted my vendor and asked for a replacement.  We will see from there.
