Clients Intermittently Dropping from Wi-Fi
malone352
Hi all,
I just deployed a 9800 vWLC for a customer, they are using 802.1x PEAP authentication against ISE and AD. Clients are reporting they drop from Wi-Fi occasionally and have to manually connect to the SSID again.
Log below showing state of client as they experience the issue
On the WLAN itself I have FT and Aironet IE disabled, session timeout set to 14400 and idle is 3600
2023/05/16 08:41:10.613361 {wncd_x_R0-0}{1}: [client-orch-sm] [19913]: (note): MAC: 9859.7a47.XXXX Association received. BSSID 10a8.29fc.6c6e, old BSSID 10a8.29fc.656e, WLAN CUST Corporate, Slot 1 AP 10a8.29fc.6c60, MHN_AP_04
2023/05/16 08:41:10.613710 {wncd_x_R0-0}{1}: [dot11-validate] [19913]: (ERR): MAC: 9859.7a47.XXXX Failed to dot11 ie validate aironet ipaddr. Aironet ipaddr IE is not present in Assoc Request
2023/05/16 08:41:10.614004 {wncd_x_R0-0}{1}: [dot11] [19913]: (note): MAC: 9859.7a47.XXXX Association success. AID 2, Roaming = True, WGB = False, 11r = False, 11w = False Fast roam = False
2023/05/16 08:41:10.614196 {wncd_x_R0-0}{1}: [client-orch-sm] [19913]: (note): MAC: 9859.7a47.XXXX Delete mobile payload sent forbssid: 10a8.29fc.656e WTP mac: 10a8.29fc.6560 slot id: 1
2023/05/16 08:41:10.614197 {wncd_x_R0-0}{1}: [client-orch-sm] [19913]: (note): MAC: 9859.7a47.XXXX DELETE mobile sent to BSSID 10a8.29fc.656e
2023/05/16 08:41:10.614314 {wncd_x_R0-0}{1}: [client-orch-state] [19913]: (note): MAC: 9859.7a47.XXXX Client state transition: S_CO_RUN -> S_CO_L2_AUTH_IN_PROGRESS
2023/05/16 08:41:10.615400 {wncd_x_R0-0}{1}: [client-auth] [19913]: (note): MAC: 9859.7a47.XXXX ADD MOBILE sent. Client state flags: 0x1 BSSID: MAC: 10a8.29fc.6c6e capwap IFID: 0x90000034
2023/05/16 08:41:10.623402 {wncd_x_R0-0}{1}: [client-auth] [19913]: (note): MAC: 9859.7a47.XXXX L2 Authentication initiated. method DOT1X, Policy VLAN 0, AAA override = 1 , NAC = 0
2023/05/16 08:41:25.124509 {wncd_x_R0-0}{1}: [client-orch-sm] [19913]: (note): MAC: 9859.7a47.XXXX Association received. BSSID 10a8.29fc.656e, old BSSID 10a8.29fc.6c6e, WLAN CUST Corporate, Slot 1 AP 10a8.29fc.6560, MHN_AP_02
2023/05/16 08:41:25.124597 {wncd_x_R0-0}{1}: [client-orch-state] [19913]: (note): MAC: 9859.7a47.XXXX Client state transition: S_CO_L2_AUTH_IN_PROGRESS -> S_CO_L2_AUTH_IN_PROGRESS
2023/05/16 08:41:25.124707 {wncd_x_R0-0}{1}: [dot11-validate] [19913]: (ERR): MAC: 9859.7a47.XXXX Failed to dot11 ie validate aironet ipaddr. Aironet ipaddr IE is not present in Assoc Request
2023/05/16 08:41:25.124907 {wncd_x_R0-0}{1}: [dot11] [19913]: (note): MAC: 9859.7a47.XXXX Association success. AID 7, Roaming = True, WGB = False, 11r = False, 11w = False Fast roam = False
2023/05/16 08:41:25.125020 {wncd_x_R0-0}{1}: [client-orch-sm] [19913]: (note): MAC: 9859.7a47.XXXX Delete mobile payload sent forbssid: 10a8.29fc.6c6e WTP mac: 10a8.29fc.6c60 slot id: 1
2023/05/16 08:41:25.125021 {wncd_x_R0-0}{1}: [client-orch-sm] [19913]: (note): MAC: 9859.7a47.XXXX DELETE mobile sent to BSSID 10a8.29fc.6c6e
2023/05/16 08:41:25.125107 {wncd_x_R0-0}{1}: [client-orch-state] [19913]: (note): MAC: 9859.7a47.XXXX Client state transition: S_CO_L2_AUTH_IN_PROGRESS -> S_CO_L2_AUTH_IN_PROGRESS
2023/05/16 08:41:25.125683 {wncd_x_R0-0}{1}: [client-auth] [19913]: (note): MAC: 9859.7a47.XXXX ADD MOBILE sent. Client state flags: 0x1 BSSID: MAC: 10a8.29fc.656e capwap IFID: 0x90000010
2023/05/16 08:41:25.133963 {wncd_x_R0-0}{1}: [client-auth] [19913]: (note): MAC: 9859.7a47.XXXX L2 Authentication initiated. method DOT1X, Policy VLAN 0, AAA override = 1 , NAC = 0
2023/05/16 08:41:27.105904 {wncd_x_R0-0}{1}: [client-auth] [19913]: (note): MAC: 9859.7a47.XXXX L2 Authentication Key Exchange Start. Resolved VLAN: 65, Audit Session id: F16F630A00001D802384F8A7
2023/05/16 08:41:27.132964 {wncd_x_R0-0}{1}: [client-keymgmt] [19913]: (note): MAC: 9859.7a47.XXXX EAP Key management successful. AKM:DOT1X Cipher:CCMP WPA Version: WPA2
2023/05/16 08:41:27.133105 {wncd_x_R0-0}{1}: [client-orch-sm] [19913]: (note): MAC: 9859.7a47.XXXX Mobility discovery triggered. Client mode: Flex - Local Switching
2023/05/16 08:41:27.133108 {wncd_x_R0-0}{1}: [client-orch-state] [19913]: (note): MAC: 9859.7a47.XXXX Client state transition: S_CO_L2_AUTH_IN_PROGRESS -> S_CO_MOBILITY_DISCOVERY_IN_PROGRESS
2023/05/16 08:41:27.133139 {wncd_x_R0-0}{1}: [mm-client] [19913]: (note): MAC: 9859.7a47.XXXX Mobility Successful. Roam Type None, Sub Roam Type MM_SUB_ROAM_TYPE_INTRA_INSTANCE, Previous BSSID MAC: 10a8.29fc.6c6e Client IFID: 0xa0000029, Client Role: Local PoA: 0x90000010 PoP: 0x0
2023/05/16 08:41:27.133332 {wncd_x_R0-0}{1}: [client-auth] [19913]: (note): MAC: 9859.7a47.XXXX ADD MOBILE sent. Client state flags: 0x6 BSSID: MAC: 10a8.29fc.656e capwap IFID: 0x90000010
2023/05/16 08:41:27.133540 {wncd_x_R0-0}{1}: [client-orch-state] [19913]: (note): MAC: 9859.7a47.XXXX Client state transition: S_CO_MOBILITY_DISCOVERY_IN_PROGRESS -> S_CO_DPATH_PLUMB_IN_PROGRESS
2023/05/16 08:41:27.133693 {wncd_x_R0-0}{1}: [client-orch-state] [19913]: (note): MAC: 9859.7a47.XXXX Client state transition: S_CO_DPATH_PLUMB_IN_PROGRESS -> S_CO_IP_LEARN_IN_PROGRESS
2023/05/16 08:41:27.133886 {wncd_x_R0-0}{1}: [sanet-shim-miscellaneous] [19913]: (ERR): MAC: 9859.7a47.XXXX get_fabric_sgt_tag_value: Fabric mode is not enabled
2023/05/16 08:41:27.134146 {wncd_x_R0-0}{1}: [client-orch-state] [19913]: (note): MAC: 9859.7a47.XXXX Client state transition: S_CO_IP_LEARN_IN_PROGRESS -> S_CO_RUN
Devices are Intune managed xml config below, connection mode is auto
    <name>CUST Corporate</name>
    <SSIDConfig>
        <SSID>
            <hex>XXX7472616E20436F72706F72617465</hex>
        </SSID>
    </SSIDConfig>
    <connectionType>ESS</connectionType>
    <connectionMode>auto</connectionMode>
    <MSM>
        <security>
            <authEncryption>
                <authentication>WPA2</authentication>
                <encryption>AES</encryption>
                <useOneX>true</useOneX>
            </authEncryption>
            <PMKCacheMode>enabled</PMKCacheMode>
            <PMKCacheTTL>720</PMKCacheTTL>
            <PMKCacheSize>128</PMKCacheSize>
            <preAuthMode>disabled</preAuthMode>
            <OneX xmlns=http://www.microsoft.com/networking/OneX/v1>
                <authMode>machineOrUser</authMode>
                <EAPConfig><EapHostConfig xmlns=http://www.microsoft.com/provisioning/EapHostConfig><EapMethod><Type xmlns=http://www.microsoft.com/provisioning/EapCommon>25</Type><VendorId xmlns=http://www.microsoft.com/provisioning/EapCommon>0</VendorId><VendorType xmlns=http://www.microsoft.com/provisioning/EapCommon>0</VendorType><AuthorId xmlns=http://www.microsoft.com/provisioning/EapCommon>0</AuthorId></EapMethod><Config xmlns=http://www.microsoft.com/provisioning/EapHostConfig><Eap xmlns=http://www.microsoft.com/provisioning/BaseEapConnectionPropertiesV1><Type>25</Type><EapType xmlns=http://www.microsoft.com/provisioning/MsPeapConnectionPropertiesV1><ServerValidation><DisableUserPromptForServerValidation>false</DisableUserPromptForServerValidation><ServerNames>CUSTISE</ServerNames></ServerValidation><FastReconnect>true</FastReconnect><InnerEapOptional>false</InnerEapOptional><Eap xmlns=http://www.microsoft.com/provisioning/BaseEapConnectionPropertiesV1><Type>26</Type><EapType xmlns=http://www.microsoft.com/provisioning/MsChapV2ConnectionPropertiesV1><UseWinLogonCredentials>true</UseWinLogonCredentials></EapType></Eap><EnableQuarantineChecks>false</EnableQuarantineChecks><RequireCryptoBinding>false</RequireCryptoBinding><PeapExtensions><PerformServerValidation xmlns=http://www.microsoft.com/provisioning/MsPeapConnectionPropertiesV2>true</PerformServerValidation><AcceptServerName xmlns=http://www.microsoft.com/provisioning/MsPeapConnectionPropertiesV2>true</AcceptServerName></PeapExtensions></EapType></Eap></Config></EapHostConfig></EAPConfig>
            </OneX>
        </security>
    </MSM>
        <enableRandomization>false</enableRandomization>
        <randomizationSeed>4046238024</randomizationSeed>
    </MacRandomization>
</WLANProfile>
12 Replies 12
malone352
I should mention issue was not present on their old AireOS estate
Mark Elsen
   1) What is the controller software version ?
   2) Have a checkup review of the controller configuration with the CLI command show tech wireless ; have the output analyzed with : https://cway.cisco.com/wireless-config-analyzer/
   3) Perform client debugging according to : https://logadvisor.cisco.com/logadvisor/wireless/9800/9800ClientConnectivity  , you can have client debugs analyzed by : https://cway.cisco.com/wireless-debug-analyzer/
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
saba75564
Despite the fact that the issue does not occur on AireOS's old estate, it was there on the new estate
- Please execute the requested tasks,
M.
       Beauty and terror
      Just keep going
       No feeling is final
Hi thank you for the reply
We are using version 17.06.04, nothing major in analyzed output findings below, I suppose i should ensure NTP matches ISE
Error 230115 RF tag points to non-existing RF profile name. This may cause severe controller issues. Tag(s) name: TEST <- THis is not in use
Warning 230023 Controller with no valid time source (sync has not happened) or file without NTP information, please check if controller has valid
NTP server configured
Warning 230038 To prevent WebUI issues while using some large GUI options (VLANs for example), it is advisable to increase the VTY count to 50
Warning 230045 Device Classification (client profiling) is not globally enabled, it is recommended to use it
Warning 230056 Service tcp-keepalive in/out, should be enabled to reduce lingering inactive connections to management points
Warning 230079 Redundancy is in use, but RMI feature is not enabled. For best high availability scenarios, it is recommended to use it
Warning 240020 11k Neighbor List is in use, but dual band is disabled. if not using single-band devices, enable both for best results. WLAN(s): SSID Guest,SSID Corporate
Warning 250014 ARP proxy is disabled. To save client battery and other performance improvements, it is recommended to enable. Profiles: SSID-Guest
Warning 290001 Management user has not been set. For security reasons, it is best practice to configure username/password for AP access on the join
profile. AP Profiles: default-ap-profile
Warning 290004 Syslog host is not set (using default broadcast value). For best practices, it is recommended to use a syslog server. AP Profiles:
default-ap-profile
- You have some errors there which need to be resolved for a start.
- Upgrade to TAC recommended code 17.6.5  or 17.9.3 as per TAC recommended link below.
derek.x.witts
Hi, just wondered if you upgraded the code and if that fixed your issue?
yum3372
I have same error on my WLC9800. That version is 17.3.6.
Please somebody help me.
@yum3372 >... same error
        For starters begin with a new post  ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
JPavonM
Have you updated device's drivers? (sometimes it happen that also upgrading BIOS for some laptops solve connectivity issues)
derek.x.witts
Thank you for the repsonse. We have tried end device firmware update to no avail. We are going to test in the lab if a controller code  upgrade fixes the issue but have also raised with the end vendor to advise.
dolahler
Hi Derek,
wandering if you managed to upgrade your WLC9800 to later IOS XE version and if that resolved the issue?
