Cisco Aironet AIR-SAP2602I-E-K9 SNMP OID questions
helpling
using this AP I want to monitor some values with icinga using the chek_snmp command or build an own script. I want to get the following:
- CPU load
- Memory usage/free
- Temperature
- Amount of connected clients
- Used bandwith up & down
I get a long list with snmpwalk but I have no idea where those values are behind. Can someone help me please?
(I searched already but I cound't find or I am to dumb to get it)
Thanks in advance!
Kay
10 Replies 10
 Try to share the information you got, this can make easier to help.
 But bottom line with SNMP is that it works based in OIDs. Each OID can as AP one kind of specific information. So you have to have the knowledge of what OID you have and what they are searching for.
Sorry, but do you mean the list I get when I do the snmpwalk?
Yes, should this I can guide you on how to read this.
SNMPv2-MIB::sysDescr.0 = STRING: Cisco IOS Software, C3600 Software (AP3G2-K9W7-M), Version 15.3(3)JBB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 04-May-15 17:19 by prod_rel_team
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.9.1.1659
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (283038056) 32 days, 18:13:00.56
SNMPv2-MIB::sysContact.0 = STRING:
SNMPv2-MIB::sysLocation.0 = STRING:
SNMPv2-MIB::sysServices.0 = INTEGER: 6
SNMPv2-MIB::sysORLastChange.0 = Timeticks: (0) 0:00:00.00
IF-MIB::ifNumber.0 = INTEGER: 10
IF-MIB::ifIndex.1 = INTEGER: 1
IF-MIB::ifIndex.2 = INTEGER: 2
IF-MIB::ifIndex.3 = INTEGER: 3
IF-MIB::ifIndex.4 = INTEGER: 4
IF-MIB::ifIndex.5 = INTEGER: 5
IF-MIB::ifIndex.6 = INTEGER: 6
IF-MIB::ifIndex.7 = INTEGER: 7
IF-MIB::ifIndex.8 = INTEGER: 8
IF-MIB::ifIndex.9 = INTEGER: 9
IF-MIB::ifIndex.10 = INTEGER: 10
IF-MIB::ifDescr.1 = STRING: Dot11Radio0
IF-MIB::ifDescr.2 = STRING: Dot11Radio1
IF-MIB::ifDescr.3 = STRING: GigabitEthernet0
IF-MIB::ifDescr.4 = STRING: Null0
IF-MIB::ifDescr.5 = STRING: Dot11Radio0.4000
IF-MIB::ifDescr.6 = STRING: Dot11Radio0.4001
IF-MIB::ifDescr.7 = STRING: Dot11Radio1.4000
IF-MIB::ifDescr.8 = STRING: GigabitEthernet0.4000
IF-MIB::ifDescr.9 = STRING: GigabitEthernet0.4001
IF-MIB::ifDescr.10 = STRING: BVI1
IF-MIB::ifType.1 = INTEGER: ieee80211(71)
IF-MIB::ifType.2 = INTEGER: ieee80211(71)
IF-MIB::ifType.3 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.4 = INTEGER: other(1)
IF-MIB::ifType.5 = INTEGER: l2vlan(135)
IF-MIB::ifType.6 = INTEGER: l2vlan(135)
IF-MIB::ifType.7 = INTEGER: l2vlan(135)
IF-MIB::ifType.8 = INTEGER: l2vlan(135)
IF-MIB::ifType.9 = INTEGER: l2vlan(135)
IF-MIB::ifType.10 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifMtu.1 = INTEGER: 1500
IF-MIB::ifMtu.2 = INTEGER: 1500
IF-MIB::ifMtu.3 = INTEGER: 1500
IF-MIB::ifMtu.4 = INTEGER: 1500
IF-MIB::ifMtu.5 = INTEGER: 1500
IF-MIB::ifMtu.6 = INTEGER: 1500
IF-MIB::ifMtu.7 = INTEGER: 1500
IF-MIB::ifMtu.8 = INTEGER: 1500
IF-MIB::ifMtu.9 = INTEGER: 1500
IF-MIB::ifMtu.10 = INTEGER: 1500
IF-MIB::ifSpeed.1 = Gauge32: 54000000
IF-MIB::ifSpeed.2 = Gauge32: 54000000
IF-MIB::ifSpeed.3 = Gauge32: 1000000000
IF-MIB::ifSpeed.4 = Gauge32: 4294967295
IF-MIB::ifSpeed.5 = Gauge32: 54000000
IF-MIB::ifSpeed.6 = Gauge32: 54000000
IF-MIB::ifSpeed.7 = Gauge32: 54000000
IF-MIB::ifSpeed.8 = Gauge32: 1000000000
IF-MIB::ifSpeed.9 = Gauge32: 1000000000
IF-MIB::ifSpeed.10 = Gauge32: 54000000
IF-MIB::ifAdminStatus.1 = INTEGER: up(1)
IF-MIB::ifAdminStatus.2 = INTEGER: up(1)
IF-MIB::ifAdminStatus.3 = INTEGER: up(1)
IF-MIB::ifAdminStatus.4 = INTEGER: up(1)
IF-MIB::ifAdminStatus.5 = INTEGER: up(1)
IF-MIB::ifAdminStatus.6 = INTEGER: up(1)
IF-MIB::ifAdminStatus.7 = INTEGER: up(1)
IF-MIB::ifAdminStatus.8 = INTEGER: up(1)
IF-MIB::ifAdminStatus.9 = INTEGER: up(1)
IF-MIB::ifAdminStatus.10 = INTEGER: up(1)
IF-MIB::ifOperStatus.1 = INTEGER: up(1)
IF-MIB::ifOperStatus.2 = INTEGER: up(1)
IF-MIB::ifOperStatus.3 = INTEGER: up(1)
IF-MIB::ifOperStatus.4 = INTEGER: up(1)
IF-MIB::ifOperStatus.5 = INTEGER: up(1)
IF-MIB::ifOperStatus.6 = INTEGER: up(1)
IF-MIB::ifOperStatus.7 = INTEGER: up(1)
IF-MIB::ifOperStatus.8 = INTEGER: up(1)
IF-MIB::ifOperStatus.9 = INTEGER: up(1)
IF-MIB::ifOperStatus.10 = INTEGER: up(1)
IF-MIB::ifLastChange.1 = Timeticks: (6852) 0:01:08.52
IF-MIB::ifLastChange.2 = Timeticks: (4092) 0:00:40.92
IF-MIB::ifLastChange.3 = Timeticks: (3388) 0:00:33.88
IF-MIB::ifLastChange.4 = Timeticks: (0) 0:00:00.00
IF-MIB::ifLastChange.5 = Timeticks: (6752) 0:01:07.52
IF-MIB::ifLastChange.6 = Timeticks: (6752) 0:01:07.52
IF-MIB::ifLastChange.7 = Timeticks: (3992) 0:00:39.92
IF-MIB::ifLastChange.8 = Timeticks: (3388) 0:00:33.88
IF-MIB::ifLastChange.9 = Timeticks: (3388) 0:00:33.88
IF-MIB::ifLastChange.10 = Timeticks: (3688) 0:00:36.88
IF-MIB::ifInOctets.1 = Counter32: 2979897497
IF-MIB::ifInOctets.2 = Counter32: 2448258399
IF-MIB::ifInOctets.3 = Counter32: 1893950924
IF-MIB::ifInOctets.4 = Counter32: 0
IF-MIB::ifInOctets.5 = Counter32: 2472622314
IF-MIB::ifInOctets.6 = Counter32: 3440096233
IF-MIB::ifInOctets.7 = Counter32: 3325282681
IF-MIB::ifInOctets.8 = Counter32: 0
IF-MIB::ifInOctets.9 = Counter32: 1093673453
IF-MIB::ifInOctets.10 = Counter32: 78561036
IF-MIB::ifInUcastPkts.1 = Counter32: 56858935
IF-MIB::ifInUcastPkts.2 = Counter32: 295696135
IF-MIB::ifInUcastPkts.3 = Counter32: 232544924
IF-MIB::ifInUcastPkts.4 = Counter32: 0
IF-MIB::ifInUcastPkts.5 = Counter32: 36342038
IF-MIB::ifInUcastPkts.6 = Counter32: 13553201
IF-MIB::ifInUcastPkts.7 = Counter32: 294542308
IF-MIB::ifInUcastPkts.8 = Counter32: 0
IF-MIB::ifInUcastPkts.9 = Counter32: 11840114
IF-MIB::ifInUcastPkts.10 = Counter32: 907354
IF-MIB::ifInDiscards.1 = Counter32: 284
IF-MIB::ifInDiscards.2 = Counter32: 716
IF-MIB::ifInDiscards.3 = Counter32: 771819
IF-MIB::ifInDiscards.4 = Counter32: 0
IF-MIB::ifInDiscards.10 = Counter32: 771825
IF-MIB::ifInErrors.1 = Counter32: 0
IF-MIB::ifInErrors.2 = Counter32: 0
IF-MIB::ifInErrors.3 = Counter32: 0
IF-MIB::ifInErrors.4 = Counter32: 0
IF-MIB::ifInErrors.10 = Counter32: 0
IF-MIB::ifInUnknownProtos.1 = Counter32: 0
IF-MIB::ifInUnknownProtos.2 = Counter32: 0
IF-MIB::ifInUnknownProtos.3 = Counter32: 0
IF-MIB::ifInUnknownProtos.4 = Counter32: 0
IF-MIB::ifInUnknownProtos.10 = Counter32: 0
IF-MIB::ifOutOctets.1 = Counter32: 2545200365
IF-MIB::ifOutOctets.2 = Counter32: 3800417534
IF-MIB::ifOutOctets.3 = Counter32: 3649880290
IF-MIB::ifOutOctets.4 = Counter32: 0
IF-MIB::ifOutOctets.5 = Counter32: 2341294845
IF-MIB::ifOutOctets.6 = Counter32: 1091201129
IF-MIB::ifOutOctets.7 = Counter32: 361830760
IF-MIB::ifOutOctets.8 = Counter32: 166745918
IF-MIB::ifOutOctets.9 = Counter32: 3441191974
IF-MIB::ifOutOctets.10 = Counter32: 78561516
IF-MIB::ifOutUcastPkts.1 = Counter32: 65112582
IF-MIB::ifOutUcastPkts.2 = Counter32: 166107594
IF-MIB::ifOutUcastPkts.3 = Counter32: 345217803
IF-MIB::ifOutUcastPkts.4 = Counter32: 0
IF-MIB::ifOutUcastPkts.5 = Counter32: 53223158
IF-MIB::ifOutUcastPkts.6 = Counter32: 11684023
IF-MIB::ifOutUcastPkts.7 = Counter32: 165953081
IF-MIB::ifOutUcastPkts.8 = Counter32: 331380933
IF-MIB::ifOutUcastPkts.9 = Counter32: 13551445
IF-MIB::ifOutUcastPkts.10 = Counter32: 883769
IF-MIB::ifOutDiscards.1 = Counter32: 47922472
IF-MIB::ifOutDiscards.2 = Counter32: 29713180
IF-MIB::ifOutDiscards.3 = Counter32: 0
IF-MIB::ifOutDiscards.4 = Counter32: 0
IF-MIB::ifOutDiscards.10 = Counter32: 0
IF-MIB::ifOutErrors.1 = Counter32: 11452
IF-MIB::ifOutErrors.2 = Counter32: 1428
IF-MIB::ifOutErrors.3 = Counter32: 0
IF-MIB::ifOutErrors.4 = Counter32: 0
IF-MIB::ifOutErrors.10 = Counter32: 0
SNMPv2-SMI::mib-2.3.1.1.1.8.1.XXX = INTEGER: 8
SNMPv2-SMI::mib-2.3.1.1.1.10.1.XXX22 = INTEGER: 10
SNMPv2-SMI::mib-2.3.1.1.1.10.1.XXX26 = INTEGER: 10
SNMPv2-SMI::mib-2.3.1.1.1.10.1.XXX = INTEGER: 10
SNMPv2-SMI::mib-2.3.1.1.2.8.1.XXX = Hex-STRING:
SNMPv2-SMI::mib-2.3.1.1.2.10.1.XXX22 = STRING: ":"
SNMPv2-SMI::mib-2.3.1.1.2.10.1.XXX26 = STRING: ""
SNMPv2-SMI::mib-2.3.1.1.2.10.1.XXX = Hex-STRING:
SNMPv2-SMI::mib-2.3.1.1.3.8.1.XXX = IpAddress:
SNMPv2-SMI::mib-2.3.1.1.3.10.1.XXX22 = IpAddress:
SNMPv2-SMI::mib-2.3.1.1.3.10.1.XXX26 = IpAddress:
SNMPv2-SMI::mib-2.3.1.1.3.10.1.XXX = IpAddress:
IP-MIB::ipForwarding.0 = INTEGER: notForwarding(2)
IP-MIB::ipDefaultTTL.0 = INTEGER: 255
IP-MIB::ipInReceives.0 = Counter32: 9980200
IP-MIB::ipInHdrErrors.0 = Counter32: 0
IP-MIB::ipInAddrErrors.0 = Counter32: 0
IP-MIB::ipForwDatagrams.0 = Counter32: 0
IP-MIB::ipInUnknownProtos.0 = Counter32: 0
IP-MIB::ipInDiscards.0 = Counter32: 0
IP-MIB::ipInDelivers.0 = Counter32: 7500699
IP-MIB::ipOutRequests.0 = Counter32: 701288
IP-MIB::ipOutDiscards.0 = Counter32: 1
IP-MIB::ipOutNoRoutes.0 = Counter32: 0
IP-MIB::ipReasmTimeout.0 = INTEGER: 30 seconds
IP-MIB::ipReasmReqds.0 = Counter32: 0
IP-MIB::ipReasmOKs.0 = Counter32: 0
IP-MIB::ipReasmFails.0 = Counter32: 0
IP-MIB::ipFragOKs.0 = Counter32: 0
IP-MIB::ipFragFails.0 = Counter32: 0
IP-MIB::ipFragCreates.0 = Counter32: 0
IP-MIB::ipAdEntAddr. = IpAddress:
IP-MIB::ipAdEntIfIndex. = INTEGER: 10
IP-MIB::ipAdEntNetMask. = IpAddress:
IP-MIB::ipAdEntBcastAddr = INTEGER: 1
IP-MIB::ipAdEntReasmMaxSize = INTEGER: 18024
IP-MIB::ipNetToMediaIfIndex.8 = INTEGER: 8
IP-MIB::ipNetToMediaIfIndex.10 = INTEGER: 10
IP-MIB::ipNetToMediaPhysAddress.8 = STRING:
IP-MIB::ipNetToMediaPhysAddress.10 = STRING:
IP-MIB::ipNetToMediaNetAddress.8 = IpAddress:
IP-MIB::ipNetToMediaNetAddress.10 = IpAddress:
IP-MIB::ipNetToMediaType.8 = INTEGER: static(4)
IP-MIB::ipNetToMediaType.10 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.10.XXX = INTEGER: static(4)
IP-MIB::ipRoutingDiscards.0 = Counter32: 0
IP-MIB::ipv4InterfaceTableLastChange.0 = Timeticks: (2796) 0:00:27.96
IP-MIB::ipv4InterfaceReasmMaxSize.8 = INTEGER: 18024
IP-MIB::ipv4InterfaceReasmMaxSize.10 = INTEGER: 18024
IP-MIB::ipv4InterfaceEnableStatus.8 = INTEGER: up(1)
IP-MIB::ipv4InterfaceEnableStatus.10 = INTEGER: up(1)
IP-MIB::ipv4InterfaceRetransmitTime.8 = Gauge32: 14400000 milliseconds
IP-MIB::ipv4InterfaceRetransmitTime.10 = Gauge32: 14400000 milliseconds
IP-MIB::ipSystemStatsInReceives.ipv4 = Counter32: 9980248
IP-MIB::ipSystemStatsHCInReceives.ipv4 = Counter64: 9980249
IP-MIB::ipSystemStatsInOctets.ipv4 = Counter32: 1014673309
IP-MIB::ipSystemStatsHCInOctets.ipv4 = Counter64: 1014673382
IP-MIB::ipSystemStatsInHdrErrors.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInNoRoutes.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInAddrErrors.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInUnknownProtos.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInTruncatedPkts.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInForwDatagrams.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsHCInForwDatagrams.ipv4 = Counter64: 0
IP-MIB::ipSystemStatsReasmReqds.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsReasmOKs.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsReasmFails.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInDiscards.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInDelivers.ipv4 = Counter32: 7500756
IP-MIB::ipSystemStatsHCInDelivers.ipv4 = Counter64: 7500757
IP-MIB::ipSystemStatsOutRequests.ipv4 = Counter32: 701345
IP-MIB::ipSystemStatsHCOutRequests.ipv4 = Counter64: 701346
IP-MIB::ipSystemStatsOutNoRoutes.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsOutForwDatagrams.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsHCOutForwDatagrams.ipv4 = Counter64: 0
IP-MIB::ipSystemStatsOutDiscards.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsOutFragReqds.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsOutFragOKs.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsOutFragFails.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsOutFragCreates.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsOutTransmits.ipv4 = Counter32: 701355
IP-MIB::ipSystemStatsHCOutTransmits.ipv4 = Counter64: 701356
IP-MIB::ipSystemStatsOutOctets.ipv4 = Counter32: 55163700
IP-MIB::ipSystemStatsHCOutOctets.ipv4 = Counter64: 55163777
IP-MIB::ipSystemStatsInMcastPkts.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsHCInMcastPkts.ipv4 = Counter64: 0
IP-MIB::ipSystemStatsInMcastOctets.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsHCInMcastOctets.ipv4 = Counter64: 0
IP-MIB::ipSystemStatsOutMcastPkts.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsHCOutMcastPkts.ipv4 = Counter64: 0
IP-MIB::ipSystemStatsOutMcastOctets.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsHCOutMcastOctets.ipv4 = Counter64: 0
IP-MIB::ipSystemStatsInBcastPkts.ipv4 = Counter32: 6786565
IP-MIB::ipSystemStatsHCInBcastPkts.ipv4 = Counter64: 6786565
IP-MIB::ipSystemStatsOutBcastPkts.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsHCOutBcastPkts.ipv4 = Counter64: 0
IP-MIB::ipSystemStatsDiscontinuityTime.ipv4 = Timeticks: (0) 0:00:00.00
IP-MIB::ipIfStatsInReceives.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsInReceives.ipv4.10 = Counter32: 9980293
IP-MIB::ipIfStatsHCInReceives.ipv4.8 = Counter64: 0
IP-MIB::ipIfStatsHCInReceives.ipv4.10 = Counter64: 9980295
IP-MIB::ipIfStatsInOctets.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv4.10 = Counter32: 1154400903
IP-MIB::ipIfStatsHCInOctets.ipv4.8 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.10 = Counter64: 1154401079
IP-MIB::ipIfStatsInHdrErrors.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsInHdrErrors.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsInNoRoutes.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsInNoRoutes.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsInAddrErrors.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsInAddrErrors.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsInUnknownProtos.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsInUnknownProtos.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsInTruncatedPkts.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsInTruncatedPkts.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsInForwDatagrams.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsInForwDatagrams.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsHCInForwDatagrams.ipv4.8 = Counter64: 0
IP-MIB::ipIfStatsHCInForwDatagrams.ipv4.10 = Counter64: 0
IP-MIB::ipIfStatsReasmReqds.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsReasmReqds.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsReasmOKs.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsReasmOKs.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsReasmFails.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsReasmFails.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsInDiscards.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsInDiscards.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsInDelivers.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsInDelivers.ipv4.10 = Counter32: 7500816
IP-MIB::ipIfStatsHCInDelivers.ipv4.8 = Counter64: 0
IP-MIB::ipIfStatsHCInDelivers.ipv4.10 = Counter64: 7500818
IP-MIB::ipIfStatsOutRequests.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsOutRequests.ipv4.10 = Counter32: 701407
IP-MIB::ipIfStatsHCOutRequests.ipv4.8 = Counter64: 0
IP-MIB::ipIfStatsHCOutRequests.ipv4.10 = Counter64: 701409
IP-MIB::ipIfStatsOutForwDatagrams.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsOutForwDatagrams.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsHCOutForwDatagrams.ipv4.8 = Counter64: 0
IP-MIB::ipIfStatsHCOutForwDatagrams.ipv4.10 = Counter64: 0
IP-MIB::ipIfStatsOutDiscards.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsOutDiscards.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsOutFragReqds.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsOutFragReqds.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsOutFragOKs.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsOutFragOKs.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsOutFragFails.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsOutFragFails.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsOutFragCreates.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsOutFragCreates.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsOutTransmits.ipv4.8 = Counter32: 2
IP-MIB::ipIfStatsOutTransmits.ipv4.10 = Counter32: 701425
IP-MIB::ipIfStatsHCOutTransmits.ipv4.8 = Counter64: 2
IP-MIB::ipIfStatsHCOutTransmits.ipv4.10 = Counter64: 701427
IP-MIB::ipIfStatsOutOctets.ipv4.8 = Counter32: 120
IP-MIB::ipIfStatsOutOctets.ipv4.10 = Counter32: 64989125
IP-MIB::ipIfStatsHCOutOctets.ipv4.8 = Counter64: 120
IP-MIB::ipIfStatsHCOutOctets.ipv4.10 = Counter64: 64989306
IP-MIB::ipIfStatsInMcastPkts.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsInMcastPkts.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsHCInMcastPkts.ipv4.8 = Counter64: 0
IP-MIB::ipIfStatsHCInMcastPkts.ipv4.10 = Counter64: 0
IP-MIB::ipIfStatsInMcastOctets.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsInMcastOctets.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsHCInMcastOctets.ipv4.8 = Counter64: 0
IP-MIB::ipIfStatsHCInMcastOctets.ipv4.10 = Counter64: 0
IP-MIB::ipIfStatsOutMcastPkts.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsOutMcastPkts.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsHCOutMcastPkts.ipv4.8 = Counter64: 0
IP-MIB::ipIfStatsHCOutMcastPkts.ipv4.10 = Counter64: 0
IP-MIB::ipIfStatsOutMcastOctets.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsOutMcastOctets.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsHCOutMcastOctets.ipv4.8 = Counter64: 0
IP-MIB::ipIfStatsHCOutMcastOctets.ipv4.10 = Counter64: 0
IP-MIB::ipIfStatsInBcastPkts.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsInBcastPkts.ipv4.10 = Counter32: 6786566
IP-MIB::ipIfStatsHCInBcastPkts.ipv4.8 = Counter64: 0
IP-MIB::ipIfStatsHCInBcastPkts.ipv4.10 = Counter64: 6786566
IP-MIB::ipIfStatsOutBcastPkts.ipv4.8 = Counter32: 0
IP-MIB::ipIfStatsOutBcastPkts.ipv4.10 = Counter32: 0
IP-MIB::ipIfStatsHCOutBcastPkts.ipv4.8 = Counter64: 0
IP-MIB::ipIfStatsHCOutBcastPkts.ipv4.10 = Counter64: 0
IP-MIB::ipIfStatsDiscontinuityTime.ipv4.8 = Timeticks: (0) 0:00:00.00
IP-MIB::ipIfStatsDiscontinuityTime.ipv4.10 = Timeticks: (0) 0:00:00.00
IP-MIB::ipAddressPrefixOrigin.8.ipv4."XXX0.0".17 = INTEGER: manual(2)
IP-MIB::ipAddressPrefixOrigin.10.ipv4."XXX0.0".17 = INTEGER: manual(2)
IP-MIB::ipAddressPrefixOnLinkFlag.8.ipv4."XXX0.0".17 = INTEGER: true(1)
IP-MIB::ipAddressPrefixOnLinkFlag.10.ipv4."XXX0.0".17 = INTEGER: true(1)
IP-MIB::ipAddressPrefixAutonomousFlag.8.ipv4."XXX0.0".17 = INTEGER: false(2)
IP-MIB::ipAddressPrefixAutonomousFlag.10.ipv4."XXX0.0".17 = INTEGER: false(2)
IP-MIB::ipAddressPrefixAdvPreferredLifetime.8.ipv4."XXX0.0".17 = Gauge32: 4294967295 seconds
IP-MIB::ipAddressPrefixAdvPreferredLifetime.10.ipv4."XXX0.0".17 = Gauge32: 4294967295 seconds
IP-MIB::ipAddressPrefixAdvValidLifetime.8.ipv4."XXX0.0".17 = Gauge32: 4294967295 seconds
IP-MIB::ipAddressPrefixAdvValidLifetime.10.ipv4."XXX0.0".17 = Gauge32: 4294967295 seconds
IP-MIB::ipAddressSpinLock.0 = INTEGER: 0
IP-MIB::ipAddressIfIndex.ipv4."XXX" = INTEGER: 10
IP-MIB::ipAddressType.ipv4."XXX" = INTEGER: unicast(1)
IP-MIB::ipAddressPrefix.ipv4."XXX" = OID: IP-MIB::ipAddressPrefixOrigin.10.ipv4."".17
IP-MIB::ipAddressOrigin.ipv4."XXX" = INTEGER: manual(2)
IP-MIB::ipAddressStatus.ipv4."XXX" = INTEGER: inaccessible(4)
IP-MIB::ipAddressCreated.ipv4."XXX" = Timeticks: (2796) 0:00:27.96
IP-MIB::ipAddressLastChanged.ipv4."XXX" = Timeticks: (2796) 0:00:27.96
IP-MIB::ipAddressRowStatus.ipv4."XXX" = INTEGER: active(1)
IP-MIB::ipAddressStorageType.ipv4."XXX" = INTEGER: nonVolatile(3)
IP-MIB::ipNetToPhysicalPhysAddress.8.ipv4."XXX" = STRING:
IP-MIB::ipNetToPhysicalPhysAddress.10.ipv4."XXX22" = STRING:
IP-MIB::ipNetToPhysicalPhysAddress.10.ipv4."XXX26" = STRING:
IP-MIB::ipNetToPhysicalPhysAddress.10.ipv4."XXX" = STRING:
IP-MIB::ipNetToPhysicalLastUpdated.8.ipv4."XXX" = Timeticks: (2796) 0:00:27.96
IP-MIB::ipNetToPhysicalLastUpdated.10.ipv4."XXX22" = Timeticks: (2796) 0:00:27.96
IP-MIB::ipNetToPhysicalLastUpdated.10.ipv4."XXX26" = Timeticks: (2796) 0:00:27.96
IP-MIB::ipNetToPhysicalLastUpdated.10.ipv4."XXX" = Timeticks: (2796) 0:00:27.96
IP-MIB::ipNetToPhysicalType.8.ipv4."XXX" = INTEGER: static(4)
IP-MIB::ipNetToPhysicalType.10.ipv4."XXX22" = INTEGER: dynamic(3)
IP-MIB::ipNetToPhysicalType.10.ipv4."XXX26" = INTEGER: dynamic(3)
IP-MIB::ipNetToPhysicalType.10.ipv4."XXX" = INTEGER: static(4)
IP-MIB::ipNetToPhysicalState.8.ipv4."XXX" = INTEGER: unknown(6)
IP-MIB::ipNetToPhysicalState.10.ipv4."XXX22" = INTEGER: unknown(6)
IP-MIB::ipNetToPhysicalState.10.ipv4."XXX26" = INTEGER: unknown(6)
IP-MIB::ipNetToPhysicalState.10.ipv4."XXX" = INTEGER: unknown(6)
IP-MIB::ipNetToPhysicalRowStatus.8.ipv4."XXX" = INTEGER: active(1)
IP-MIB::ipNetToPhysicalRowStatus.10.ipv4."XXX22" = INTEGER: active(1)
IP-MIB::ipNetToPhysicalRowStatus.10.ipv4."XXX26" = INTEGER: active(1)
IP-MIB::ipNetToPhysicalRowStatus.10.ipv4."XXX" = INTEGER: active(1)
IP-MIB::icmpInMsgs.0 = Counter32: 544584
IP-MIB::icmpInErrors.0 = Counter32: 0
IP-MIB::icmpInDestUnreachs.0 = Counter32: 0
IP-MIB::icmpInTimeExcds.0 = Counter32: 0
IP-MIB::icmpInParmProbs.0 = Counter32: 0
IP-MIB::icmpInSrcQuenchs.0 = Counter32: 0
IP-MIB::icmpInRedirects.0 = Counter32: 0
IP-MIB::icmpInEchos.0 = Counter32: 544584
IP-MIB::icmpInEchoReps.0 = Counter32: 0
IP-MIB::icmpInTimestamps.0 = Counter32: 0
IP-MIB::icmpInTimestampReps.0 = Counter32: 0
IP-MIB::icmpInAddrMasks.0 = Counter32: 0
IP-MIB::icmpInAddrMaskReps.0 = Counter32: 0
IP-MIB::icmpOutMsgs.0 = Counter32: 545452
IP-MIB::icmpOutErrors.0 = Counter32: 0
IP-MIB::icmpOutDestUnreachs.0 = Counter32: 869
IP-MIB::icmpOutTimeExcds.0 = Counter32: 0
IP-MIB::icmpOutParmProbs.0 = Counter32: 0
IP-MIB::icmpOutSrcQuenchs.0 = Counter32: 0
IP-MIB::icmpOutRedirects.0 = Counter32: 0
IP-MIB::icmpOutEchos.0 = Counter32: 0
IP-MIB::icmpOutEchoReps.0 = Counter32: 544584
IP-MIB::icmpOutTimestamps.0 = Counter32: 0
IP-MIB::icmpOutTimestampReps.0 = Counter32: 0
IP-MIB::icmpOutAddrMasks.0 = Counter32: 0
IP-MIB::icmpOutAddrMaskReps.0 = Counter32: 0
IP-MIB::icmpStatsInMsgs.ipv4 = Counter32: 544584
IP-MIB::icmpStatsInErrors.ipv4 = Counter32: 0
IP-MIB::icmpStatsOutMsgs.ipv4 = Counter32: 545452
IP-MIB::icmpStatsOutErrors.ipv4 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.0 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.1 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.2 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.3 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.4 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.5 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.6 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.7 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.8 = Counter32: 544584
IP-MIB::icmpMsgStatsInPkts.ipv4.9 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.10 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.11 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.12 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.13 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.14 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.15 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.16 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.17 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.18 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.19 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.20 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.21 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.22 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.23 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.24 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.25 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.26 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.27 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.28 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.29 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.30 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.31 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.32 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.33 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.34 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.35 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.36 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.37 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.38 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.39 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.40 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.41 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.42 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.43 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.44 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.45 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.46 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.47 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.48 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.49 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.50 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.51 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.52 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.53 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.54 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.55 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.56 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.57 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.58 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.59 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.60 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.61 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.62 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.63 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.64 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.65 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.66 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.67 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.68 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.69 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.70 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.71 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.72 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.73 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.74 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.75 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.76 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.77 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.78 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.79 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.80 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.81 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.82 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.83 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.84 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.85 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.86 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.87 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.88 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.89 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.90 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.91 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.92 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.93 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.94 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.95 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.96 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.97 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.98 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.99 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.100 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.101 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.102 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.103 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.104 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.105 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.106 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.107 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.108 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.109 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.110 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.111 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.112 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.113 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.114 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.115 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.116 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.117 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.118 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.119 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.120 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.121 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.122 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.123 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.124 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.125 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.126 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.127 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.128 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.129 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.130 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.131 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.132 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.133 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.134 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.135 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.136 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.137 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.138 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.139 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.140 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.141 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.142 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.143 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.144 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.145 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.146 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.147 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.148 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.149 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.150 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.151 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.152 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.153 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.154 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.155 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.156 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.157 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.158 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.159 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.160 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.161 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.162 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.163 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.164 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.165 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.166 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.167 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.168 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.169 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.170 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.171 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.172 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.173 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.174 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.175 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.176 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.177 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.178 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.179 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.180 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.181 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.182 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.183 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.184 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.185 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.186 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.187 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.188 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.189 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.190 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.191 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.192 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.193 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.194 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.195 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.196 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.197 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.198 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.199 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.200 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.201 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.202 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.203 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.204 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.205 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.206 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.207 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.208 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.209 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.210 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.211 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.212 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.213 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.214 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.215 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.216 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.217 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.218 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.219 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.220 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.221 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.222 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.223 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.224 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.225 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.226 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.227 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.228 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.229 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.230 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.231 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.232 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.233 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.234 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.235 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.236 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.237 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.238 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.239 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.240 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.241 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.242 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.243 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.244 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.245 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.246 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.247 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.248 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.249 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.250 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.251 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.252 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.253 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.254 = Counter32: 0
IP-MIB::icmpMsgStatsInPkts.ipv4.255 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.0 = Counter32: 544584
IP-MIB::icmpMsgStatsOutPkts.ipv4.1 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.2 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.3 = Counter32: 869
IP-MIB::icmpMsgStatsOutPkts.ipv4.4 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.5 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.6 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.7 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.8 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.9 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.10 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.11 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.12 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.13 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.14 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.15 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.16 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.17 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.18 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.19 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.20 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.21 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.22 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.23 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.24 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.25 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.26 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.27 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.28 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.29 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.30 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.31 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.32 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.33 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.34 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.35 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.36 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.37 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.38 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.39 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.40 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.41 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.42 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.43 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.44 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.45 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.46 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.47 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.48 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.49 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.50 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.51 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.52 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.53 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.54 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.55 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.56 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.57 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.58 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.59 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.60 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.61 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.62 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.63 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.64 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.65 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.66 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.67 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.68 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.69 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.70 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.71 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.72 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.73 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.74 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.75 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.76 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.77 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.78 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.79 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.80 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.81 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.82 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.83 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.84 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.85 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.86 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.87 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.88 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.89 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.90 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.91 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.92 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.93 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.94 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.95 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.96 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.97 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.98 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.99 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.100 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.101 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.102 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.103 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.104 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.105 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.106 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.107 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.108 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.109 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.110 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.111 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.112 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.113 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.114 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.115 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.116 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.117 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.118 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.119 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.120 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.121 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.122 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.123 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.124 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.125 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.126 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.127 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.128 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.129 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.130 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.131 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.132 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.133 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.134 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.135 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.136 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.137 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.138 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.139 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.140 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.141 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.142 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.143 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.144 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.145 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.146 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.147 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.148 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.149 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.150 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.151 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.152 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.153 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.154 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.155 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.156 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.157 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.158 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.159 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.160 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.161 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.162 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.163 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.164 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.165 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.166 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.167 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.168 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.169 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.170 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.171 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.172 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.173 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.174 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.175 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.176 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.177 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.178 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.179 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.180 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.181 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.182 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.183 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.184 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.185 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.186 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.187 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.188 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.189 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.190 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.191 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.192 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.193 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.194 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.195 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.196 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.197 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.198 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.199 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.200 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.201 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.202 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.203 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.204 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.205 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.206 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.207 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.208 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.209 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.210 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.211 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.212 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.213 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.214 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.215 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.216 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.217 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.218 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.219 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.220 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.221 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.222 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.223 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.224 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.225 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.226 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.227 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.228 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.229 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.230 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.231 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.232 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.233 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.234 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.235 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.236 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.237 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.238 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.239 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.240 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.241 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.242 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.243 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.244 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.245 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.246 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.247 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.248 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.249 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.250 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.251 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.252 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.253 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.254 = Counter32: 0
IP-MIB::icmpMsgStatsOutPkts.ipv4.255 = Counter32: 0
TCP-MIB::tcpRtoAlgorithm.0 = INTEGER: rfc2988(5)
TCP-MIB::tcpRtoMin.0 = INTEGER: 1000 milliseconds
TCP-MIB::tcpRtoMax.0 = INTEGER: 60000 milliseconds
TCP-MIB::tcpMaxConn.0 = INTEGER: -1
TCP-MIB::tcpActiveOpens.0 = Counter32: 0
TCP-MIB::tcpPassiveOpens.0 = Counter32: 5203
TCP-MIB::tcpAttemptFails.0 = Counter32: 9
TCP-MIB::tcpEstabResets.0 = Counter32: 4270
TCP-MIB::tcpCurrEstab.0 = Gauge32: 0
TCP-MIB::tcpInSegs.0 = Counter32: 47110
TCP-MIB::tcpOutSegs.0 = Counter32: 34338
TCP-MIB::tcpRetransSegs.0 = Counter32: 27
TCP-MIB::tcpInErrs.0 = Counter32: 0
TCP-MIB::tcpOutRsts.0 = Counter32: 7619
TCP-MIB::tcpHCInSegs.0 = Counter64: 47110
TCP-MIB::tcpHCOutSegs.0 = Counter64: 34338
TCP-MIB::tcpListenerProcess.unknown."".80 = Gauge32: 109
TCP-MIB::tcpListenerProcess.unknown."".37540 = Gauge32: 3
TCP-MIB::tcpListenerProcess.unknown."".37550 = Gauge32: 15
UDP-MIB::udpInDatagrams.0 = Counter32: 2403214
UDP-MIB::udpNoPorts.0 = Counter32: 4506518
UDP-MIB::udpInErrors.0 = Counter32: 49
UDP-MIB::udpOutDatagrams.0 = Counter32: 122272
UDP-MIB::udpLocalAddress.XXX.161 = IpAddress:
UDP-MIB::udpLocalAddress.XXX.162 = IpAddress:
UDP-MIB::udpLocalAddress.XXX.2887 = IpAddress:
UDP-MIB::udpLocalAddress.XXX.49429 = IpAddress:
UDP-MIB::udpLocalPort.XXX.161 = INTEGER: 161
UDP-MIB::udpLocalPort.XXX.162 = INTEGER: 162
UDP-MIB::udpLocalPort.XXX.2887 = INTEGER: 2887
UDP-MIB::udpLocalPort.XXX.49429 = INTEGER: 49429
UDP-MIB::udpEndpointProcess.unknown."".161.unknown."".0.1 = Gauge32: 0
UDP-MIB::udpEndpointProcess.unknown."".162.unknown."".0.1 = Gauge32: 0
UDP-MIB::udpEndpointProcess.unknown."".546.unknown."".0.1 = Gauge32: 0
UDP-MIB::udpEndpointProcess.unknown."".2887.unknown."".2887.1 = Gauge32: 0
UDP-MIB::udpEndpointProcess.unknown."".49429.unknown."".0.1 = Gauge32: 0
UDP-MIB::udpEndpointProcess.unknown."".63127.unknown."".0.1 = Gauge32: 0
UDP-MIB::udpEndpointProcess.ipv4."XXX".161.ipv4."".43578.1 = Gauge32: 0
UDP-MIB::udpEndpointProcess.ipv4."XXX".162.ipv4."0.0.0.0".0.1 = Gauge32: 0
UDP-MIB::udpEndpointProcess.ipv4."XXX".2887.ipv4."0.0.0.0".2887.1 = Gauge32: 0
UDP-MIB::udpEndpointProcess.ipv4."XXX".49429.ipv4."0.0.0.0".0.1 = Gauge32: 0
UDP-MIB::udpHCInDatagrams.0 = Counter64: 2403236
UDP-MIB::udpHCOutDatagrams.0 = Counter64: 122292
SNMPv2-SMI::transmission.7.2.1.1.1 = INTEGER: 1
SNMPv2-SMI::transmission.7.2.1.1.2 = INTEGER: 2
SNMPv2-SMI::transmission.7.2.1.1.3 = INTEGER: 3
SNMPv2-SMI::transmission.7.2.1.2.1 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.2.2 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.2.3 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.3.1 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.3.2 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.3.3 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.4.1 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.4.2 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.4.3 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.5.1 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.5.2 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.5.3 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.6.1 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.6.2 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.6.3 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.7.1 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.7.2 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.7.3 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.8.1 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.8.2 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.8.3 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.9.1 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.9.2 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.9.3 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.10.1 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.10.2 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.10.3 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.11.1 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.11.2 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.11.3 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.13.1 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.13.2 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.13.3 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.16.1 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.16.2 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.16.3 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.17.1 = OID: SNMPv2-SMI::zeroDotZero
SNMPv2-SMI::transmission.7.2.1.17.2 = OID: SNMPv2-SMI::zeroDotZero
SNMPv2-SMI::transmission.7.2.1.17.3 = OID: SNMPv2-SMI::zeroDotZero
SNMPv2-SMI::transmission.7.2.1.18.1 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.18.2 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.18.3 = Counter32: 0
SNMPv2-SMI::transmission.7.2.1.19.1 = INTEGER: 1
SNMPv2-SMI::transmission.7.2.1.19.2 = INTEGER: 1
SNMPv2-SMI::transmission.7.2.1.19.3 = INTEGER: 3
SNMPv2-MIB::snmpInPkts.0 = Counter32: 122389
SNMPv2-MIB::snmpOutPkts.0 = Counter32: 122342
SNMPv2-MIB::snmpInBadVersions.0 = Counter32: 0
SNMPv2-MIB::snmpInBadCommunityNames.0 = Counter32: 47
SNMPv2-MIB::snmpInBadCommunityUses.0 = Counter32: 0
SNMPv2-MIB::snmpInASNParseErrs.0 = Counter32: 0
SNMPv2-MIB::snmpInTooBigs.0 = Counter32: 0
SNMPv2-MIB::snmpInNoSuchNames.0 = Counter32: 0
SNMPv2-MIB::snmpInBadValues.0 = Counter32: 0
SNMPv2-MIB::snmpInReadOnlys.0 = Counter32: 0
SNMPv2-MIB::snmpInGenErrs.0 = Counter32: 0
SNMPv2-MIB::snmpInTotalReqVars.0 = Counter32: 196511
SNMPv2-MIB::snmpInTotalSetVars.0 = Counter32: 0
SNMPv2-MIB::snmpInGetRequests.0 = Counter32: 32257
SNMPv2-MIB::snmpInGetNexts.0 = Counter32: 90097
SNMPv2-MIB::snmpInSetRequests.0 = Counter32: 0
SNMPv2-MIB::snmpInGetResponses.0 = Counter32: 0
SNMPv2-MIB::snmpInTraps.0 = Counter32: 0
SNMPv2-MIB::snmpOutTooBigs.0 = Counter32: 0
SNMPv2-MIB::snmpOutNoSuchNames.0 = Counter32: 2839
SNMPv2-MIB::snmpOutBadValues.0 = Counter32: 0
SNMPv2-MIB::snmpOutGenErrs.0 = Counter32: 0
SNMPv2-MIB::snmpOutGetRequests.0 = Counter32: 0
SNMPv2-MIB::snmpOutGetNexts.0 = Counter32: 0
SNMPv2-MIB::snmpOutSetRequests.0 = Counter32: 0
SNMPv2-MIB::snmpOutGetResponses.0 = Counter32: 122366
SNMPv2-MIB::snmpOutTraps.0 = Counter32: 0
SNMPv2-MIB::snmpEnableAuthenTraps.0 = INTEGER: disabled(2)
SNMPv2-MIB::snmpSilentDrops.0 = Counter32: 0
SNMPv2-MIB::snmpProxyDrops.0 = Counter32: 0
SNMPv2-SMI::mib-2.17.1.1.0 = Hex-STRING: 00 00 00 00 00 00
SNMPv2-SMI::mib-2.17.1.2.0 = INTEGER: 3
SNMPv2-SMI::mib-2.17.1.3.0 = INTEGER: 4
SNMPv2-SMI::mib-2.17.1.4.1.1.5 = INTEGER: 5
SNMPv2-SMI::mib-2.17.1.4.1.1.6 = INTEGER: 6
SNMPv2-SMI::mib-2.17.1.4.1.1.7 = INTEGER: 7
SNMPv2-SMI::mib-2.17.1.4.1.1.8 = INTEGER: 8
SNMPv2-SMI::mib-2.17.1.4.1.1.9 = INTEGER: 9
SNMPv2-SMI::mib-2.17.1.4.1.2.5 = INTEGER: 5
SNMPv2-SMI::mib-2.17.1.4.1.2.6 = INTEGER: 6
SNMPv2-SMI::mib-2.17.1.4.1.2.7 = INTEGER: 7
SNMPv2-SMI::mib-2.17.1.4.1.2.8 = INTEGER: 8
SNMPv2-SMI::mib-2.17.1.4.1.2.9 = INTEGER: 9
SNMPv2-SMI::mib-2.17.1.4.1.3.5 = OID: SNMPv2-SMI::zeroDotZero
SNMPv2-SMI::mib-2.17.1.4.1.3.6 = OID: SNMPv2-SMI::zeroDotZero
SNMPv2-SMI::mib-2.17.1.4.1.3.7 = OID: SNMPv2-SMI::zeroDotZero
SNMPv2-SMI::mib-2.17.1.4.1.3.8 = OID: SNMPv2-SMI::zeroDotZero
SNMPv2-SMI::mib-2.17.1.4.1.3.9 = OID: SNMPv2-SMI::zeroDotZero
SNMPv2-SMI::mib-2.17.1.4.1.4.5 = Counter32: 0
SNMPv2-SMI::mib-2.17.1.4.1.4.6 = Counter32: 0
SNMPv2-SMI::mib-2.17.1.4.1.4.7 = Counter32: 0
SNMPv2-SMI::mib-2.17.1.4.1.4.8 = Counter32: 0
SNMPv2-SMI::mib-2.17.1.4.1.4.9 = Counter32: 0
SNMPv2-SMI::mib-2.17.1.4.1.5.5 = Counter32: 0
SNMPv2-SMI::mib-2.17.1.4.1.5.6 = Counter32: 0
SNMPv2-SMI::mib-2.17.1.4.1.5.7 = Counter32: 0
SNMPv2-SMI::mib-2.17.1.4.1.5.8 = Counter32: 0
SNMPv2-SMI::mib-2.17.1.4.1.5.9 = Counter32: 0
SNMPv2-SMI::mib-2.17.2.15.1.1.5 = INTEGER: 5
SNMPv2-SMI::mib-2.17.2.15.1.1.6 = INTEGER: 6
SNMPv2-SMI::mib-2.17.2.15.1.1.7 = INTEGER: 7
SNMPv2-SMI::mib-2.17.2.15.1.1.8 = INTEGER: 8
SNMPv2-SMI::mib-2.17.2.15.1.1.9 = INTEGER: 9
SNMPv2-SMI::mib-2.17.2.15.1.2.5 = INTEGER: 128
SNMPv2-SMI::mib-2.17.2.15.1.2.6 = INTEGER: 128
SNMPv2-SMI::mib-2.17.2.15.1.2.7 = INTEGER: 128
SNMPv2-SMI::mib-2.17.2.15.1.2.8 = INTEGER: 128
SNMPv2-SMI::mib-2.17.2.15.1.2.9 = INTEGER: 128
SNMPv2-SMI::mib-2.17.2.15.1.3.5 = INTEGER: 1
SNMPv2-SMI::mib-2.17.2.15.1.3.6 = INTEGER: 1
SNMPv2-SMI::mib-2.17.2.15.1.3.7 = INTEGER: 1
SNMPv2-SMI::mib-2.17.2.15.1.3.8 = INTEGER: 1
SNMPv2-SMI::mib-2.17.2.15.1.3.9 = INTEGER: 1
SNMPv2-SMI::mib-2.17.2.15.1.4.5 = INTEGER: 2
SNMPv2-SMI::mib-2.17.2.15.1.4.6 = INTEGER: 2
SNMPv2-SMI::mib-2.17.2.15.1.4.7 = INTEGER: 2
SNMPv2-SMI::mib-2.17.2.15.1.4.8 = INTEGER: 2
SNMPv2-SMI::mib-2.17.2.15.1.4.9 = INTEGER: 2
SNMPv2-SMI::mib-2.17.2.15.1.5.5 = INTEGER: 33
SNMPv2-SMI::mib-2.17.2.15.1.5.6 = INTEGER: 33
SNMPv2-SMI::mib-2.17.2.15.1.5.7 = INTEGER: 33
SNMPv2-SMI::mib-2.17.2.15.1.5.8 = INTEGER: 4
SNMPv2-SMI::mib-2.17.2.15.1.5.9 = INTEGER: 4
SNMPv2-SMI::mib-2.17.2.15.1.6.5 = Hex-STRING: 00 00 00 00 00 00 00 00
SNMPv2-SMI::mib-2.17.2.15.1.6.6 = Hex-STRING: 00 00 00 00 00 00 00 00
SNMPv2-SMI::mib-2.17.2.15.1.6.7 = Hex-STRING: 00 00 00 00 00 00 00 00
SNMPv2-SMI::mib-2.17.2.15.1.6.8 = Hex-STRING: 00 00 00 00 00 00 00 00
SNMPv2-SMI::mib-2.17.2.15.1.6.9 = Hex-STRING: 00 00 00 00 00 00 00 00
SNMPv2-SMI::mib-2.17.2.15.1.7.5 = INTEGER: 0
SNMPv2-SMI::mib-2.17.2.15.1.7.6 = INTEGER: 0
SNMPv2-SMI::mib-2.17.2.15.1.7.7 = INTEGER: 0
SNMPv2-SMI::mib-2.17.2.15.1.7.8 = INTEGER: 0
SNMPv2-SMI::mib-2.17.2.15.1.7.9 = INTEGER: 0
SNMPv2-SMI::mib-2.17.2.15.1.8.5 = Hex-STRING: 00 00 00 00 00 00 00 00
SNMPv2-SMI::mib-2.17.2.15.1.8.6 = Hex-STRING: 00 00 00 00 00 00 00 00
SNMPv2-SMI::mib-2.17.2.15.1.8.7 = Hex-STRING: 00 00 00 00 00 00 00 00
SNMPv2-SMI::mib-2.17.2.15.1.8.8 = Hex-STRING: 00 00 00 00 00 00 00 00
SNMPv2-SMI::mib-2.17.2.15.1.8.9 = Hex-STRING: 00 00 00 00 00 00 00 00
SNMPv2-SMI::mib-2.17.2.15.1.9.5 = Hex-STRING: 00 00
SNMPv2-SMI::mib-2.17.2.15.1.9.6 = Hex-STRING: 00 00
SNMPv2-SMI::mib-2.17.2.15.1.9.7 = Hex-STRING: 00 00
SNMPv2-SMI::mib-2.17.2.15.1.9.8 = Hex-STRING: 00 00
SNMPv2-SMI::mib-2.17.2.15.1.9.9 = Hex-STRING: 00 00
SNMPv2-SMI::mib-2.17.2.15.1.10.5 = Counter32: 0
SNMPv2-SMI::mib-2.17.2.15.1.10.6 = Counter32: 0
SNMPv2-SMI::mib-2.17.2.15.1.10.7 = Counter32: 0
SNMPv2-SMI::mib-2.17.2.15.1.10.8 = Counter32: 0
SNMPv2-SMI::mib-2.17.2.15.1.10.9 = Counter32: 0
SNMPv2-SMI::mib-2.17.4.1.0 = Counter32: 0
SNMPv2-SMI::mib-2.17.4.2.0 = INTEGER: 300
SNMPv2-SMI::mib-2.17.4.3.1.1.28.145.72.46.155.100 = Hex-STRING:
SNMPv2-SMI::mib-2.17.4.3.1.1.52.226.253.14.53.44 = Hex-STRING:
SNMPv2-SMI::mib-2.17.4.3.1.1.72.81.183.190.106.44 = Hex-STRING:
SNMPv2-SMI::mib-2.17.4.3.1.1.100.154.190.98.130.231 = Hex-STRING:
SNMPv2-SMI::mib-2.17.4.3.1.1.128.134.242.66.86.88 = Hex-STRING:
SNMPv2-SMI::mib-2.17.4.3.1.1.128.134.242.66.89.25 = Hex-STRING:
SNMPv2-SMI::mib-2.17.4.3.1.1.128.134.242.66.236.158 = Hex-STRING:
SNMPv2-SMI::mib-2.17.4.3.1.1.164.49.53.227.87.17 = Hex-STRING:
SNMPv2-SMI::mib-2.17.4.3.1.1.184.83.172.173.235.43 = Hex-STRING:
SNMPv2-SMI::mib-2.17.4.3.1.2.28.145.72.46.155.100 = INTEGER: 7
SNMPv2-SMI::mib-2.17.4.3.1.2.52.226.253.14.53.44 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.2.64.78.54.38.131.77 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.2.72.81.183.190.106.44 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.2.100.154.190.98.130.231 = INTEGER: 7
SNMPv2-SMI::mib-2.17.4.3.1.2.128.134.242.66.86.88 = INTEGER: 7
SNMPv2-SMI::mib-2.17.4.3.1.2.128.134.242.66.89.25 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.2.128.134.242.66.236.158 = INTEGER: 7
SNMPv2-SMI::mib-2.17.4.3.1.2.164.49.53.227.87.17 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.2.184.83.172.173.235.43 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.3.28.145.72.46.155.100 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.3.52.226.253.14.53.44 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.3.64.78.54.38.131.77 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.3.72.81.183.190.106.44 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.3.100.154.190.98.130.231 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.3.128.134.242.66.86.88 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.3.128.134.242.66.89.25 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.3.128.134.242.66.236.158 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.3.164.49.53.227.87.17 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.3.1.3.184.83.172.173.235.43 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.4.1.1.5 = INTEGER: 5
SNMPv2-SMI::mib-2.17.4.4.1.1.6 = INTEGER: 6
SNMPv2-SMI::mib-2.17.4.4.1.1.7 = INTEGER: 7
SNMPv2-SMI::mib-2.17.4.4.1.1.8 = INTEGER: 8
SNMPv2-SMI::mib-2.17.4.4.1.1.9 = INTEGER: 9
SNMPv2-SMI::mib-2.17.4.4.1.2.5 = INTEGER: 1514
SNMPv2-SMI::mib-2.17.4.4.1.2.6 = INTEGER: 1514
SNMPv2-SMI::mib-2.17.4.4.1.2.7 = INTEGER: 1514
SNMPv2-SMI::mib-2.17.4.4.1.2.8 = INTEGER: 1782
SNMPv2-SMI::mib-2.17.4.4.1.2.9 = INTEGER: 1782
SNMPv2-SMI::mib-2.17.4.4.1.3.5 = Counter32: 50359295
SNMPv2-SMI::mib-2.17.4.4.1.3.6 = Counter32: 50359295
SNMPv2-SMI::mib-2.17.4.4.1.3.7 = Counter32: 295341730
SNMPv2-SMI::mib-2.17.4.4.1.3.8 = Counter32: 313387916
SNMPv2-SMI::mib-2.17.4.4.1.3.9 = Counter32: 313387916
SNMPv2-SMI::mib-2.17.4.4.1.4.5 = Counter32: 64774022
SNMPv2-SMI::mib-2.17.4.4.1.4.6 = Counter32: 64774022
SNMPv2-SMI::mib-2.17.4.4.1.4.7 = Counter32: 165924157
SNMPv2-SMI::mib-2.17.4.4.1.4.8 = Counter32: 308
SNMPv2-SMI::mib-2.17.4.4.1.4.9 = Counter32: 308
SNMPv2-SMI::mib-2.17.4.4.1.5.5 = Counter32: 0
SNMPv2-SMI::mib-2.17.4.4.1.5.6 = Counter32: 0
SNMPv2-SMI::mib-2.17.4.4.1.5.7 = Counter32: 0
SNMPv2-SMI::mib-2.17.4.4.1.5.8 = Counter32: 0
SNMPv2-SMI::mib-2.17.4.4.1.5.9 = Counter32: 0
SNMPv2-SMI::mib-2.17.7.1.1.1.0 = INTEGER: 1
SNMPv2-SMI::mib-2.17.7.1.1.2.0 = INTEGER: 4095
SNMPv2-SMI::mib-2.17.7.1.1.3.0 = Gauge32: 16
SNMPv2-SMI::mib-2.17.7.1.1.4.0 = Gauge32: 3
SNMPv2-SMI::mib-2.17.7.1.1.5.0 = INTEGER: 2
SNMPv2-SMI::mib-2.17.7.1.2.1.1.2.1 = Counter32: 0
SNMPv2-SMI::mib-2.17.7.1.2.1.1.2.254 = Counter32: 0
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.1.28.145.72.46.155.100 = INTEGER: 7
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.1.52.226.253.14.53.44 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.1.64.78.54.38.131.77 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.1.72.81.183.190.106.44 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.1.100.154.190.98.130.231 = INTEGER: 7
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.1.128.134.242.66.86.88 = INTEGER: 7
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.1.128.134.242.66.89.25 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.1.128.134.242.66.236.158 = INTEGER: 7
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.1.164.49.53.227.87.17 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.2.1.184.83.172.173.235.43 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.3.1.28.145.72.46.155.100 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.3.1.52.226.253.14.53.44 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.3.1.64.78.54.38.131.77 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.3.1.72.81.183.190.106.44 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.3.1.100.154.190.98.130.231 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.3.1.128.134.242.66.86.88 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.3.1.128.134.242.66.89.25 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.3.1.128.134.242.66.236.158 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.3.1.164.49.53.227.87.17 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.2.2.1.3.1.184.83.172.173.235.43 = INTEGER: 5
SNMPv2-SMI::mib-2.17.7.1.4.2.1.3.0.1 = Gauge32: 0
SNMPv2-SMI::mib-2.17.7.1.4.2.1.3.0.4000 = Gauge32: 1
SNMPv2-SMI::mib-2.17.7.1.4.2.1.3.0.4001 = Gauge32: 254
SNMPv2-SMI::mib-2.17.7.1.4.2.1.4.0.1 = Hex-STRING: 00 00
SNMPv2-SMI::mib-2.17.7.1.4.2.1.4.0.4000 = Hex-STRING: 0B 00
SNMPv2-SMI::mib-2.17.7.1.4.2.1.4.0.4001 = Hex-STRING: 04 80
SNMPv2-SMI::mib-2.17.7.1.4.2.1.5.0.1 = Hex-STRING: 00 00
SNMPv2-SMI::mib-2.17.7.1.4.2.1.5.0.4000 = Hex-STRING: 0B 00
SNMPv2-SMI::mib-2.17.7.1.4.2.1.5.0.4001 = Hex-STRING: 00 00
SNMPv2-SMI::mib-2.17.7.1.4.2.1.6.0.1 = INTEGER: 2
SNMPv2-SMI::mib-2.17.7.1.4.2.1.6.0.4000 = INTEGER: 2
SNMPv2-SMI::mib-2.17.7.1.4.2.1.6.0.4001 = INTEGER: 2
SNMPv2-SMI::mib-2.17.7.1.4.2.1.7.0.1 = Timeticks: (0) 0:00:00.00
SNMPv2-SMI::mib-2.17.7.1.4.2.1.7.0.4000 = Timeticks: (0) 0:00:00.00
SNMPv2-SMI::mib-2.17.7.1.4.2.1.7.0.4001 = Timeticks: (0) 0:00:00.00
SNMPv2-SMI::mib-2.17.7.1.4.5.1.1.5 = INTEGER: 0
SNMPv2-SMI::mib-2.17.7.1.4.5.1.1.6 = INTEGER: 0
SNMPv2-SMI::mib-2.17.7.1.4.5.1.1.7 = INTEGER: 0
SNMPv2-SMI::mib-2.17.7.1.4.5.1.1.8 = INTEGER: 0
SNMPv2-SMI::mib-2.17.7.1.4.5.1.1.9 = INTEGER: 0
IF-MIB::ifName.1 = STRING: Do0
IF-MIB::ifName.2 = STRING: Do1
IF-MIB::ifName.3 = STRING: Gi0
IF-MIB::ifName.4 = STRING: Nu0
IF-MIB::ifName.5 = STRING: Do0.4000
IF-MIB::ifName.6 = STRING: Do0.4001
IF-MIB::ifName.7 = STRING: Do1.4000
IF-MIB::ifName.8 = STRING: Gi0.4000
IF-MIB::ifName.9 = STRING: Gi0.4001
IF-MIB::ifName.10 = STRING: BV1
IF-MIB::ifInMulticastPkts.1 = Counter32: 332
IF-MIB::ifInMulticastPkts.2 = Counter32: 336
IF-MIB::ifInMulticastPkts.3 = Counter32: 6110
IF-MIB::ifInMulticastPkts.4 = Counter32: 0
IF-MIB::ifInMulticastPkts.5 = Counter32: 397535
IF-MIB::ifInMulticastPkts.6 = Counter32: 23616
IF-MIB::ifInMulticastPkts.7 = Counter32: 626489
IF-MIB::ifInMulticastPkts.8 = Counter32: 0
IF-MIB::ifInMulticastPkts.9 = Counter32: 3173431
IF-MIB::ifInMulticastPkts.10 = Counter32: 0
IF-MIB::ifInBroadcastPkts.1 = Counter32: 736761
IF-MIB::ifInBroadcastPkts.2 = Counter32: 1033813
IF-MIB::ifInBroadcastPkts.3 = Counter32: 150268371
IF-MIB::ifInBroadcastPkts.4 = Counter32: 0
IF-MIB::ifInBroadcastPkts.5 = Counter32: 150094
IF-MIB::ifInBroadcastPkts.6 = Counter32: 15427
IF-MIB::ifInBroadcastPkts.7 = Counter32: 203670
IF-MIB::ifInBroadcastPkts.8 = Counter32: 0
IF-MIB::ifInBroadcastPkts.9 = Counter32: 503836
IF-MIB::ifInBroadcastPkts.10 = Counter32: 0
IF-MIB::ifOutMulticastPkts.1 = Counter32: 6626540
IF-MIB::ifOutMulticastPkts.2 = Counter32: 7945981
IF-MIB::ifOutMulticastPkts.3 = Counter32: 1127476
IF-MIB::ifOutMulticastPkts.4 = Counter32: 0
IF-MIB::ifOutMulticastPkts.5 = Counter32: 11263225
IF-MIB::ifOutMulticastPkts.6 = Counter32: 3103405
IF-MIB::ifOutMulticastPkts.7 = Counter32: 11258871
IF-MIB::ifOutMulticastPkts.8 = Counter32: 1047614
IF-MIB::ifOutMulticastPkts.9 = Counter32: 23616
IF-MIB::ifOutMulticastPkts.10 = Counter32: 23588
IF-MIB::ifOutBroadcastPkts.1 = Counter32: 28290162
IF-MIB::ifOutBroadcastPkts.2 = Counter32: 41611713
IF-MIB::ifOutBroadcastPkts.3 = Counter32: 369201
IF-MIB::ifOutBroadcastPkts.4 = Counter32: 0
IF-MIB::ifOutBroadcastPkts.5 = Counter32: 68936944
IF-MIB::ifOutBroadcastPkts.6 = Counter32: 516311
IF-MIB::ifOutBroadcastPkts.7 = Counter32: 68940332
IF-MIB::ifOutBroadcastPkts.8 = Counter32: 353770
IF-MIB::ifOutBroadcastPkts.9 = Counter32: 15427
IF-MIB::ifOutBroadcastPkts.10 = Counter32: 5
IF-MIB::ifHCInOctets.1 = Counter64: 20159766681
IF-MIB::ifHCInOctets.2 = Counter64: 324570805599
IF-MIB::ifHCInOctets.3 = Counter64: 169397675468
IF-MIB::ifHCInOctets.5 = Counter64: 15357524978
IF-MIB::ifHCInOctets.6 = Counter64: 3440096233
IF-MIB::ifHCInOctets.7 = Counter64: 325447830009
IF-MIB::ifHCInOctets.8 = Counter64: 0
IF-MIB::ifHCInOctets.9 = Counter64: 5388641079
IF-MIB::ifHCInOctets.10 = Counter64: 78561036
IF-MIB::ifHCInUcastPkts.1 = Counter64: 56858935
IF-MIB::ifHCInUcastPkts.2 = Counter64: 295696135
IF-MIB::ifHCInUcastPkts.3 = Counter64: 232544924
IF-MIB::ifHCInUcastPkts.5 = Counter64: 36342043
IF-MIB::ifHCInUcastPkts.6 = Counter64: 13553201
IF-MIB::ifHCInUcastPkts.7 = Counter64: 294542310
IF-MIB::ifHCInUcastPkts.8 = Counter64: 0
IF-MIB::ifHCInUcastPkts.9 = Counter64: 11840114
IF-MIB::ifHCInUcastPkts.10 = Counter64: 907354
IF-MIB::ifHCInMulticastPkts.1 = Counter64: 332
IF-MIB::ifHCInMulticastPkts.2 = Counter64: 336
IF-MIB::ifHCInMulticastPkts.3 = Counter64: 6110
IF-MIB::ifHCInMulticastPkts.5 = Counter64: 397535
IF-MIB::ifHCInMulticastPkts.6 = Counter64: 23616
IF-MIB::ifHCInMulticastPkts.7 = Counter64: 626489
IF-MIB::ifHCInMulticastPkts.8 = Counter64: 0
IF-MIB::ifHCInMulticastPkts.9 = Counter64: 3173431
IF-MIB::ifHCInMulticastPkts.10 = Counter64: 0
IF-MIB::ifHCInBroadcastPkts.1 = Counter64: 736761
IF-MIB::ifHCInBroadcastPkts.2 = Counter64: 1033813
IF-MIB::ifHCInBroadcastPkts.3 = Counter64: 150268371
IF-MIB::ifHCInBroadcastPkts.5 = Counter64: 150094
IF-MIB::ifHCInBroadcastPkts.6 = Counter64: 15427
IF-MIB::ifHCInBroadcastPkts.7 = Counter64: 203670
IF-MIB::ifHCInBroadcastPkts.8 = Counter64: 0
IF-MIB::ifHCInBroadcastPkts.9 = Counter64: 503836
IF-MIB::ifHCInBroadcastPkts.10 = Counter64: 0
IF-MIB::ifHCOutOctets.1 = Counter64: 54084807917
IF-MIB::ifHCOutOctets.2 = Counter64: 119764534526
IF-MIB::ifHCOutOctets.3 = Counter64: 342952296674
IF-MIB::ifHCOutOctets.5 = Counter64: 49585938903
IF-MIB::ifHCOutOctets.6 = Counter64: 5386168763
IF-MIB::ifHCOutOctets.7 = Counter64: 116325950655
IF-MIB::ifHCOutOctets.8 = Counter64: 339469269841
IF-MIB::ifHCOutOctets.9 = Counter64: 3441191974
IF-MIB::ifHCOutOctets.10 = Counter64: 78561516
IF-MIB::ifHCOutUcastPkts.1 = Counter64: 65112582
IF-MIB::ifHCOutUcastPkts.2 = Counter64: 166107594
IF-MIB::ifHCOutUcastPkts.3 = Counter64: 345217803
IF-MIB::ifHCOutUcastPkts.5 = Counter64: 53223165
IF-MIB::ifHCOutUcastPkts.6 = Counter64: 11684023
IF-MIB::ifHCOutUcastPkts.7 = Counter64: 165953083
IF-MIB::ifHCOutUcastPkts.8 = Counter64: 331382130
IF-MIB::ifHCOutUcastPkts.9 = Counter64: 13551445
IF-MIB::ifHCOutUcastPkts.10 = Counter64: 883769
IF-MIB::ifHCOutMulticastPkts.1 = Counter64: 6626540
IF-MIB::ifHCOutMulticastPkts.2 = Counter64: 7945981
IF-MIB::ifHCOutMulticastPkts.3 = Counter64: 1127476
IF-MIB::ifHCOutMulticastPkts.5 = Counter64: 11263225
IF-MIB::ifHCOutMulticastPkts.6 = Counter64: 3103405
IF-MIB::ifHCOutMulticastPkts.7 = Counter64: 11258871
IF-MIB::ifHCOutMulticastPkts.8 = Counter64: 1047614
IF-MIB::ifHCOutMulticastPkts.9 = Counter64: 23616
IF-MIB::ifHCOutMulticastPkts.10 = Counter64: 23588
IF-MIB::ifHCOutBroadcastPkts.1 = Counter64: 28290162
IF-MIB::ifHCOutBroadcastPkts.2 = Counter64: 41611713
IF-MIB::ifHCOutBroadcastPkts.3 = Counter64: 369201
IF-MIB::ifHCOutBroadcastPkts.5 = Counter64: 68936944
IF-MIB::ifHCOutBroadcastPkts.6 = Counter64: 516311
IF-MIB::ifHCOutBroadcastPkts.7 = Counter64: 68940332
IF-MIB::ifHCOutBroadcastPkts.8 = Counter64: 353770
IF-MIB::ifHCOutBroadcastPkts.9 = Counter64: 15427
IF-MIB::ifHCOutBroadcastPkts.10 = Counter64: 5
IF-MIB::ifLinkUpDownTrapEnable.1 = INTEGER: enabled(1)
IF-MIB::ifLinkUpDownTrapEnable.2 = INTEGER: enabled(1)
IF-MIB::ifLinkUpDownTrapEnable.3 = INTEGER: enabled(1)
IF-MIB::ifLinkUpDownTrapEnable.4 = INTEGER: enabled(1)
IF-MIB::ifLinkUpDownTrapEnable.5 = INTEGER: disabled(2)
IF-MIB::ifLinkUpDownTrapEnable.6 = INTEGER: disabled(2)
IF-MIB::ifLinkUpDownTrapEnable.7 = INTEGER: disabled(2)
IF-MIB::ifLinkUpDownTrapEnable.8 = INTEGER: disabled(2)
IF-MIB::ifLinkUpDownTrapEnable.9 = INTEGER: disabled(2)
IF-MIB::ifLinkUpDownTrapEnable.10 = INTEGER: enabled(1)
IF-MIB::ifHighSpeed.1 = Gauge32: 54
IF-MIB::ifHighSpeed.2 = Gauge32: 54
IF-MIB::ifHighSpeed.3 = Gauge32: 1000
IF-MIB::ifHighSpeed.4 = Gauge32: 10000
IF-MIB::ifHighSpeed.5 = Gauge32: 54
IF-MIB::ifHighSpeed.6 = Gauge32: 54
IF-MIB::ifHighSpeed.7 = Gauge32: 54
IF-MIB::ifHighSpeed.8 = Gauge32: 1000
IF-MIB::ifHighSpeed.9 = Gauge32: 1000
IF-MIB::ifHighSpeed.10 = Gauge32: 54
IF-MIB::ifPromiscuousMode.1 = INTEGER: false(2)
IF-MIB::ifPromiscuousMode.2 = INTEGER: false(2)
IF-MIB::ifPromiscuousMode.3 = INTEGER: false(2)
IF-MIB::ifPromiscuousMode.4 = INTEGER: false(2)
IF-MIB::ifPromiscuousMode.5 = INTEGER: false(2)
IF-MIB::ifPromiscuousMode.6 = INTEGER: false(2)
IF-MIB::ifPromiscuousMode.7 = INTEGER: false(2)
IF-MIB::ifPromiscuousMode.8 = INTEGER: false(2)
IF-MIB::ifPromiscuousMode.9 = INTEGER: false(2)
IF-MIB::ifPromiscuousMode.10 = INTEGER: false(2)
IF-MIB::ifConnectorPresent.1 = INTEGER: true(1)
IF-MIB::ifConnectorPresent.2 = INTEGER: true(1)
IF-MIB::ifConnectorPresent.3 = INTEGER: true(1)
IF-MIB::ifConnectorPresent.4 = INTEGER: false(2)
IF-MIB::ifConnectorPresent.5 = INTEGER: false(2)
IF-MIB::ifConnectorPresent.6 = INTEGER: false(2)
IF-MIB::ifConnectorPresent.7 = INTEGER: false(2)
IF-MIB::ifConnectorPresent.8 = INTEGER: false(2)
IF-MIB::ifConnectorPresent.9 = INTEGER: false(2)
IF-MIB::ifConnectorPresent.10 = INTEGER: false(2)
IF-MIB::ifAlias.1 = STRING:
IF-MIB::ifAlias.2 = STRING:
IF-MIB::ifAlias.3 = STRING:
IF-MIB::ifAlias.4 = STRING:
IF-MIB::ifAlias.5 = STRING:
IF-MIB::ifAlias.6 = STRING:
IF-MIB::ifAlias.7 = STRING:
IF-MIB::ifAlias.8 = STRING:
IF-MIB::ifAlias.9 = STRING:
IF-MIB::ifAlias.10 = STRING:
IF-MIB::ifCounterDiscontinuityTime.1 = Timeticks: (0) 0:00:00.00
IF-MIB::ifCounterDiscontinuityTime.2 = Timeticks: (0) 0:00:00.00
IF-MIB::ifCounterDiscontinuityTime.3 = Timeticks: (0) 0:00:00.00
IF-MIB::ifCounterDiscontinuityTime.4 = Timeticks: (0) 0:00:00.00
IF-MIB::ifCounterDiscontinuityTime.5 = Timeticks: (0) 0:00:00.00
IF-MIB::ifCounterDiscontinuityTime.6 = Timeticks: (0) 0:00:00.00
IF-MIB::ifCounterDiscontinuityTime.7 = Timeticks: (0) 0:00:00.00
IF-MIB::ifCounterDiscontinuityTime.8 = Timeticks: (0) 0:00:00.00
IF-MIB::ifCounterDiscontinuityTime.9 = Timeticks: (0) 0:00:00.00
IF-MIB::ifCounterDiscontinuityTime.10 = Timeticks: (0) 0:00:00.00
IF-MIB::ifStackStatus.0.4 = INTEGER: active(1)
IF-MIB::ifStackStatus.0.5 = INTEGER: active(1)
IF-MIB::ifStackStatus.0.6 = INTEGER: active(1)
IF-MIB::ifStackStatus.0.7 = INTEGER: active(1)
IF-MIB::ifStackStatus.0.8 = INTEGER: active(1)
IF-MIB::ifStackStatus.0.9 = INTEGER: active(1)
IF-MIB::ifStackStatus.0.10 = INTEGER: active(1)
IF-MIB::ifStackStatus.1.0 = INTEGER: active(1)
IF-MIB::ifStackStatus.2.0 = INTEGER: active(1)
IF-MIB::ifStackStatus.3.0 = INTEGER: active(1)
IF-MIB::ifStackStatus.4.0 = INTEGER: active(1)
IF-MIB::ifStackStatus.5.1 = INTEGER: active(1)
IF-MIB::ifStackStatus.6.1 = INTEGER: active(1)
IF-MIB::ifStackStatus.7.2 = INTEGER: active(1)
IF-MIB::ifStackStatus.8.3 = INTEGER: active(1)
IF-MIB::ifStackStatus.9.3 = INTEGER: active(1)
IF-MIB::ifStackStatus.10.0 = INTEGER: active(1)
IF-MIB::ifRcvAddressStatus.1."l...~." = INTEGER: active(1)
IF-MIB::ifRcvAddressStatus.1."......" = INTEGER: active(1)
IF-MIB::ifRcvAddressStatus.2."l....." = INTEGER: active(1)
IF-MIB::ifRcvAddressStatus.2."......" = INTEGER: active(1)
IF-MIB::ifRcvAddressStatus.3."P...}J" = INTEGER: active(1)
IF-MIB::ifRcvAddressStatus.3."......" = INTEGER: active(1)
IF-MIB::ifRcvAddressType.1."l...~." = INTEGER: other(1)
IF-MIB::ifRcvAddressType.1."......" = INTEGER: other(1)
IF-MIB::ifRcvAddressType.2."l....." = INTEGER: other(1)
IF-MIB::ifRcvAddressType.2."......" = INTEGER: other(1)
IF-MIB::ifRcvAddressType.3."P...}J" = INTEGER: other(1)
IF-MIB::ifRcvAddressType.3."......" = INTEGER: other(1)
IF-MIB::ifTableLastChange.0 = Timeticks: (2797) 0:00:27.97
IF-MIB::ifStackLastChange.0 = Timeticks: (2797) 0:00:27.97
SNMPv2-SMI::mib-2.47.1.1.1.1.2.1 = STRING: "Cisco Aironet 2600 Series (IEEE 802.11n) Access Point"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.2 = STRING: "802.11N 2.4GHz Radio"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.3 = STRING: "802.11N 5GHz Radio"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.4 = STRING: "PowerPC Ethernet"
SNMPv2-SMI::mib-2.47.1.1.1.1.3.1 = OID: SNMPv2-SMI::enterprises.9.12.3.1.3.1
SNMPv2-SMI::mib-2.47.1.1.1.1.3.2 = OID: SNMPv2-SMI::enterprises.9.12.3.1.10.302
SNMPv2-SMI::mib-2.47.1.1.1.1.3.3 = OID: SNMPv2-SMI::enterprises.9.12.3.1.10.302
SNMPv2-SMI::mib-2.47.1.1.1.1.3.4 = OID: SNMPv2-SMI::enterprises.9.12.3.1.10.100
SNMPv2-SMI::mib-2.47.1.1.1.1.4.1 = INTEGER: 0
SNMPv2-SMI::mib-2.47.1.1.1.1.4.2 = INTEGER: 1
SNMPv2-SMI::mib-2.47.1.1.1.1.4.3 = INTEGER: 1
SNMPv2-SMI::mib-2.47.1.1.1.1.4.4 = INTEGER: 1
SNMPv2-SMI::mib-2.47.1.1.1.1.5.1 = INTEGER: 3
SNMPv2-SMI::mib-2.47.1.1.1.1.5.2 = INTEGER: 10
SNMPv2-SMI::mib-2.47.1.1.1.1.5.3 = INTEGER: 10
SNMPv2-SMI::mib-2.47.1.1.1.1.5.4 = INTEGER: 10
SNMPv2-SMI::mib-2.47.1.1.1.1.6.1 = INTEGER: -1
SNMPv2-SMI::mib-2.47.1.1.1.1.6.2 = INTEGER: 0
SNMPv2-SMI::mib-2.47.1.1.1.1.6.3 = INTEGER: 1
SNMPv2-SMI::mib-2.47.1.1.1.1.6.4 = INTEGER: -1
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1 = STRING: "AP2600"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.2 = STRING: "Dot11Radio0"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3 = STRING: "Dot11Radio1"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.4 = STRING: "GigabitEthernet0"
SNMPv2-SMI::mib-2.47.1.1.1.1.8.1 = STRING: "V02"
SNMPv2-SMI::mib-2.47.1.1.1.1.8.2 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.8.3 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.8.4 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.9.1 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.9.2 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.9.3 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.9.4 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.10.1 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.10.2 = STRING: "418.2"
SNMPv2-SMI::mib-2.47.1.1.1.1.10.3 = STRING: "418.2"
SNMPv2-SMI::mib-2.47.1.1.1.1.10.4 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.11.1 = STRING: ""
SNMPv2-SMI::mib-2.47.1.1.1.1.11.2 = STRING: ""
SNMPv2-SMI::mib-2.47.1.1.1.1.11.3 = STRING: ""
SNMPv2-SMI::mib-2.47.1.1.1.1.11.4 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.12.1 = STRING: ""
SNMPv2-SMI::mib-2.47.1.1.1.1.12.2 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.12.3 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.12.4 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.13.1 = STRING: "AIR-SAP2602I-E-K9 "
SNMPv2-SMI::mib-2.47.1.1.1.1.13.2 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.13.3 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.13.4 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.14.1 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.14.2 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.14.3 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.14.4 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.15.1 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.15.2 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.15.3 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.15.4 = ""
SNMPv2-SMI::mib-2.47.1.1.1.1.16.1 = INTEGER: 2
SNMPv2-SMI::mib-2.47.1.1.1.1.16.2 = INTEGER: 2
SNMPv2-SMI::mib-2.47.1.1.1.1.16.3 = INTEGER: 2
SNMPv2-SMI::mib-2.47.1.1.1.1.16.4 = INTEGER: 2
SNMPv2-SMI::mib-2.47.1.2.1.1.2.1 = STRING: "default logical entity for AIR-SAP2602I-E-K9 platform"
SNMPv2-SMI::mib-2.47.1.2.1.1.3.1 = OID: SNMPv2-SMI::mib-2
SNMPv2-SMI::mib-2.47.1.2.1.1.4.1 = STRING: "spice"
SNMPv2-SMI::mib-2.47.1.2.1.1.5.1 = Hex-STRING:
SNMPv2-SMI::mib-2.47.1.2.1.1.6.1 = OID: SNMPv2-TM::snmpUDPDomain
SNMPv2-SMI::mib-2.47.1.2.1.1.7.1 = Hex-STRING:
SNMPv2-SMI::mib-2.47.1.2.1.1.8.1 = ""
SNMPv2-SMI::mib-2.47.1.3.2.1.2.2.0 = OID: IF-MIB::ifIndex.1
SNMPv2-SMI::mib-2.47.1.3.2.1.2.3.0 = OID: IF-MIB::ifIndex.2
SNMPv2-SMI::mib-2.47.1.3.2.1.2.4.0 = OID: IF-MIB::ifIndex.3
SNMPv2-SMI::mib-2.47.1.3.3.1.1.1.2 = INTEGER: 2
SNMPv2-SMI::mib-2.47.1.3.3.1.1.1.3 = INTEGER: 3
SNMPv2-SMI::mib-2.47.1.3.3.1.1.1.4 = INTEGER: 4
SNMPv2-SMI::mib-2.47.1.4.1.0 = Timeticks: (2820) 0:00:28.20
NOTIFICATION-LOG-MIB::nlmConfigGlobalEntryLimit.0 = Gauge32: 500
NOTIFICATION-LOG-MIB::nlmConfigGlobalAgeOut.0 = Gauge32: 15 minutes
NOTIFICATION-LOG-MIB::nlmStatsGlobalNotificationsLogged.0 = Counter32: 0 notifications
NOTIFICATION-LOG-MIB::nlmStatsGlobalNotificationsBumped.0 = Counter32: 0 notifications
 What happen here is that you are reading a directiory. For that, you can read the whole directory or you can jump inside a small directory and read what is inside.
For example, I want to read only the AP uptime on my network:
SNMPv2-SMI::enterprises.9.9.513.1.1.1.1.6.12.133.37.52.4.0 = Timeticks: (301917678) 34 days, 22:39:36.78
SNMPv2-SMI::enterprises.9.9.513.1.1.1.1.6.12.133.37.52.5.224 = Timeticks: (323408278) 37 days, 10:21:22.78
SNMPv2-SMI::enterprises.9.9.513.1.1.1.1.6.12.133.37.52.6.96 = Timeticks: (27239078) 3 days, 3:39:50.78
SNMPv2-SMI::enterprises.9.9.513.1.1.1.1.6.12.133.37.52.8.224 = Timeticks: (1145661079) 132 days, 14:23:30.79
SNMPv2-SMI::enterprises.9.9.513.1.1.1.1.6.12.133.37.52.14.160 = Timeticks: (52722879) 6 days, 2:27:08.79
SNMPv2-SMI::enterprises.9.9.513.1.1.1.1.6.12.133.37.52.15.32 = Timeticks: (220380780) 25 days, 12:10:07.80
SNMPv2-SMI::enterprises.9.9.513.1.1.1.1.6.12.133.37.52.15.64 = Timeticks: (364122080) 42 days, 3:27:00.80
SNMPv2-SMI::enterprises.9.9.513.1.1.1.1.6.12.133.37.52.15.192 = Timeticks: (34767580) 4 days, 0:34:35.80
SNMPv2-SMI::enterprises.9.9.513.1.1.1.1.6.12.133.37.52.17.128 = Timeticks: (755679881) 87 days, 11:06:38.81
SNMPv2-SMI::enterprises.9.9.513.1.1.1.1.6.12.133.37.52.18.224 = Timeticks: (299924081) 34 days, 17:07:20.81
Now, you are inside the "UPTIME" Directory and you can retrieve data.
I sent to the WLC the OID 1.3.6.1.4.1.9.9.513.1.1.1.1.6 and he gave me back the information about uptime.
That´s the idea. You need to find out which information you want to retrieve and which OID can do that.
Allright, and how to find out for a standalone AP if there is no WLC?
Thanks.
I have no standalone AP here that's why I used WLC but bear in mind that the idea is the same.
 You need to get the AP model MIB and install a SNMP parser in order to identify the OIDs, then, you can use an script to pull data.
Allright, but where can I get this MIB data from or which one do I need from ftp://ftp.cisco.com/pub/mibs/v2/ ?
Kay
You need to look for MIB related to your AP Model. As I said, you can use a software like Paessler MIB Importer V3 to open up the MIB and seach for which OID do what you need.
cDot11AssStatsAssociated OBJECT-TYPE
SYNTAX Counter32
UNITS "client"
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"This object counts the number of stations
associated with this device on this interface
since device re-started."
::= { cDot11AssociationStatsEntry 1 }
cDot11AssStatsAuthenticated OBJECT-TYPE
SYNTAX Counter32
UNITS "client"
STATUS current
DESCRIPTION
authenticated with this device on this interface
::= { cDot11AssociationStatsEntry 2 }
The OID for Active Clients is 1.3.6.1.4.1.9.9.273.1.1.2.1.1
On the FTP server are hundrets of MIB files where I can't find any file named similar to the AP model we use. It is very difficult to get an overview here.
Even if I import a random MIB file to the Paessler program, I don't see anything useful and if I try random OID's the device replys its not existing.
I don't want anybody to search for me, I just want to understand the logic behind to be able to figure by myself.
Flavio, thanks a lot for your help!
