Cisco AIR-AP1242AG-A-K9 Vs AIR-LAP1131AG-N-K9 Which AP is best
Almas Saiyed
Dear All,
I am confused between AIR-AP1242AG-A-K9 and AIR-LAP1131AG-N-K9, we have WLC 4400 which supports both, which one will be the best.
and what are the adv. adn disadv. of both.
Almas...
Stephen Rodriguez
Almas,
     Depends on what you are looking to do.  Both are good for any standard deployment, i.e. office space, hallways.
The 1242 is a bit more flexible as it has external antenna that can be articulated.  So you can mount it on a wall, or on the ceiling.  The down side, is they will be visible.
The 1131 has built-in antenna, and is designed to be mounted horizontally, on a ceiling for example.
So depending on where you can mount, that will determine the type of AP you need to use
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Leo Laohoo
Depends on what you are using and what you want them for.
Like Steve's post, the 1130 has internal antenna and is designed to be "pleasing to the eye" when deployed in an office environment.  The 1240 is a WAP that requires optional external antennas.  It's designed in "challenging" places such as warehouse, theatres, etc.
Be warned that both the 1130 and 1240 are the 2nd generation of WAPs.  They will NOT support of 802.11n.  The cheapest 802.11n WAP is the 1040.
