Cisco Airnot 2802i-D-K9 is come with Mobility Express enable or not?
subburevat
hi all
we have a query that is cisco airnot 2802i-D-K9 comes with mobility express or we need to upgrade the OS in that?
5 Replies 5
Sandeep Choudhary
console and found it!!!
To determine if your AP has a Cisco Mobility Express image or CAPWAP Lightweight AP image, Check this link:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/1/user_guide/b_ME_User_Guide/getg_start.html
Dont forget to rate helpful posts
ours is CAPWAP. It will work on the Mobilty Software?
yes it will.
info: On 2800 and 3800 series Access Points, Mobility Express is supported starting Release 8.3.102.0 so they must have 8.3.102.0 CAPWAP image before they can be converted to Mobility Express. If the CAPWAP image on the Access Point is prior to 8.3.102.0, Access Point MUST first join a WLC running 8.3.102.0 or higher to upgrade its CAPWAP image. After the CAPWAP image of the AP has been upgraded, conversion of AP from CAPWAP to Mobility Express can be performed.
Check link to convert:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_Cisco_Mobility_Express_Deployment_Guide/b_Cisco_Mobility_Express_Deployment_Guide_chapter_010.html
Thanks for your valuable reply..
If you are satisfied with reply then plz also mark it as answered. It may help others.
