Cisco 4400 Wireless Controller is unreachable
satheesh5
I have two Cisco 4400 Wireless Controller. one is working fine but the other one is not reachable. Kindly advice how to troubleshoot.
Controller: - 4400 Series
Model: - 4404
Software Version - : 7.0.250.0
Satheesh.
2 Accepted Solutions
If that is the only output you get I think you will have to contact TAC
Dont know if the 4400's  still are supported and if you have a contract on it?
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-series-switches/end_of_life_notice_c51-634665.html
Maybe TAC has some way of troubleshooting or rebuilding the bootprocess or it will have to be replaced.
are you getting this issue after a software upgrade then check here
http://www.cisco.com/c/en/us/support/docs/field-notices/637/fn63770.html
have you tried to boot options (using backup image)
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/107530-backup-image-wlc.html
9 Replies 9
Scott Fella
Can you tell use what other troubleshooting you have done?  There isn't much information for us to help you.  Is the unit powered up and accessible via console?  Is the ports up on the controller and in the switch?  Can you ping the gateway from the WLC?
-Scott
-Scott
Hi Scott,
Sorry for the delayed reply. itried connecting through the console below is the details.
Bootloader 4.2.112.0 (Mar 12 2008 - 19:38:43)
Motorola PowerPC ProcessorID=00000000 Rev. PVR=80200020
        CPU: 833 MHz
        CCB: 333 MHz
        DDR: 166 MHz
        LBC: 41 MHz
L1 D-cache 32KB, L1 I-cache 32KB enabled.
I2C:   ready
DTT:   1 is 40 C
DRAM:  DDR module detected, total size:512MB.
512 MB
8540 in PCI Host Mode.
8540 is the PCI Arbiter.
Memory Test PASS
 It get stuck at this point. Kindly advice.
Satheesh.
Still i couldnt find a solution for the above issue.
Satheesh.
As we have not heard from you that what other troubleshooting you have done towards resolution.
Please go through the bellow link which can help you on some basic troubleshooting steps for WLC.
Here you go : http://www.cisco.com/c/en/us/support/wireless/4400-series-wireless-lan-controllers/products-tech-notes-list.html
sobhardw
Please refer to the configuration guide of Wireless controller:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70mobil.html
and below is the guide with the troubleshooting steps :
http://www.cisco.com/c/en/us/td/docs/wireless/technology/guest_access/technical/reference/4-1/GAccess_41.html#wp1001632
mohanak
