Cisco Aironet 1815i Access Point Reset and CAPWAP to Mobility Express
iamNaveed
Hi all,
How can i reset AP 1815i. I tried to press mode button then connect PoE cable and hole mode for 25 second, but still.
Hit ESC key to stop autoboot: 0
I pressed Escape button but not going to config mode. Below are the complete list:
Board type: AP1815I
smem ram ptable found: ver: 1 len: 3
U-Boot 2012.07 (btldr release 36) (Oct 13 2017 - 10:35:07)
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
DRAM: 1022 MiB
Nand: Detected ONFI Macronix NAND 256MiB 3,3V 8-bit
NAND ECC=4 ECC_THRESHOLD(NAND ECC-1)=3
SF: Detected MX25L3205D with page size 4 KiB, total 4 MiB
MFG data loaded
Scanning shenv data blocks
Total valid parts=4
Active shenv part[1:0], write_counter=27
machid: 8010001
Net: MAC0 addr:6c:8d:77:60:20:e8
AR8033 PHY 0
PHY ID1: 0x4d
PHY ID2: 0xd072
ipq40xx_ess_sw_init done
Button is pressed. Configuration reset activated..
Keep the button pressed for > 20 seconds for full reset
Wait for the button to be released ....
Button pressed for 24 seconds
Setting env for configuration reset..
Writing to Nand... done
Manual boot mode, use bootcmd
Specified BOOT: part2
Booting from part2
Read 1024 bytes from volume part2 to 88000000
Read 22043835 bytes from volume part2 to 88000000
Signature returns 0
Image signing verification success, continue to run...
bootm 0x88000400
## Booting kernel from Legacy Image at 88000400 ...
## Loading init Ramdisk from multi component Legacy Image at 88000400 ...
## Flattened Device Tree from multi component Image at 88000400
Booting using the fdt at 0x894fc874
Loading Ramdisk to 9eccd000, end 9ffffd22 ... OK
Loading Device Tree to 9ecc1000, end 9ecccc46 ... OK
no such device nand0
Using machid 0x8010001 from environment
Starting image ...
[01/01/1970 00:00:22.0799] Linux version 3.14.43 (vipendya@cheetah-build4) (gcc version 4.7.1 (OpenWrt GCC 4.7.1 r48430) ) #1 SMP PREEMPT Sat Nov 24 21:55:06 PST 2018
[01/01/1970 00:00:22.2499] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[01/01/1970 00:00:22.3399] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[01/01/1970 00:00:22.4399] Machine model: Cisco 11ac Wave2 Wifi Access Point
[01/01/1970 00:00:22.5199] Memory policy: Data cache writealloc
[01/01/1970 00:00:22.5899] Kernel command line: console=ttyMSM0,9600n8 ubi.mtd=0 root=/dev/ram activepart=part2 activeboot=0 wdgtriggered=0 board_sku=1 clk_ignore_unused
[01/01/1970 00:00:22.7699] CPU1: Booted secondary processor
[01/01/1970 00:00:22.8299] CPU2: Booted secondary processor
[01/01/1970 00:00:22.8999] CPU3: Booted secondary processor
[01/01/1970 00:00:22.9599] buginf tty flushing thread started, ttyport=be933400
[*01/01/1970 00:00:26.2499] buginf() enabled.
[*01/01/1970 00:00:26.2799] Made it into bootsh: Nov 24 2018 22:00:55
[*01/01/1970 00:00:26.2899] bootsh build T-b1c4d316cf409bad6ec9cbf2958c6014776e95f2-gb1c4d316-vipendya
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
Factory configuration reset detected...
Config Factory Reset triggered: clear saved config files..
error: open /dev/board-config
init started: BusyBox v1.23.2 (2018-11-24 21:44:42 PST)
[*01/01/1970 00:00:29.9899] GCM-128 POST passed
[*01/01/1970 00:00:29.9899] GCM-256 POST passed
[*01/01/1970 00:00:30.1299] === 5G radio domain is 12, COPY 5G BDF files from ETSI_BDF folder ===
[*01/01/1970 00:00:30.1799] 0
[*01/01/1970 00:00:30.3699] Active version: 8.5.140.0
[*01/01/1970 00:00:30.3799] Backup version: 0.0.0.0
[*01/01/1970 00:00:30.7799]
[*01/01/1970 00:00:30.7799] led pattern module start
[*01/01/1970 00:00:30.8199] Loading caldata from mtd2
Jan 1 00:00:31 FIPS[2906]: *** shell: FIPS Mode = disabled ***
User Access Verification
Username: [*01/01/1970 00:00:31.2499] ess-switch DT exist!
[*01/01/1970 00:00:31.2499] switchreg_base_addr: 0xc000000
[*01/01/1970 00:00:31.2499] switchreg_size: 0x80000
[*01/01/1970 00:00:31.2499] switch_access_mode: local bus
[*01/01/1970 00:00:31.2499] wan bmp:0x20
[*01/01/1970 00:00:31.2499] ess-psgmii DT exist!
[*01/01/1970 00:00:31.2499] mac mode=3
[*01/01/1970 00:00:31.2499] current mac mode = 3
[*01/01/1970 00:00:31.2499] current dts led_source_num is 5
[*01/01/1970 00:00:31.2499] mdio DT exist!
[*01/01/1970 00:00:31.2499] ssdk_plat_init start
[*01/01/1970 00:00:31.2499] enable ess clk
[*01/01/1970 00:00:31.3599] reset ok in probe!
[*01/01/1970 00:00:31.3599] PHY ID is 0x4dd072
[*01/01/1970 00:00:31.4199] Dakota Chip version 0x1401
[*01/01/1970 00:00:31.4199] QCA Switch config done.
[*01/01/1970 00:00:31.4299] gcc map success!
[*01/01/1970 00:00:31.4799] qca-ssdk module init succeeded!
[*01/01/1970 00:00:31.4799] QCA Switch config done.
[*01/01/1970 00:00:31.6699] crypto worker thread started
[*01/01/1970 00:00:31.6799] crypto worker thread started
[*01/01/1970 00:00:31.7399] pid 3175's current affinity mask: f
[*01/01/1970 00:00:31.7399] pid 3175's new affinity mask: e
[*01/01/1970 00:00:31.7399] pid 3174's current affinity mask: f
[*01/01/1970 00:00:31.7399] pid 3174's new affinity mask: e
[*01/01/1970 00:00:31.9699] Current value of FACTORY_RESET=0
[*07/06/2022 23:59:59.0199] Last reload time: Jul 16 08:46:31 2022
[*07/16/2022 08:46:31.0000] Setting system time Sat Jul 16 08:46:31 UTC 2022
[*07/16/2022 08:46:31.0999] device wired0 entered promiscuous mode
[*07/16/2022 08:46:31.2199] Creating default base capwap config.
[*07/16/2022 08:46:31.5999] stile module dp init successfully
[*07/16/2022 08:46:31.5999] NBAR Label:BLD_V155_3_S_XE316_THROTTLE_LATEST_20180404_162221 NBAR VERSION:module build date: Nov 24 2018 at 21:58:41
[*07/16/2022 08:46:31.9399] pid 3317's current affinity mask: f
[*07/16/2022 08:46:31.9399] pid 3317's new affinity mask: e
[*07/16/2022 08:46:31.9499] pid 3316's current affinity mask: f
[*07/16/2022 08:46:31.9499] pid 3316's new affinity mask: e
[*07/16/2022 08:46:31.9499] pid 3315's current affinity mask: f
[*07/16/2022 08:46:31.9499] pid 3315's new affinity mask: e
[*07/16/2022 08:46:32.6399]
[*07/16/2022 08:46:32.6599] boot 8 build T-b1c4d316cf409bad6ec9cbf2958c6014776e95f2-gb1c4d316-vipendya board mallorca mac 6C:8D:77:60:20:E8
[*07/16/2022 08:46:32.6699] Module: mbedtls .text=0x7f000000 data=0x7f0075e0 bss=0x7f007840
[*07/16/2022 08:46:32.6699] Module: aptrace .text=0x7f00c000 data=0x7f017fb0 bss=0x7f018498
[*07/16/2022 08:46:32.6699] Module: led_module .text=0x7f020000 data=0x7f020594 bss=0x7f020c04
[*07/16/2022 08:46:32.6699] Module: qca_ssdk .text=0x7f024000 data=0x7f0ba100 bss=0x7f0bfba4
[*07/16/2022 08:46:32.6699] Module: essedma .text=0x7f111000 data=0x7f117984 bss=0x7f117e18
[*07/16/2022 08:46:32.6699] Module: crypto_netdev .text=0x7f11f000 data=0x7f121ec0 bss=0x7f122120
[*07/16/2022 08:46:32.6699] Module: proclikefs .text=0x7f12b000 data= bss=0x7f12bb80
[*07/16/2022 08:46:32.6699] Module: stile_lm_ft .text= data= bss=
[*07/16/2022 08:46:32.6699] Module: stile_lm_dp .text= data= bss=
[*07/16/2022 08:46:32.6699] Module: ipv6 .text=0x7fc72000 data=0x7fcab200 bss=0x7fcac800
[*07/16/2022 08:46:32.6699] Module: llc .text=0x7fcd3000 data=0x7fcd3850 bss=0x7fcd39dc
[*07/16/2022 08:46:32.6699] Module: stp .text=0x7fcd8000 data=0x7fcd8280 bss=0x7fcd842c
[*07/16/2022 08:46:32.6699] Module: act2_driver .text=0x7fcdc000 data=0x7fcdc76c bss=0x7fcdc9f0
[*07/16/2022 08:46:32.6699] Module: bridge .text=0x7fce0000 data=0x7fce8adc bss=0x7fce8f1c
[*07/16/2022 08:46:32.6699] Module: p8022 .text=0x7fcf6000 data= bss=
[*07/16/2022 08:46:32.6699] Module: psnap .text=0x7fcfa000 data=0x7fcfa348 bss=0x7fcfa4b8
[*07/16/2022 08:46:32.6699] Module: reed_solomon .text=0x7fcfe000 data=0x7fcff404 bss=
[*07/16/2022 08:46:33.3099] Last reload reason : 0: unknown
[*07/16/2022 08:46:35.6099] __mm_init_module
[*07/16/2022 08:46:35.6899] ol_ath_ahb_probe
[*07/16/2022 08:46:35.6899] ol_ath_ahb_probe: io resource start: 0xa000000, mem=0xc2800000
[*07/16/2022 08:46:35.6899] __ol_ath_attach() Allocated scn b81404c0
[*07/16/2022 08:46:35.6899] ol_ath_ahb_configure: MSI addr: 0b006040, MSI base: 00000040
[*07/16/2022 08:46:35.6999]
[*07/16/2022 08:46:35.6999] ol_ath_ahb_configure : num_desired MSI set to 0
[*07/16/2022 08:46:35.6999] Using Legacy Interrupt
[*07/16/2022 08:46:35.6999] Waiting for target init
[*07/16/2022 08:46:35.6999] Done waiting
[*07/16/2022 08:46:35.6999] ol_ath_attach interface_id 0
[*07/16/2022 08:46:35.6999] Chip id: 0xb, chip version: 0x1000000
[*07/16/2022 08:46:35.6999] Target Version is 1000000
[*07/16/2022 08:46:35.6999] Flash Download Address c0000
[*07/16/2022 08:46:35.6999] ol_transfer_bin_file: flash data file defined
[*07/16/2022 08:46:35.6999] ol_transfer_bin_file[3918] Get Caldata for wifi0.
[*07/16/2022 08:46:35.6999] __adf_os_fs_read[42], Open File /tmp/wifi0.caldata SUCCESS!!
[*07/16/2022 08:46:35.6999] file system magic:16914836
[*07/16/2022 08:46:35.6999] super blocksize:4096
[*07/16/2022 08:46:35.6999] inode 1356
[*07/16/2022 08:46:35.6999] file size:12064
[*07/16/2022 08:46:35.6999] qc98xx_verify_checksum: flash checksum passed: 0x6a58
[*07/16/2022 08:46:35.6999] ol_transfer_bin_file 3979: Download Flash data len 12064
[*07/16/2022 08:46:35.7199]
[*07/16/2022 08:46:35.7199] Board data initialized
[*07/16/2022 08:46:35.7199] Firmware loaded from user helper succesfully
[*07/16/2022 08:46:35.7399] ol_ath_download_firmware :First OTP download and Execute is good address:0x5800 return param 4660
[*07/16/2022 08:46:35.7399] ol_ath_download_firmware:##Board Id 22 , CHIP Id 0
[*07/16/2022 08:46:35.7399] wifi0: Selecting board data file name boardData_Mallorca_EAP_2G_neg_pwr.bin
[*07/16/2022 08:46:35.7399] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=IPQ4019/hw.1/boardData_Mallorca_EAP_2G_neg_pwr.bin
[*07/16/2022 08:46:35.7399] Firmware loaded from user helper succesfully
[*07/16/2022 08:46:35.7599] Firmware loaded from user helper succesfully
[*07/16/2022 08:46:35.7799]
[*07/16/2022 08:46:35.7799] [Flash] : Ignore Module param
[*07/16/2022 08:46:35.7799] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*07/16/2022 08:46:35.7799] Firmware loaded from user helper succesfully
[*07/16/2022 08:46:35.7899] ol_transfer_bin_file: Downloading firmware file: IPQ4019/hw.1/athwlan.bin
[*07/16/2022 08:46:35.7899] Firmware loaded from user helper succesfully
[*07/16/2022 08:46:37.0199] HTC Rx: insufficient length, got:4 expected =8
[*07/16/2022 08:46:37.0199] Startup Mode-0 set
[*07/16/2022 08:46:37.0199] HTC Service:0x0300 ep:1 TX flow control disabled
[*07/16/2022 08:46:37.0199] HTC Service:0x0100 ep:2 TX flow control disabled
[*07/16/2022 08:46:37.0199] Firmware_Build_Number:70
[*07/16/2022 08:46:37.0199] num_rf_chain:0x00000002 ht_cap_info:0x0000085b vht_cap_info:0x339959b2 vht_supp_mcs:0x0000fffa
[*07/16/2022 08:46:37.0199] RES CFG Support wmi_service_bitmap 9778
[*07/16/2022 08:46:37.0199] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 50 to TGT
[*07/16/2022 08:46:37.0299] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
[*07/16/2022 08:46:37.0299] ol_ath_service_ready_event[4238] WAPI MBSSID 0
[*07/16/2022 08:46:37.0699] wmi_ready_event_rx: WMI UNIFIED READY event
[*07/16/2022 08:46:37.0699] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 0
[*07/16/2022 08:46:37.0699] ACS not enabled
[*07/16/2022 08:46:37.0799] ol_ath_thermal_mitigation_attach: --
[*07/16/2022 08:46:37.0799] ol_ath_ahb_probe
[*07/16/2022 08:46:37.0799] ol_ath_ahb_probe: io resource start: 0xa800000, mem=0xc3000000
[*07/16/2022 08:46:37.0799] __ol_ath_attach() Allocated scn b8cc04c0
[*07/16/2022 08:46:37.0799] ol_ath_ahb_configure: MSI addr: 0b006040, MSI base: 00000050
[*07/16/2022 08:46:37.0999]
[*07/16/2022 08:46:37.0999] ol_ath_ahb_configure : num_desired MSI set to 0
[*07/16/2022 08:46:37.0999] Using Legacy Interrupt
[*07/16/2022 08:46:37.0999] Waiting for target init
[*07/16/2022 08:46:37.0999] Done waiting
[*07/16/2022 08:46:37.0999] ol_ath_attach interface_id 1
[*07/16/2022 08:46:37.0999] Chip id: 0xb, chip version: 0x1000000
[*07/16/2022 08:46:37.0999] Target Version is 1000000
[*07/16/2022 08:46:37.0999] Flash Download Address c0000
[*07/16/2022 08:46:37.0999] ol_transfer_bin_file: flash data file defined
[*07/16/2022 08:46:37.0999] ol_transfer_bin_file[3918] Get Caldata for wifi1.
[*07/16/2022 08:46:37.0999] __adf_os_fs_read[42], Open File /tmp/wifi1.caldata SUCCESS!!
[*07/16/2022 08:46:37.0999] file system magic:16914836
[*07/16/2022 08:46:37.0999] super blocksize:4096
[*07/16/2022 08:46:37.0999] inode 1357
[*07/16/2022 08:46:37.0999] file size:12064
[*07/16/2022 08:46:37.0999] qc98xx_verify_checksum: flash checksum passed: 0xe1e7
[*07/16/2022 08:46:37.0999] ol_transfer_bin_file 3979: Download Flash data len 12064
[*07/16/2022 08:46:37.1299]
[*07/16/2022 08:46:37.1299] Board data initialized
[*07/16/2022 08:46:37.1299] Firmware loaded from user helper succesfully
[*07/16/2022 08:46:37.1499] ol_ath_download_firmware :First OTP download and Execute is good address:0x5c00 return param 4660
[*07/16/2022 08:46:37.1499] ol_ath_download_firmware:##Board Id 23 , CHIP Id 0
[*07/16/2022 08:46:37.1499] wifi1: Selecting board data file name boardData_Mallorca_EAP_5G_neg_pwr.bin
[*07/16/2022 08:46:37.1499] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=IPQ4019/hw.1/boardData_Mallorca_EAP_5G_neg_pwr.bin
[*07/16/2022 08:46:37.1499] Firmware loaded from user helper succesfully
[*07/16/2022 08:46:37.1699] Firmware loaded from user helper succesfully
[*07/16/2022 08:46:37.1799]
[*07/16/2022 08:46:37.1799] [Flash] : Ignore Module param
[*07/16/2022 08:46:37.1799] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*07/16/2022 08:46:37.1799] Firmware loaded from user helper succesfully
[*07/16/2022 08:46:37.1899] Firmware loaded from user helper succesfully
[*07/16/2022 08:46:37.1899] ol_transfer_bin_file: Downloading firmware file: IPQ4019/hw.1/athwlan.bin
[*07/16/2022 08:46:37.1999] Firmware loaded from user helper succesfully
[*07/16/2022 08:46:38.0199] FWLOG: [77002] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/16/2022 08:46:38.0199] FWLOG: [77002] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/16/2022 08:46:38.0199] FWLOG: [77002] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/16/2022 08:46:38.0199] FWLOG: [77002] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/16/2022 08:46:38.4199] HTC Rx: insufficient length, got:4 expected =8
[*07/16/2022 08:46:38.4199] Startup Mode-0 set
[*07/16/2022 08:46:38.4199] HTC Service:0x0300 ep:1 TX flow control disabled
[*07/16/2022 08:46:38.4299] HTC Service:0x0100 ep:2 TX flow control disabled
[*07/16/2022 08:46:38.4299] Firmware_Build_Number:70
[*07/16/2022 08:46:38.4299] num_rf_chain:0x00000002 ht_cap_info:0x0000085b vht_cap_info:0x339959b2 vht_supp_mcs:0x0000fffa
[*07/16/2022 08:46:38.4299] RES CFG Support wmi_service_bitmap 9778
[*07/16/2022 08:46:38.4299] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 50 to TGT
[*07/16/2022 08:46:38.4299] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
[*07/16/2022 08:46:38.4299] ol_ath_service_ready_event[4238] WAPI MBSSID 0
[*07/16/2022 08:46:38.4699] wmi_ready_event_rx: WMI UNIFIED READY event
[*07/16/2022 08:46:38.4699] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 1
[*07/16/2022 08:46:38.4799] acfg_attach: Offload using existing sock bd71d400
[*07/16/2022 08:46:38.4799] ACS not enabled
[*07/16/2022 08:46:38.4799] ol_ath_thermal_mitigation_attach: --
[*07/16/2022 08:46:38.5499] pktlog_init: Initializing Pktlog for AR900B, pktlog_hdr_size = 16
[*07/16/2022 08:46:39.4199] FWLOG: [78440] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/16/2022 08:46:39.4199] FWLOG: [78440] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/16/2022 08:46:39.4199] FWLOG: [78440] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/16/2022 08:46:39.4199] FWLOG: [78440] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/16/2022 08:46:39.4199] FWLOG: [78450] UNKNOWN 22:55 ( 0x3a, 0x10, 0x0, 0x10, 0x0 )
[*07/16/2022 08:46:39.6499] pid 3655's current affinity mask: f
[*07/16/2022 08:46:39.6499] pid 3655's new affinity mask: e
[*07/16/2022 08:46:41.5199]
[*07/16/2022 08:46:41.5199] Click sched monitor: schedulers = 3
[*07/16/2022 08:46:42.4499] click-config/io-real.click:131: While configuring 'todev_wired0 :: ToDevice':
[*07/16/2022 08:46:42.4499] warning: device 'wired0' is down
[*07/16/2022 08:46:42.4899] click-config/io-real.click:131: While configuring 'fromdev_wired0 :: FromDevice':
[*07/16/2022 08:46:42.4899] warning: device 'wired0' is down
[*07/16/2022 08:46:43.3399] click-config/io-real.click:131: While initializing 'tohost_wired0 :: ToHost':
[*07/16/2022 08:46:43.3399] warning: device 'wired0' is down
[*07/16/2022 08:46:43.8299] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg40000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000
[*07/16/2022 08:46:45.5199] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[*07/16/2022 08:46:45.5399] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*07/16/2022 08:46:45.5499] ip6_port srcr6, ip6local fe80::6e8d:77ff:fe60:20e8, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 3(slaac)
[07/16/2022 08:46:50.5899] ess_edma c080000.edma: wired0: GMAC Link is up with phy_speed=100
[*07/16/2022 08:46:50.6699] IPv6: ADDRCONF(NETDEV_CHANGE): wired0: link becomes ready
[*07/16/2022 08:46:55.7099] Loading sha2...
[*07/16/2022 08:46:55.7099] Dumpping sha1...
[*07/16/2022 08:46:57.4599] Loading MIC cert and key
[*07/16/2022 08:46:57.4699] Dumpping sha2...
[*07/16/2022 08:46:59.2299] Loading MIC cert and key
[*07/16/2022 08:47:00.1599] Generating key, this may take a while...
[*07/16/2022 08:47:01.0699] Public key portion is:
[*07/16/2022 08:47:01.0699] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCnWwbkwLylIK3mw7wLquwkseC9+iAtLSFe9ZVHeFgNXQ9lL12iIG7HDt+ITKYzHeSuAyaG1LjCLq/W5andaRMzjdb16LgvTQ3UQXSsZJaY2qp0qhlrHwJRYueYRFLqGmJQroyNXWxypH9ToJeixais9+X1WyxKS4q5mrilmP1/z77xIs6Jjw08VDZfjr84POdC3GtvTtfxAQ7ey0lEz8+hm6ucACbJexSMO0HwWE47YXyc9nbVB+VaalGp2ut2PfdoVvhYobjn/o7a/wibwNPXeSELOCuaUp/o5ekONJwklUHAqsZwfgG7aF0ufEH28McqzerVITcUi/nHkDQ855J7 root@m6C8D776020E8
[*07/16/2022 08:47:01.0699] Fingerprint: sha1!! 83:5f:0d:83:8a:a7:c0:02:89:9a:e1:55:2d:ac:eb:d5:04:d3:29:62
[*07/16/2022 08:47:01.9999] pid 5346's current affinity mask: f
[*07/16/2022 08:47:01.9999] pid 5346's new affinity mask: e
[*07/16/2022 08:47:02.0099] setting interrupt 200 affinity to 1
[*07/16/2022 08:47:02.0299] setting interrupt 201 affinity to 1
[*07/16/2022 08:47:03.1099] Password for user changed
[*07/16/2022 08:47:03.2199] gzip -dc /etc/wcp.usermodule.template.gz | sed -e 's/__TX_POWER_2G_FILE__/\/radio_fw\/MI2.csv/g' -e 's/__TX_POWER_5G_FILE__/\/radio_fw\/MI5.csv/g' -e 's/__EVM_POWER_2G_FILE__/\/radio_fw\/EVM_2.csv/g' -e 's/__EVM_POWER_5G_FILE__/\/radio_fw\/EVM_5.csv/g' -e 's/__DOMAIN_2G__/1/g' -e 's/__DOMAIN_5G__/12/g' -e 's/__PWR_TABLE_49G__/0/g' -e 's/__PRODUCT_ID__/AIR-AP1815I-E-K9/g' -e 's/__AP_TYPE__/66/g' -e 's/__WIRELESS_MAC__/6C:8D:77:5C:81:E0/g' -e 's/__WIRED_MAC__/6C:8D:77:60:20:E8/g' -e 's/__WIRED1_MAC__/6C:8D:77:60:20:E8/g' | DMALLOC_OPTIONS=debug=0x400003,inter=1000,log=/tmp/wcp.dmalloc.log,limit=40000000 wcpd &
[*07/16/2022 08:47:04.1699] ip6_port srcr6, ip6local fe80::6e8d:77ff:fe60:20e8, ip6 fd22:cc4f:a8cb:0:6e8d:77ff:fe60:20e8, plen 64, gw6 fe80::20cc:4fff:fea8:cb00, gw6_mac 22:CC:4F:A8:CB:00, mtu 1500, vid 0, mode6 3(slaac)
[*07/16/2022 08:47:04.1699] AP IPv6 Address updated from :: to fd22:cc4f:a8cb:0:6e8d:77ff:fe60:20e8
[*07/16/2022 08:47:05.9199] DOT11_DRV[0]: Init Radio0
[*07/16/2022 08:47:05.9499] DOT11_DRV[0]: Stop Radio0
[*07/16/2022 08:47:05.9599] DOT11_DRV[0]: set_channel Channel set to 6
[*07/16/2022 08:47:05.9799] DOT11_DRV[1]: Init Radio1
[*07/16/2022 08:47:06.0099] DOT11_DRV[1]: Stop Radio1
[*07/16/2022 08:47:06.0199] DOT11_DRV[1]: set_channel Channel set to 36
[*07/16/2022 08:47:06.0199] CRIT-MeshControl:
[*07/16/2022 08:47:06.0199] Mesh Control: skipped adding wired1 backhaul
[*07/16/2022 08:47:06.3099] DOT11_CFG[0] Radio Mode is changed from Local to Local
[*07/16/2022 08:47:06.3099] DOT11_CFG[1] Radio Mode is changed from Local to Local
[*07/16/2022 08:47:06.3199] DOT11_DRV[0]: set_channel Channel set to 1
[*07/16/2022 08:47:06.3299] DOT11_DRV[0]: Channel set to 1, width 20
[*07/16/2022 08:47:06.3399] DOT11_DRV[0]: Channel set to 1, width 20
[*07/16/2022 08:47:06.3499] DOT11_DRV[1]: set_channel Channel set to 36
[*07/16/2022 08:47:06.3499] DOT11_DRV[1]: Channel set to 36, width 20
[*07/16/2022 08:47:06.3599] DOT11_DRV[1]: Channel set to 36, width 20
[*07/16/2022 08:47:08.1799] Waiting for uplink IPv4 configuration
[*07/16/2022 08:47:09.2399] ethernet_port wired0, ip 192.168.8.146, netmask 255.255.255.0, gw 192.168.8.1, mtu 1500, bcast 192.168.8.255, dns1 192.168.8.1, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*07/16/2022 08:47:10.5199] DOT11_CFG[0] Radio Mode is changed from Local to Local
[*07/16/2022 08:47:10.5199] DOT11_CFG[1] Radio Mode is changed from Local to Local
[*07/16/2022 08:47:10.5899] AP IPv4 Address updated from 0.0.0.0 to 192.168.8.146
[*07/16/2022 08:47:10.6299] dtls_init: Use MIC certificate
[*07/16/2022 08:47:10.6299] CAPWAP State: Init
[*07/16/2022 08:47:10.6299] Config not found, PNP is required, Starting PNP
[*07/16/2022 08:47:22.9799] PNP:Server not reachable, Start CAPWAP Discovery
[*07/16/2022 08:47:22.9799] CAPWAP State: Discovery
[*07/16/2022 08:47:22.9899] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/16/2022 08:47:22.9899] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*07/16/2022 08:47:22.9899] CAPWAP State: Discovery
[*07/16/2022 08:47:32.3999]
[*07/16/2022 08:47:32.3999] CAPWAP State: Discovery
[*07/16/2022 08:47:32.4099] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/16/2022 08:47:32.4199] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*07/16/2022 08:47:41.9099]
[*07/16/2022 08:47:41.9099] CAPWAP State: Discovery
[*07/16/2022 08:47:41.9199] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/16/2022 08:47:41.9299] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*07/16/2022 08:47:51.4099]
5 Replies 5
test
Prince.O
Looks like you may need to hold the mode button a bit longer to trigger the full reset ; see below:
Button pressed for 9 seconds
You can also do this from the CLI with this command : "Capwap ap erase all "
Hi Prince,
Please ignore 9 seconds. I tried for more than 25 seconds but still the same.
JPavonM
If neither 'Hit ESC' doesn't work nor the factory reset method to keep pressd the Reset button for more than 20 secs (an less than 60 secs) then something maybe done improperly.
I understand you are unable to get into privilege mode after booting to invoke 'capwap ap erase' to try again the previous methods (try using a different console App just in case the one you use does not accept hitting ESC while booting to fall into u-boot)
Rich R
> How can i reset AP 1815i?
[*07/16/2022 08:46:31.2199] Creating default base capwap config."
- You have clearly already reset the AP.
CAPWAP to Mobility Express - you said this in the subject line but no more after that.  Presume you're asking how to convert the AP to ME.  Follow the instructions:
https://www.cisco.com/c/en/us/support/docs/wireless/mobility-express-aironet-access-points/215410-convert-capwap-1852-access-point-ap-to.html
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/83/user_guide/b_ME_User_Guide_83/b_ME_User_Guide_83_chapter_01000.html#task_7588F4C009744AEFBB9EB754A713E390
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/b_cisco_mobility_express_8_8/m_deploying_cisco_mobility_express.html#task_A871BE3C97AF41328979F0271486D49F
And always check the release notes:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/release_notes/b_ME_RN_810.html
