Cisco 3802 with Cisco Switches POE
I hope everyone is doing great. Just wanted to check to see if the 3802 Series Access Points will work with Cisco 3850 Switch Series as well as the Cisco 9300 Series. Thanks
d.friday
Level 4
Level 4
The 3850 switches will work with the 3802  APs, I suggest using the Mgig ports on the 3850 Switches
5 Replies 5
Chris Donkelaar
In what way? From the product overview, depending on the model you want, the Catalyst 9300 provides PoE capabilities with up to 384 ports of PoE per stack, 60W Cisco UPOE, and PoE+. Is this what you are looking for?
-If I helped you somehow, please, rate it as useful.-
Chris,
Thanks for the response and is now pretty clear that the 3802's will work on the 9300 Series, but what about the 3850's series switches POE, will the 3802's series AP's will work on them?
d.friday
Level 4
Level 4
Thank you so much guys for your time. Appreciated
Leo Laohoo
3800 uses 30.0w PoE.  So if the 3850 support uPoE then the AP can operate at full power.
