Cisco AP 2802i Not Joining with WLC-2504
mohamednazar1
Hi All,
Cisco AP 2802I-E-K9, AP Running Image 8.2.130.0, Couldn't joint with WLC-2504 software version 8-2-130-0.But AIR-CAP2702I-E-K9 can register with WLC and working fine.  getting below error from the AP2802I
[*10/18/2016 11:01:43.6373] CAPWAP State: Discovery
[*10/18/2016 11:01:43.6390] Discovery Request sent to 255.255.255.255 with disco very type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*10/18/2016 11:01:43.6398] Discovery Response from 10.10.10.5
[*10/18/2016 11:01:53.0000] CAPWAP State: DTLS Setup
[*10/18/2016 11:01:54.6368] CAPWAP State: Join
[*10/18/2016 11:01:54.6379] Sending Join request to 10.10.10.5 through port 5256
[*10/18/2016 11:01:59.2746] Join Response from 10.10.10.5
[*10/18/2016 11:01:59.2747] CAPWAP State: Image Data
[*10/18/2016 11:01:59.2748] CAPWAP State: Configure
[*10/18/2016 11:01:59.3049] DTLS: packet too old or a replay distance=0, this_se q_num=1, last_seq_num=1
[*10/18/2016 11:02:44.8852] GOING BACK TO DISCOVER MODE
[*10/18/2016 11:02:44.8855] CAPWAP State: DTLS Teardown
[*10/18/2016 11:02:49.6374] CAPWAP State: Discovery
[*10/18/2016 11:02:49.6454] Discovery Request sent to 255.255.255.255 with disco very type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*10/18/2016 11:02:49.6463] Discovery Response from 10.10.10.5
[*10/18/2016 11:02:59.0000] CAPWAP State: DTLS Setup
[*10/18/2016 11:03:00.6204] CAPWAP State: Join
[*10/18/2016 11:03:00.6215] Sending Join request to 10.10.10.5 through port 5256
[*10/18/2016 11:03:05.2748] Join Response from 10.10.10.5
[*10/18/2016 11:03:05.2748] CAPWAP State: Image Data
[*10/18/2016 11:03:05.2749] CAPWAP State: Configure
[*10/18/2016 11:03:05.3029] DTLS: packet too old or a replay distance=0, this_se q_num=1, last_seq_num=1
Keep getting the same error. This is new installation and doesn't have Service contract witch Cisco.
Please advice
Mohamed Nazar
22 Replies 22
Sandeep Choudhary
paste the output of this commands:
1. sh sysinfo from wlc, also paste the complete boot up-process from AP console.
Dont forget to rate helpful posts
Hi Sandeep
Thanks for your support. Please find the attached Notepad for AP and controller logs.
Please advice.
Hi Mohemed,
i have exactly the same problem, did you find the solution ?
thank you.
Hi Sandeep,
Can you help us with this issue please?
Ajin.
Hi AJIN,
Normally for Kuwait your AP model should be : AP 2802I-I-K9
and you have AP 2802I-E-K9 -> Normally its for Europe.
Hi Sandeep,
So can I change the country in the controller and try associating the AP? Will it work? Is there any other workaround?
Hi Ajin,
As Rasika wrote....
AP is also using the wrong port to discover WLC.
Are you using IP helper command and IP forward-protocol udp <5246> command on switch ?
Hi Sandeep,
As this is a new setup, the AP is connected directly to the PoE port of the 2504 controller. And DHCP is configured in the switch which is connected to the controller, and no IP forward protocol command is used
Hi Ajin,
Its not a recommended solution to attach AP directly to WLC.
If you want to join AP, then you need to setup a dhcp scope on the wlc and make sure that it must be on the same network as the wlc management. The ap will get an ip address from the pool and join the wlc as long as everything else is configured correctly.
Hi Sandeep,
Let me give that a try. But I have a 2702I-E-K9 AP which got connected without any issue connecting directly to the controller. The problem is only with the AP2802I-E-K9
It appears to me as if the 2504 controller software does not have the correct image for the AP2802, but does have the right immage to send to the AP2702.
in the release notes of  8.0.140.0. the 2800 series is not mentioned (could be cosmetic)?
The following access point platforms are supported in this release:
  • Cisco Aironet 1040, 1130, 1140, 1240, 1250, 1260, 1600, 1700, 2600, 2700, 3500, 3600, 3700, Cisco 600 Series OfficeExtend, 700, AP801, and AP802 Series indoor access points
  • Cisco Aironet 1520 (1522, 1524), 1530, 1550 (1552), 1570, and Industrial Wireless 3700 Series outdoor and industrial wireless access point
sorry missed this info:
SwVer                              : 8.2.130.0
But as the error has to do with DTLS
maybe this helps
Downloading and Installing a DTLS License for an LDPE Cisco WLC
Step 1 To download the Cisco DTLS license:
a. Go to the Cisco Software Center at this URL:
https://tools.cisco.com/SWIFT/LicensingUI/Home
Hi Sandeep,
I have reset the controller, configured it with country Germany and timezone Berlin, created a DHCP scope, then connected it to a Cisco switch and also the AP to the switch. This time the AP has joined the controller without any hiccup but both the radios are showing DOWN! Please see the attached screenshot. How can we bring the radios up?
Did you try to enable manually to these Radios of AP by going here:
wireless > Access Point > Radios > 802.11a/n/c or 802.11b/g/n then on far right of each a blue drop down arrow box is there click on configure and enable the admin status.
