Cisco 9800 Controller with ISE Integration for Guest Self Registation
Hi Team
I'm trying to implement the guest self registration portal with cisco ISE and i successfully done the setup with Cisco 5508 controller but with cisco 9800 i was not able to do the same
Could anyone help with this
Balaji
Central WebAuth with ISE and 9800 documented here: https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213920-central-web-authentication-cwa-on-cata.html
*****Help out other by using the rating system and marking answered questions as "Answered"*****
6 Replies 6
Mark Elsen
 - FYI : https://community.cisco.com/t5/security-knowledge-base/ise-and-catalyst-9800-series-integration-guide/ta-p/3753060
  Note that you can always have a checkup of the 9800 controller configuration with the CLI command show tech wireless ; feed the output into Wireless Config Analyzer
                            The resulting advisories can help you in staging and or obtaining intended result (e.g)
 M.
I think this will help for this solution
i'll check and update today
Balaji
I have created 2 SSID Employee / Guest
Enabled the flex profile and Guest is in centralized DHCP which is working as expected but Employee should get IP from local dhcp server
after enabled the Flex Profile i'm not able to see employee ssid itself in any of the client device
In advance tab it is in default configuration and no changed made. Could you please help here
Balaji
The main question is how far you get, what state the client is in at the controller when it doesn't go further, and what the ISE log says.
I have enabled the MAC Filtering in SSID Configuration. Post that When client is connected to the Guest SSID there are not getting the IP address and in Controller logs i could see that failure reason as : AAA Server was down
*Nov 25 18:55:24.622: %SESSION_MGR-5-FAIL: Chassis 1 R0/0: wncd: Authorization failed or unapplied for client (0ab7.a2af.11fd) on Interface capwap_90000002 AuditSessionID 954BA8C00000004107D627CC. Failure reason: Authc fail. Authc failure reason: AAA Server Down.
sis 1 R0/0: wncd: Authorization failed or unapplied for client (0ab7.a2af.11fd) on Interface capwap_90000002 AuditSessionID 954BA8C00000004007D5FA84. Failure reason: Authc fail. Authc failure reason: AAA Server Down.
