Cisco 2500 series not responding
w.gaotlhobogwe1
hi
My Cisco wireless controller 2500 series is not responding in puTTy and in web default address access. it started after when i configured it using web access address, after configuration i clicked save then my electricity cutoff thats when it started not to respond can you please help
Leo Laohoo
The flash card could be corrupt.  Contact TAC to get it RMA-ed.
Abhishek Abhishek
When you plug the controller into an AC power source, the bootup script initializes the system, verifies the hardware configuration, loads its microcode into memory, verifies its operating system software load, and initializes itself with its stored configurations. Before performing this test, you should have connected your PC to the CLI console on the controller as described in the "Connecting the Controller Console Port" section.
Please have a look into the below link
http://www.cisco.com/c/en/us/td/docs/wireless/controller/6-0/configuration/guide/Controller60CG/c60mint.html
gohussai
Level 4
Level 4
You should use Console port of 2500 to directly connect with the system and power on and follow the interactive script which appears on startup. IF still you are having issue even after reboot the Controller then you just change the Controller mode to ROMMON and reload the Controller image.
