Cisco AIR-AP521 Access Point Disconnects Frequently
shaikhugee
Dear All,
I have a problem in my environment. My Cisco Access Point AIR-AP521 disconnets every few days and I have to restart the access point to make it work. The System Software Version is 12.4(21a)JA1 and it is acting as a access point. The lastest event logs does not show any critical logs. I am sure that there is no electricity or switch related problem.
Please help me in fixing our this problem.
Tks,
Usman
Surendra BG
Upgrade the software to 12.4(21a)JY and see if the issue reoccurs!!
Surendra
Surendra BG
Thank you Surendra for the prompt reply. I will test this out.
