Cisco AIR-SAP2602I-A-K9 won't connect to 2504 WLC, any suggestions?
acapistran96
I've been trying to rack my mind about what is going on with this AP. If it helps any I'll describe my setup.
I have a UDM-PRO router with a link to a 2960-S Cisco switch. The port on UDM-Pro is setup as a Full Trunk port. The port on the 2960-S is setup with switchport mode trunk and thats it.
 both the WLC and the AP are setup as switchport mode trunk ports.
I have two VLANs. I'm using the native vlan as the LAN network with a default 192.168.1.0/24 subnet with DHCP giving out addresses from 2-200. and another vlan for a Camera network. I can't imagine that being a problem though.
Maybe its a firewall issue?
Here's what I have for the rules on my UDM-Pro. Is there something I'm missing?
Any advice would be appreciated. I've been trying to troubleshoot with time as well but still no luck.
 RULE INDEXENABLEDDESCRIPTIONACTIONCOUNTTYPE
3001
allow established/related sessions
Accept
All
Internet In
3002
drop invalid state
Drop
All
Internet In
3001
Accept
All
Internet Local
3002
drop invalid state
Drop
All
Internet Local
3005
allow IPSec ISAKMP, NAT-T
Accept
UDP
Internet Local
3006
allow ESP
Accept
ESP
Internet Local
3007
allow L2TP over IPSec
Accept
UDP
Internet Local
6001
accounting defined network 192.168.5.0/24
Accept
All
LAN In
6002
accounting defined network 192.168.15.0/24
Accept
All
LAN In
6003
accounting defined network 192.168.1.0/24
Accept
All
LAN In
6004
accounting defined network 192.168.20.0/28
Accept
All
LAN In
6001
Accept
All
LAN Out
6002
Accept
All
LAN Out
6003
Accept
All
LAN Out
6004
Accept
All
LAN Out
3003
Accept
All
Internet v6 In
3004
drop invalid state
Drop
All
Internet v6 In
3003
Accept
All
Internet v6 Local
3004
drop invalid state
Drop
All
Internet v6 Local
3008
Allow neighbor solicitation
Accept
IPv6-ICMP
Internet v6 Local
3009
Allow neighbor advertisements
Accept
IPv6-ICMP
Internet v6 Local
6005
allow packets to corporate networks
Accept
All
LAN v6 Out
Translating "CISCO-CAPWAP-CONTROLLER.localdomain"...domain server (192.168.1.1)
Not in Bound state.
*Jan 14 12:29:54.251: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Jan 14 12:29:57.327: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.1.165, mask 255.255.255.0, hostname APbc16.65ff.79f2
Here's the info I pulled from the WLC and the AP
WLC:
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.110.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
Build Type....................................... DATA + WPS
System Name...................................... CapistranWLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.1.215
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 0 days 0 hrs 7 mins 23 secs
System Timezone Location......................... (GMT -5:00) Eastern Time (US and Canada)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... US - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +30 C
External Temperature............................. +33 C
Fan Status....................................... 3500 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ DC:EB:94:94:CE:00
Maximum number of APs supported.................. 75
System Nas-Id.................................... CapistranWLC
WLC MIC Certificate Types........................ SHA1/SHA2
(Cisco Controller) show>time
Time............................................. Thu Jan 13 19:41:07 2022
Timezone delta................................... 0:0
Timezone location................................ (GMT -5:00) Eastern Time (US and Canada)
NTP Servers
NTP Polling Interval......................... 3600
Index NTP Key Index NTP Server NTP Msg Auth Status
1 0 192.168.1.1 AUTH DISABLED
(Cisco Controller) show>sh license
Incorrect usage. Use the '?' or <TAB> key to list commands.
(Cisco Controller) show>license
(Cisco Controller) show>li?
license linktest
802.11a Display 802.11a configuration.
802.11b Display 802.11b configuration.
802.11h Display 802.11h configuration.
aaa Displays AAA related information
acl Display system Access Control Lists.
advanced Display Advanced configuration and statistics.
ap Display AP Configuration.
arp Display ARP cache.
assisted-roaming Display Assisted Roaming and 802.11k configuration.
auth-list Display AP authorization list.
avc Display AVC Configuration/Statistics.
band-select Display Aggressive Load Balancing configuration.
boot Displays the default boot image.
buffers Display pmalloc buffer utilization.
cac Show Call-Admission-Control details
call-control Display Call-control information
cdp Display CDP information
certificate Display SSL Certificate Configuration.
client Displays active clients.
coredump Displays Core Dump Summary
country Display the configured countries.
--More-- or (q)uit
(Cisco Controller) show>license ?
all Displays All The License(s).
capacity Displays License currently used by AP
detail Displays Details Of A Given License.
evaluation Displays Evaluation License(s).
expiring Displays Expiring License(s).
feature Displays License Enabled Features.
file Displays All The License File(s).
handle Displays License Handles.
image-level Display the image level
in-use Displays License That Are In-Use.
permanent Displays Permanent License(s).
statistics Displays License Statistics.
status Displays License Status.
summary Displays Brief Summary Of All License(s).
udi Displays UDI Values For Licenses.
(Cisco Controller) show>license all
License Store: Primary License Storage
StoreIndex: 0 Feature: base Version: 1.0
License Type: Permanent
License State: Active, Not in Use
License Count: Non-Counted
License Priority: Medium
License Store: Evaluation License Storage
StoreIndex: 0 Feature: base-ap-count Version: 1.0
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
Evaluation total period: 12 weeks 6 days
Evaluation period left: 12 weeks 6 days
License Count: 75 / 0 (Active/In-use)
License Priority: None
AP:
Cisco IOS Software, C3600 Software (AP3G2-K9W8-M), Version 15.3(3)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 19-Dec-14 11:20 by prod_rel_team
ROM: Bootstrap program is C3600 boot loader
BOOTLDR: C3600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(25e)JAY, RELEASE SOFTWARE (fc1)
APbc16.65ff.79f2 uptime is 4 minutes
System image file is "flash:/ap3g2-k9w8-mx.153-3.JA1/ap3g2-k9w8-xx.153-3.JA1"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP2602I-A-K9 (PowerPC) processor (revision A0) with 188394K/60928K bytes of memory.
Processor board ID FTX1721J0F5
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.0.110.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: BC:16:65:FF:79:F2
Part Number : 73-14588-02
PCA Assembly Number : 800-37899-01
PCA Revision Number : A0
PCB Serial Number : FOC17175LAA
Top Assembly Part Number : 800-38356-01
Top Assembly Serial Number : FTX1721J0F5
Top Revision Number : A0
Product/Model Number : AIR-SAP2602I-A-K9
Configuration register is 0xF
APbc16.65ff.79f2#sh ip interface brief
BVI1 192.168.1.165 YES DHCP up up
Dot11Radio0 unassigned NO unset up up
Dot11Radio1 unassigned NO unset up up
GigabitEthernet0 unassigned NO unset up up
Virtual-WLAN0 unassigned NO unset up up
Virtual-WLAN0.1 unassigned NO unset up up
Virtual-WLAN0.2 unassigned NO unset up up
Virtual-WLAN0.3 unassigned NO unset up up
Virtual-WLAN0.4 unassigned NO unset up up
Virtual-WLAN0.5 unassigned NO unset up up
Virtual-WLAN0.6 unassigned NO unset up up
Virtual-WLAN0.7 unassigned NO unset up up
Virtual-WLAN0.8 unassigned NO unset up up
Virtual-WLAN0.9 unassigned NO unset up up
Virtual-WLAN0.10 unassigned NO unset up up
Virtual-WLAN0.11 unassigned NO unset up up
Virtual-WLAN0.12 unassigned NO unset up up
Virtual-WLAN0.13 unassigned NO unset up up
Virtual-WLAN0.14 unassigned NO unset up up
Virtual-WLAN0.15 unassigned NO unset up up
Virtual-WLAN0.16 unassigned NO unset up up
APbc16.65ff.79f2#
Not in Bound state.sh capwap
*Jan 14 12:28:57.751: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
APbc16.65ff.79f2#sh capwap
*Jan 14 12:29:00.827: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.1.165, mask 255.255.255.0, hostname APbc16.65ff.79f2
clien
APbc16.65ff.79f2#sh capwap client rcb
AdminState : ADMIN_ENABLED
SwVer : 8.0.110.0
NumFilledSlots : 2
MwarName :
MwarMacAddr : ff01.0000.0000
MwarHwVer : 0.0.0.0
ApMode : Local
ApSubMode : Not Configured
OperationState : DISCOVERY
CAPWAP Path MTU : 1485
Link-Encryption (AP) : Disabled
Link-Encryption (MWAR) : Disabled
Prefer-mode : Un-configured
LinkAuditing : disabled
AP Rogue Detection Mode : Enabled
AP Tcp MSS Adjust : Disabled
Predownload Status : None
Auto Immune Status : Disabled
RA Guard Status : Disabled
Efficient Upgrade State : Disabled
Efficient Upgrade Role : None
TFTP Server : Disabled
Antenna Band Mode : Unknown
802.11bg(0) Radio
ADMIN State = ENABLE [1]
OPER State = DOWN [1]
CONFIG State = UP [2]
HW State = UP [4]
Radio Mode : Local
GPR Period : 0
Beacon Period : 0
DTIM Period : 0
World Mode : 1
VoceraFix : 0
Dfs peakdetect : 1
Fragmentation Threshold : 0
Current Tx Power Level : 0
Current Channel : 0
Current Bandwidth : 20
802.11a(1) Radio
HW State = UP [4]
Radio Mode : Local
GPR Period : 0
Beacon Period : 0
DTIM Period : 0
World Mode : 1
VoceraFix : 0
Dfs peakdetect : 1
Current Channel : 0
APbc16.65ff.79f2#
acapistran96
I just wanted to update this post because I found the solution on my own. Turns out I didn't have a license on the 2504 installed. Once the licenses were installed for up to 25 max, the AP's were able to join. I also found out that having the incorrect time on your WLC can also mess up AP's attempting to connect to the controller. finally, the only other issue I had with one of the 2602s was I believe to be bad NVRAM. The only reason i say that is because this particular AP would lose the config on reboot and had to be reconfigured everytime it joined the controller. Thank you all who tried to help me though. Sorry I was so late in replying
6 Replies 6
Leo Laohoo
Enter the following command into the AP:
capwap ap primary-base CapistranWLC 192.168.1.215
I entered the command but nothing changed. Still trying to translate.
Rich R
Have you had a slow, thorough read and re-read through https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html and then followed all the steps in the right order?
For starters that AireOS should be updated to the latest available release which is compatible with all your APs.
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
Assuming 2504 WLC and 2600 AP then I'd suggest 8.5.182.0
acapistran96
Cisco APs actually emulate NVRAM and the config is stored on flash.
There's a field notice about the problems with flash on IOS APs:
https://www.cisco.com/c/en/us/support/docs/field-notices/703/fn70330.html
Note these problems are fixed in the latest releases of software.
thank you for the resource!
