Cisco Aironet 1042 AP Authentication using existing RADIUS server
johnbouman
I have two Cisco Aironet 1042 AP that are set up to use a WPA2 key, (which is 32 characters and hard to type and not easy to remember), to connect to them. I have a RADIUS Server running on a Windows 2008 server that I would like to use for authentication instead. Can someone help me with this? Thanking you in advance for your assistance.
Rasika Nayanajith
You should be able to find how to configure your AP using below post.  I have used ACS5.2 as RADIUS, you may need to configure windows server accordingly
http://mrncciew.com/2013/11/14/autonomous-ap-with-external-radius/
Rasika
*** Pls rate all useful responses ***
