Cisco Aironet 3602I is stand alone or need a controller ????..
dchavarria
          Can any help me with this questions ?...thanks you.
David Chavarria
8 Replies 8
blakekrone
Level 4
Level 4
3602's need a controller.
Stephen Rodriguez
3602 is designed to work with the WLC, as is the 3500.  Any AP with Clean Air needs to be joined to the WLC to gain the Clean Air functionality.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
You also need code 7.2, which means you need a new 2504, 5508 or WISM2. Will not work on older controllers.
Amjad Abdullah
in General APs can be converted to work with autonomous (standalone) image or an LWAPP/CAPWAP image that needs controller.
for 3600 series APs however there are no support for autonomous image and you can only use it on WLC with version 7.2 or above (7.0 does not work).
7.2 version does not work on all WLC platforms and only works on new platforms like WiSM2 and 2500 WLCs.
I think everyone above mentioned what I wrote but I just tries ot make a good summary.
Amjad
Rating useful replies is more useful than saying "Thank you"
Do you know if there is an autonomous image for this, we were asked to perform a site survey with this model , but we dont want to be carrying WLC to do this,
No. There is no autonomous image.
martyn.rees
Level 4
Level 4
I'd be interested to hear how others have done site surveys with these units, as it does make it hard without an autonomous image.
This was the same issue when the 3500's came out until people found out you can use the 1260 image.  What I have seen in the field is using a 2504 and a power pack to power up the 2504.  It would be the same if you would have to survey for mesh.
-Scott
