12-18-2023 04:15 AM
I know that this device is EoL already. Unfortunately, I just assigned to support with new customer using WLC 8510 with version 8.5.182.7.
Anyone used to faced the ping loss behavior? As I got the message, no configuring changes, but just a reboot by itself. There are many WLCs connected uplink to the same switch. Layer 1 is working fine, no CRC, no transceiver issue, other WLC not faced this issue(same network, same configuration). Please help
12-18-2023 08:12 AM
- Check the logs on WLC5 and or configure a syslog server on it , (follow up on logging) ; you may try another port on the particular switch too ,
M.
12-18-2023 08:22 AM
So this happened after a reboot? Were the configs saved before the reboot? Reboot it again and ping the address to make sure there is no other device using that same address. Other than that, check out what @Mark Elsen posted also.
12-18-2023 03:06 PM
Never seen that before. We still have some 8510's which we plan to turn off within the next few months.
Also upgrade to 8.5.182.11 (link below) just to make sure you have all the latest bug fixes. Did you check the interface stats on both sides - WLC & switch?
That kind of problem can sometimes also indicate a failing SFP so you could try replacing SFPs on both sides.
12-19-2023 04:42 AM
Thank you. I have not heard about 8.5.182.11 before. I will try with this version. I am 100% sure there is no layer 1 issue and also try on new switch's interfaces.
