cisco AIR-CAP3502I-A-K9
INEM
Hello guys,
One question, I want to know which country code I must choose to register my AP cisco AIR-CAP3502I-A-K9  on the WLC?
The controller was set up to use the following country code:
But the AP cannot register.
Can someone help me with that?
thanks in advance,
Console into the AP and reboot the AP.
This is a vWLC, right?  Was the EULA accepted?
How many AP license have been enabled?
7 Replies 7
Leo Laohoo
Post the complete output to the following commands:
  1. WLC:  sh sysinfo
  2. WLC:  sh time
  3. AP:  sh version
  4. AP:  sh ip interface brief
Hi Leo,
Ok, please see the output of the commands below:
(Cisco Controller) >show time
Time............................................. Sat Apr 17 08:03:54 2021
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
NTP Version.................................. 3
NTP Polling Interval......................... 600
Index NTP Key Index NTP Server Status NTP Msg Auth Status
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.171.0
RTOS Version..................................... 8.5.171.0
Bootloader Version............................... 8.5.1.85
Emergency Image Version.......................... 8.5.171.0
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... Cisco_b7:b0:01
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 150.1.7.211
IPv6 Address..................................... ::
System Up Time................................... 0 days 0 hrs 5 mins 15 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US - United States
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Memory Current Usage............................. 15
Memory Average Usage............................. 17
CPU Current Usage................................ 0
CPU Average Usage................................ 0
Flash Type....................................... Compact Flash Card
Flash Size....................................... 1073741824
Burned-in MAC Address............................ 0C:FA:D2:B7:B0:01
Maximum number of APs supported.................. 200
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
Licensing Type................................... RTU
vWLC config...................................... Small
APf0f7.5539.6629#sh version
Cisco IOS Software, C3500 Software (AP3G1-RCVK9W8-M), Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 18-Oct-11 15:02 by prod_rel_team
ROM: Bootstrap program is C3500 boot loader
BOOTLDR: C3500 Boot Loader (AP3G1-BOOT-M) Version 12.4(23c)JA, RELEASE SOFTWARE (fc3)
APf0f7.5539.6629 uptime is 13 minutes
System image file is "flash:/ap3g1-rcvk9w8-mx/ap3g1-rcvk9w8-mx"
cisco AIR-CAP3502I-A-K9 (PowerPC460exr) processor (revision A0) with 81910K/49152K bytes of memory.
Processor board ID FGL1604S24B
PowerPC460exr CPU at 666Mhz, revision number 0x18A8
Last reset from power-on
LWAPP image version 7.0.112.74
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: F0:F7:55:39:66:29
Part Number : -------
PCA Assembly Number : 800-------05
PCA Revision Number : A0
PCB Serial Number : ---------------
Top Assembly Part Number : 800--------01
Top Assembly Serial Number : ------------
Top Revision Number : A0
Product/Model Number : AIR-CAP3502I-A-K9
Configuration register is 0xF
APf0f7.5539.6629#sh ip interface brief
GigabitEthernet0 150.1.7.102 YES DHCP up up
Also I perform a dump and I saw that something is wrong related to Malformed Packets and Certificates, see below:
Anyone have some idea what is going on?
thanks in advance,
Best Regards
Two things:
  • WLC is not configured with NTP.  Configure it because APs will not join WLC if time-and-date are incorrect.
  • RCV image is very old.  I suspect the certificate inside the image have already expired.  Upload the latest RCV image to the AP.
I upgrade the image and set up the NTP, the problem persist.
From Dasboard of WLC:
Any ideia to solve the issue?
Thanks in advance,
Best Regards
Yes, This is a vWLC. No, I miss this part : )
Have been enabled 200 Licenses.
Problem solved, thanks a lot Leo.
marce1000
 - Country codes are described here : https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
           Normally however you acquire AP-models according to the country they are destined for (not the reverse).
 M.
