Cisco AIR3602 - continual reboots
I had setup in a test lab a autonomous AIR3602i, running the code version "ap3-g2-k9w7-tar.153-3.J14,tar" - Been fine for about 3 months. Today, one started rebooting continuously - okay, so I had another, powered it up, had a base configuration on, but okay all good. So I configured it as per the first. Just finished, rebooted to test, and that has now started rebooting continuously. Now I'm confused, because I have a third which runs a 'production' network, and that has a different configuration, but works fine!
Anyone seen this behavior before? The two that reboot I can't escape character in to do any diagnostics.continuous reboot, Aironet Access Points
17 Replies 17
That would work. Keep in mind that downloading the image might be an issue unless you have a support contract. So hopefully the 5508 you have had a good compatible image.
-Scott
The contents of the flash do not show any signs of crashlogs or coredump.
How, exactly, is the AP powered?  PoE?  Injector?  Power brick?
