03-20-2022 11:41 PM
When i configure the ap with Static IP it takes IP and Starts ping in local network but it cant join WLC.
03-20-2022 11:45 PM
what is the OS version in WLC
03-20-2022 11:47 PM
8.5.131.0
03-21-2022 12:01 AM
according to matrix, its compatible with OS.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
you need to check WLC logs and AP console output to find out what is the reason for not joining. check controller date and time accuracy.
03-21-2022 12:26 AM
2021 08:24:59.8185] Failed to send capwap message 0 to the state machine. Packet already freed.
[*07/26/2021 08:24:59.8185] IPv4 wtpProcessPacketFromSocket returned 4
[*07/26/2021 08:24:59.8185] Discovery Response from 10.115.45.3
[*07/26/2021 08:24:59.8185] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*07/26/2021 08:24:59.8185] Failed to decode discovery response(status = 4).
[*07/26/2021 08:24:59.8185] CAPWAP SM handler: Failed to process message type 2 state 2.
[*07/26/2021 08:24:59.8185] Failed to handle capwap control message from controller - status 4
[*07/26/2021 08:24:59.8185] Failed to process unencrypted capwap packet 0x1c84000 from 10.115.45.3
[*07/26/2021 08:24:59.8185] Failed to send message to CAPWAP state machine, msgId 0
[*07/26/2021 08:24:59.8185] Failed to send capwap message 0 to the state machine. Packet already freed.
[*07/26/2021 08:25:09.3156]
[*07/26/2021 08:25:09.3156] CAPWAP State: Discovery
[*07/26/2021 08:25:09.3256] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/26/2021 08:25:09.3256] Discovery Response from 10.115.45.4
[*07/26/2021 08:25:09.3256] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*07/26/2021 08:25:09.3256] Failed to decode discovery response(status = 4).
[*07/26/2021 08:25:09.3256] CAPWAP SM handler: Failed to process message type 2 state 2.
[*07/26/2021 08:25:09.3256] Failed to handle capwap control message from controller - status 4
[*07/26/2021 08:25:09.3256] Failed to process unencrypted capwap packet 0x1c86000 from 10.115.45.4
[*07/26/2021 08:25:09.3256] Failed to send message to CAPWAP state machine, msgId 0
[*07/26/2021 08:25:09.3256] Failed to send capwap message 0 to the state machine. Packet already freed.
[*07/26/2021 08:25:09.3256] IPv4 wtpProcessPacketFromSocket returned 4
[*07/26/2021 08:25:09.3256] Discovery Response from 10.115.45.3
[*07/26/2021 08:25:09.3256] Failed to process unencrypted capwap packet 0x1c81000 from 10.115.45.3
03-21-2022 12:39 AM
- Possibly : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvf71074 , check controller logs too
M.
03-21-2022 02:03 AM
seems like you are hitting bug. better open TAC or upgrade WLC to recent version.
03-21-2022 02:10 AM
Also check date/time settings if this is not an -T AP.
You still have free licenses on the WLC and selected the correct country?
03-21-2022 06:02 AM
Can you post a show version from the AP?
I would also suggest you to check the NTP in WLC and make sure it has synced and the time and date is current.
It has been noticed that some times Wave 2 AP's running certain older AIreOS codes (8.2.X) are not joining the WLC running 8.5 or higher. After confirming NTP I would suggest upgrading the AP manually to the same code as WLC. AP firmware can be found in the below doc.
Cisco Wireless Solutions Software Compatibility Matrix - Cisco
To upgrade the AP from AP CLI
archive download-sw tftp://<IP ADDRESS>/IOS_filename.tar
