Cisco 871 or 871W supports VLAN routing?
hxmengmetro
Hi All,
Can I use the Fa 4 (WAN) port to create several subinterface to do the vlan routing? I know 851 can't do it. Not sure about 871. Thanks.
Lou
Leo Laohoo
Depends on the version of the IOS.
Version 12.3 will support up to 10 VLANs and 12.4 will support only 2 VLANs.
Thanks a lot! So even for the version supporting only two vlans, it can support subinterface on WAN port and do the vlan routing, right?
He he he ... No.
Here's what we did:
F4 is one VLAN and any other port has another VLAN.
Thanks Leo. It's not like the router on a stick inter vlan routing we usually can do. If I connect one 2960 switch to Fa0 and put Fa0 as a trunking port which allow all the vlans, can 871 do the vlan routing between the vlans in 2960?
Thanks.
Lou
