CISCO 9800 wreless controller not getting the http or https access giving ERR_SSL_PROTOCOL_ERROR
Shrikant Gaikwad
Frequent Visitor
Frequent Visitor
Hello Team,
i am trying to deploy the two C9800-40-K9 controller in the network
1- Before connecting the both controller to the network
i had given one ip adress 10.91.225.80 ip  to the Gi0 of WLC1 and connected the cable between SP port and laptop with static ip address 10.91.225.82
2.from laptop i am able to take the https acess of the WLC1 , i upgraded the IOS for WLC1 to the 16.11.01
3.same thing i did for the WLC2 upgraded the IOS and 10.91.225.81
4.during the configuration of WLC1 and WLC2 i used Gi0 as the wireless Managment interface
5. Then we connected the both the WLC1 and WLC2 to the network but during this time i didnt check the connectivity of the WLC from coreswitch
6. Both WLC RP Port is in L2 vlan 498
7.after rackmounting Both WLC by connecting to the SP to the laptop from the browser i configured the HA between two WLC , HA form properly , i did the failover test it was working properly
8. but when i try to connect from the different vlan2 or Vlan 50 from other switch ports i am not able to take the https access of both controller , i am getting ERR_SSL_PROTOCOL_ERROR in the browser
9. can i help me what may go worng ?
10.i have license file but i didnt uploaded them on any WLC?
11. as Gi0 is not pinging from other network i changed Gi0 ip to the interface vlan 50 and wireless mgmt to int vlan 50 but still i am not able to ping the int vlan 50 ip
can somebody help did we are doing something wrong
Now we are not able to ping the int vlan 50 from outside network
we have given another int vlan 2 ip in WLC1 and this ip we are able to ping but when we try to take the browser with the interface vlan 2 of WLC i am getting the ERR_SSL_PROTOCOL_ERROR
attached is the diagram and attached is the error screenshot
Thanks all
Shrikant Gaikwad
34 Replies 34
Here are the commands to run so you can review:
show wireless management trustpoint
show run | se ip http
-Scott
Thank you for the quick and clear reply Scott, I will check this next time onsite at customer and reply if this solved my issues.
Colin
You should test this out in the lab also.  Especially if you are using the same trustpoint.  This way you can have a conversation with the customer on the risk and the next steps.
-Scott
stefan.tabell
Level 2
Level 2
I had the same error and solved it by rebooting WLC. For me the WLC was still in the setup phase so no active clients to consider.
MauricioSantana23168
Frequent Visitor
Frequent Visitor
Try the following:
show run | inc crypto
>>> Find trustpoint named TP-Self-Signed-xxxxx
conf t
no crypto pki trustpoint TP-Self-Signed-xxxxxx
no ip http server
no ip http secure-server
ip http server
ip http authentication
end
conf t
ntp server 2.north-america.pool.ntp.org
ntp server 1.north-america.pool.ntp.org
ntp server 3.north-america.pool.ntp.org
clock timezone UTC -6
clock calendar-valid
crypto key generate rsa general-keys label RSACA modulus 2048
crypto pki server CA-WLAN
issuer-name cn=ca.wla.local
grant auto
no shutdown
Pass:<<password>>
REPass:<<password>>
crypto pki trustpoint TPEWLCCA
enrollment url http://<<ip_wlc>>:80
revocation-check none
subject-name cn=wlc.<<enterprise>>.net
rsakeypair RSACA
exit
crypto pki authenticate TPEWLCCA
yes
crypto pki enroll TPEWLCCA
Pass:R0u3#C1sc0
REPass:R0u3#C1sc0
no
no
yes
ip http secure-trustpoint TPEWLCCA
Example:
