cisco 3502E LAP is showing DTLS tunneling issue with 5508 Controller
jbnair
Hello All,
I am trying to connect 3502-E-K9 Access points to 5508 controller.
The dhcp pool is from the same range from management ip address.
The AP is getting the IP address.
The AP can see the Controller ip addresses. (there are two 5508 controllers) Option 60 and 43 is already setup on the pool.
The controllers are upgraded to 7.5.102.0 IOS
The FUS FPGA version is 1.7
I have a ASA service module in 6500 and the management vlan gateway is configured with the firewall. But i temporarily removed the gateway address from FW  and applied it to the 6500 switch vlan, but still the problem is going on and it shows this is not a problem from the FW.
The logs from the AP is shown below:
*Nov 10 18:03:58.481: %CAPWAP-5-SENDJOIN: sending Join Request to 10.210.99.21
*Nov 10 18:03:58.484: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Nov 10 18:03:58.484: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Nov 10 18:03:58.484: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Nov 10 18:03:58.484: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.210.99.21
Full log:
*Mar  1 00:13:30.348: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:13:30.439: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:13:31.439: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
Translating "CISCO-CAPWAP-CONTROLLER.sht-2.com"...domain server (10.210.99.1)
*Mar  1 00:13:40.461: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.210.99.21 obtained through DHCP
*Mar  1 00:13:40.461: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.210.99.22 obtained through DHCP
*Mar  1 00:13:40.461: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:13:43.462: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.sht-2.com
*Mar  1 00:13:53.466: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov 10 18:03:58.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.210.99.21 peer_port: 5246
*Nov 10 18:03:58.481: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.210.99.21 peer_port: 5246
*Nov 10 18:04:03.483: %CAPWAP-5-SENDJOIN: sending Join Request to 10.210.99.21
Any comments?
Thanks & Regards
Jay
15 Replies 15
Hi Jay,
Glad that your problem is solved.
Thanks for rating
