ā12-06-2015 10:52 AM - edited ā07-05-2021 04:20 AM
Will the WLC4402-12-K9 work with the AIR-LAP1042N-A-K9 and Catalyst WS-C2950G-48-El?
WLC4402 -> FastEthernet0/5 (Catalyst 2950) -> AIR-LAP1042N-A-K9 (Plugged into FastEthernet0/6 on the Catalyst 2950)
Solved! Go to Solution.
ā12-06-2015 12:05 PM
The 2950 is a NON-PoE model so the AP will need either a power injector (PWR-INJ4) or a power supply.
Depends on the firmware of the controller. Due to security vulnerabilities, I recommend the WLC to run the final 7.0.X firmware and should be able to support the 1042.
