Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco Aironet 1141 5GHz Issues
Kirk Mellors
Hi there,
I was configuring my Aironet 1141 on IOS version 15.2(4)JB5 and , as I understand, thought that the 1141 had a 5GHz antenna but I have no option for enabling the radio and has "undefined Status". Attached is a screenshot of the problem.
I hope you can help!
Kirk
5 Replies 5
Juan IbaƱez
Hi Kirk,
Check if the AP haves .img files in the flash:/ directory. the AP was lightweight mode or you upgrade this before?
I don't think there are any .img files in the directory. Yes the AP was in lightweight mode and I have upgraded it to autonomous.
Kirk
Did you use the "Mode" button or did you just copy the BIN file?
I used the Mode button.
Kirk
Console into the AP and reboot.
Post the entire boot-up process.
