Cisco AIR-AP1572EAC-A-K9
Hi everyone , i have some doubts with de LWAPP AIR-AP1572EAC-A-K9 , beacuse i have a WLC5508 with this description :
- WLC 5508
- software version 7.4.121.0
- Field Recovery Image Version 7.6.95.16
This ap is compatible with this WLC version ?
Bob Bagheri
Hi Jose,
No the version you are using does not support the 1572 AP's.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn74mr02.html#pgfId-1141935
Hope that helps.
Bob
Hi Bob , thanks for your answer
if i update the WLC to the last software, my older AP will it work ?
I have this AP:
- AIR-CAP1552E-A-K9
- AIR-LAP1524PS-A-K9
Best Regards
Jose,
keep this link handy. Everytime you upgrade code or purchase me equipment, this matrix will tell you what is supported and what isn't. This will help you identify future upgrades required with new equipment purchases.
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
-Scott
-Scott
Ok Scott , thank you
