Cisco aironet ant2566d4m compatibility
g.ska
Hi everyone,
First question: I'd like to know if the "old" Aironet 3702e or p is compatible with this patch antenna: ANT2566D4M or if I need to buy the new 3802e or p antenna?
Second question: What about a WLC 2504 in version 8.0.121. Is it compatible with the new ap (3800 series)??
Many thanks,
Greg.
Leo Laohoo
ANT2566D4M has four pig-tail antennas.  This model of antenna should be compatible with the 3802E.
3802 AP is supported starting from 8.2.111.0.  So the firmware of the CT2504 needs to be upgraded.
Ok thank you very much for the information.
Best regards,
Greg.
