Cisco AIR-AP1832I-B-K9 AP's failing with red residue
James_1
Just curious if anyone else is seeing this problem with the 1832I's. We've had about a dozen of these models with manufacture date 6-19 fail on us and all of them have red residue on the same spot on the underside vents.
8 Replies 8
Leo Laohoo
Contact your Cisco AM/SE and organize for an EFA.
Thanks Leo,
I've already been in contact with Cisco Support and setup an RMA. They've been great to work with.
marce1000
 - You  may want to attach a console , startup and check if anything useful is displayed.
 M.
Thanks Marce, But these AP's are dead and don't power up.
  - Is correct power (voltage) applied ?
 M.
Yup, I tried POE from the switch, POE from an injector, and a power adaptor with no luck.
So you are in the process of an RMA?
-Scott
Hey Scott,
Yup' i've already been in contact with support and gone through the RMA process. I've got the failed ones boxed up and ready to ship back.
