I received new air-sap1602i-e-k9 access points and found out when configuring WDS that infrastructure authentication is using nowdays PEAP. Now our infarstructure authenticaton will fail for local certificate check from ACS 5.2. Does somebody know how to turn it back to LEAP or disable the server certificate check? Or is there some other things that I should change?
Deploying certificates to almost thousand access point for WDS is not an easy solution for me. Accesspoints runnign 12.x images e.g. 1242 are working fine with LEAP.
Thaks in advance.
