Cisco 3602i blinking blue-green-red after reset
QualQuek
I have a problem with my Cisco 3602i, i've reseted it but it always blinking blue-green-red.
I'm using a TPLink POE Injector up to 60w, i can see my 3602i in my switch with an ip adress i can ping it but i can't connect to it in SSH it always say "connction refused" i can't access to it by the IP as well it says it doesn't allow connection. I can't at least access to it with putty with my console cable (FDTI Chip), just nothin happen (it's configured to 9600 8 1 none none).
Have you any idea?
Thanks in advance.
QualQuek
After the reset it was the same so i've returned it to my Cisco reseller, the new one is working correctly.
Thanks everyone.
5 Replies 5
marce1000
 - Concerning the blinking probably a  powering problem (AP does not get enough power) ; for starters scrutinize the boot process on the AP console when starting it up ,
 M.
Hi @QualQuek
 This AP is probably a capwap AP and is looking for the WLC, that´s what the led blinking and change collor means.  If you dont have a WLC, it will get nowhere.
 No, you should be able to console to it. This is probably a cable problem. Unfortunatelly not all console cable works with APs.
The reason you can not access it using the IP address is that capwap AP only allows for SSH connection after it joined the WLC.
QualQuek
Just a precision i have other 3602i that i can access correctly with my console cable and putty. Only this one is causing this i don't know why exactly. I will try another full reset.
that´s what I was about to say. Try to reset it.
QualQuek
Thanks everyone.
