06-14-2025 12:45 PM
Hi Community,
We are experiencing an issue with Cisco 9120 Access Points after migrating them from an EWC setup to a centralized Cisco 9800 WLC running IOS-XE version 17.9.6. The APs have successfully joined the new WLC, and end users are able to connect to the Wi-Fi network without any issues. However, the LED on the APs continues to blink instead of displaying the expected solid green or operational status.
Solved! Go to Solution.
06-16-2025 01:34 AM
Hi @Leo Laohoo & @Rich R
Thank you for your replies.
The issue has been resolved. LLDP was disabled on the PoE switch. After enabling LLDP, the AP LED is now stable as expected.
06-14-2025 07:17 PM
CSCwh38810
06-15-2025 05:42 AM
Also note that 17.9 has passed End of SW Maintenance Releases Date so you should be planning to migrate to a new extended support release like 17.12 or 17.15. Refer to the TAC Recommended link below.
While remaining on 17.9 you should at least be considering the latest 17.9 release 17.9.7 for numerous bug fixes.
And while you are still on 17.9.6 have you installed the latest APSP3?
06-16-2025 01:34 AM
