Cisco ACS
Daniel Anderson
Currently building a L3 roaming Wireless LAN within a test environment. Currently have a Cisco ACS Appliance for AP authenication. Is it possible to integrate the Appliance into Active Directory in order provide PEAP authentication to the Laptop clients, or would I need to build a Windows server and install the Cisco ACS software onto the server?
d.beaver
Level 4
Level 4
Daniel,
I'm curious what the part number is on your appliance. Is it CSACSE-1112-K9? If so, they are same thing. The appliance should easily integrate with your AD. The appliance is nothing more than the ACS software running on a Linux box instead of a Windows 2003 server box.
