Cisco 1310 point to point encryption?
clougher01
Howdy.
We have two Cisco 1310 devices working currently in point to point mode. I have a couple of questions regards this..
1. What is the best method to encrypt the point to point links between the two? We would like to use local passwords for this.
2. We have two point to point links on each device. Would we be able to configure one link for encryption without dropping our connection to that device and then configure the second one?
3. Is there any sample guide for point to point encryption?
Many thanks..
Taff.
6 Replies 6
Surendra BG
ANS - We can use Ciphers TKIP as the encryption and WPA-PSK as the authentication.
ANS - I request you to brief me out on "we have 2 P2P on each device" does this mean we have 2 SSID configured??
https://cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml#pers
Surendra
Surendra BG
Thanks for the quick reply.
Yes there are 2 ssids on the device.
no problem.. we need to create the sun interfaces and map the SSIDs to respective VLANS, thei will solve our issue.
the link which i provided in my previous email may help you. Is der anything else that i can help you with?
Surendra
Surendra BG
Nope that's all good.. Thanks.
thats great
Have a nice day / Evening or afternoon
Plz rate the post if this solved your issue.
Surendra
Surendra BG
Please mark the Question as Answered if the provided information is correct and issue is fixed.
thanks,
Vinay
Thanks & Regards
