Cisco 9800 AP System Monitoring recommendation
Gehrig_W
Hello Cisco WLAN-experts,
during implementation and use of the new 9800-WLC-generation, I stumbled over the System Monitoring
of WLAN APs which can be activated within the AP Join Profile. Here are the start values:
I would like to start using this feature and would like to know which Thresholds and intervals are recommended by Cisco.
Here are my first start values for testing:
And here are my values from Monitoring after activation of Monitor Real Time Statistics and Trigger Alarm for AP:
Why are the APs still showing "Alarm inactive" eventhough I have activated both ?
Or does it mean that the current values of CPU and Memeory usage are not high enough to trigger an alarm ?
Who knows more about this feature ?
Thank You for any tipps
Kind regards
Wini
Rich R
Did you read the config guide?  They give examples:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-9/config-guide/b_wl_17_9_cg/m_ap_real-time_statistics.html
Correct - alarm is only active if threshold is exceeded - the examples show this.
Rich R
Hello Rich R,
thank You very much for pointing me to the example in the config guide for AP Real-Time-statistics.
Device# show ap config general | section AP statistics
The shown command within config guide shows statistics but not the WLAN AP they are belonging to.
To see also the AP-names in list format the command should  be like this:
Thank You for Your fast help in improving my knowledge about basic 9800-WLC and AP Real-Time-Statistics monitoring.
Greetings from Frankonia
Wini
