Cisco 1941W configure mac authentication in wireless
Chin
Dear all,
    Appreciate that anyone know how to configure mac authentication in 1941w router?
    Perhaps can show me some example of configure mac authentication in 1941w router.
2 Accepted Solutions
If your trying to configure mac filtering on the access point in the 1941w and the AP is autonomous, you can follow this guide:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/116582-configure-ap-00.html
Scott
-Scott
For MAC filtering In case of autonomous AP creating access-list, use the below command
Test-AP# configure terminal
Test-AP(conf)# access-list 700 deny <mac-address you want filter/deny>
 For light weight follow the below process:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/4-2/configuration/guide/ccfig42/c42lwap.html#wp1115915
Thanks & Regards
Sandeep
5 Replies 5
Sandeep Sharma
Below is the configuration for mac authentication bypass on cisco 1900 router
c1921> enable
c1921# configure terminal
c1921(conf)#interface gigabitethernet slot / port
c1921(conf-if)# authentication port-control auto
c1921(conf-if)# mab
c1921(conf-if)# end
> You can verify using the below command
c1921#show authentication sessions
Interface MAC Address Method Domain Status Session ID
Gi0/1 0201.0201.0201 mab DATA Authz Success 0303030300000004002500A8
c1921#show authentication sessions interface Gi0/1
 Interface: GigabitEthernet0/1
 MAC Address: 0201.0201.0201
 IP Address: Unknown
 User-Name: 02-01-02-01-02-01
 Status: Authz Success
Domain: DATA
 Oper host mode: single-host
 Oper control dir: both
 Authorized By: Authentication Server
 Vlan Group: N/A
 AAA Policies:
 Session timeout: N/A
 Idle timeout: N/A
 Common Session ID: 0303030300000004002500A8
 Acct Session ID: 0x00000007
 Handle: 0x3D000005
Runnable methods list:
 Method State
 mab Authc Success
For more details refer the below link:
http://www.cisco.com/c/en/us/td/docs/routers/access/1900/software/configuration/guide/Software_Configuration/conf.pdf
Thanks & Regards
Sandeep
Hi Sandeep,
Thanks for your document.
But this is the mac authentication bypass. How about if I want to control user authentication by manual configure mac address in authentication to control the wifi access?
Best regards
TPPSupport
Scott
-Scott
Thanks guys,
I able to use the mac-list to control the mac address filtering.
Thanks & Regards
Sandeep
