Cisco 2504 Wireless Controller
Superhornet
Community Member
Bonjour je voudrais maitre mon Cisco 2504 wireless controller à jour. Il a actuellement là version 8.1.102.0 installer. et je voudrais passer à la version "Release 8.5.182.0" je n'arrive pas à la télécharger !! j'ai toujours un message qui vient
je voudrais savoir la procédure. je suis une personne privé. Je voudrais éviter de faire des contra de maintenance.
Merci pour votre aide
12 Replies 12
Mark Elsen
        - Vous ne pouvez pas télécharger de logiciel de Cisco sans avoir un contrat de service
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Leo Laohoo
NOTE:  Pardon, I do not speak French.
1. Go to the Cisco website and note the link to the AireOS firmware and the complete filename of the firmware.  Please include the AP Bundle file.
2. Read this:  Cisco Wireless LAN Controller AireOS Software FIPS Mode Denial of Service Vulnerability
3. Scroll down to the "Customers Without Service Contracts" section:
Customers who purchase directly from Cisco but do not hold a Cisco service contract and customers who make purchases through third-party vendors but are unsuccessful in obtaining fixed software through their point of sale should obtain upgrades by contacting the Cisco TAC: https://www.cisco.com/c/en/us/support/web/tsd-cisco-worldwide-contacts.html
Customers should have the product serial number available and be prepared to provide the URL of this advisory as evidence of entitlement to a free upgrade.
4. Contact Cisco TAC (by email) and provide the following information:
  • Serial Number of the WLC
  • Link to the file(s) (Step 1)
  • Filename(s) (Step 1)
  • Security Bulletin (Step 2)
Hope this helps.
Rich R
Just to add to above - the version you should be asking for is 8.5.182.12 - not 8.5.182.0 - because of the field notices linked below.  The link to 8.5.182.12 is also below.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
I cannot see 8.2.182.7 for 2504. Is it not support 2504 ?
That is 8.2.182.0, not 8.2.182.7.
- 8.5.182.7 does support 2504.
- 8.5.182.7 is a special download at
https://software.cisco.com/download/specialrelease/8f166c6d88b9f77aabb63f78affa9749
- 8.5.182.7 has been superseded by 8.5.182.11 so if you're upgrading then you should be upgrading to 8.5.182.11 not 8.5.182.7
- 8.5.182.11 is also a special download at
https://software.cisco.com/download/specialrelease/2702eede2b47a5c3bb40795bbe836af6
Note that the 2504 WLC is end of support:
https://www.cisco.com/c/en/us/products/collateral/wireless/2504-wireless-controller/eos-eol-notice-c51-740645.html
and AireOS 8.5 is end of life:
https://www.cisco.com/c/en/us/products/collateral/wireless/8500-series-wireless-controllers/bulletin-c25-744139.html
So Cisco no longer release any standard maintenance releases for these products.
Greetings,
I have acquired the 2504 WLC and would like to upgrade it to the latest security level possible together with the five 3602I APs.
I understand that the 2504 is EOL & EOS and that I cannot download the software without a valid contract.
Regardless, the WLC and AP combination can go up to release 8.5.182.0. But 8.5.182.0 should not be used but instead 8.5.182.7. That in turn has also been replaced by 8.5.182.11. But now 8.5.182.11 is no longer supporting the 2504 WLC?
So what should I try and do? How can I actually get to release 8.5.182.x?
Thank you
Read the entirety of this thread and understand.
8.5.182.11 does support the 2504:
download link below.
Hi Rich,
Yes I know. The following is what I was planning but anyway I heve been declined from TAC.
-7.3.101.0
-Install Release 2.0.0.0 of Cisco Wireless LAN Controller Field Upgrade Software
-7.3.101.0 >> 8.3.150.0
-8.3.150.0 >> 8.5.131.0
-8.5.131.0 >> 8.5.182.0 (latest supported)
OMG - that is one very neglected WLC!!!!
But I'd suggest a different path:
-7.3.101.0
-7.3.101.0 >> 8.0.152.0
-8.0.152.0 >> 8.3.150.0
-8.3.150.0 >> 8.5.182.11
Yes, getting all those downloads is going to be tricky if you don't have a Cisco partner/supplier who can help you.
For the latest version with security vulnerability updates - there is an option:
Find a recent security advisory that affects 8.5 code and find the section which says "Customers without Contracts" then email TAC (don't phone) quoting the URL of the advisory, the paragraph just mentioned and the version and URL https://software.cisco.com/download/specialrelease/2702eede2b47a5c3bb40795bbe836af6  for the software you want to download and serial number of your WLC.  You'll have to mention which platform you need it for (2504) because they have all of them there at that URL.  Then TAC should publish it to you directly.  This advisory should be suitable: Cisco Wireless LAN Controller AireOS Software FIPS Mode Denial of Service Vulnerability
