Cisco 8510 HA controller in DMZ as Guest Anchor
Hi All,
We've two 8510 WLCs. one Primary 8510 WLC and another 8510-HA unit. The initial design was to use them in HA pair with AP-SSO.
Can we use this 8510-HA unit as DMZ anchor controller for dedicated guest network?
I know 8510 has RTU licensing, but I'm not sure whether we can use the HA unit in the DMZ only to tunnel the Guest traffic?
CJ
Please check this post which may help you
https://supportforums.cisco.com/discussion/12329106/8510-foreign-controller-and-5760-anchor-controller
