Cisco AP 9120 in deep green mode, no IP from DHCP
tomand
Hi! We have several Cisco AP 9120 AXI which is not joining WLC and the obvious reason is no IP. When connecting to the AP via console you will see what is shown below.
Other Aps on the same switch is working okay and all are new. I saw the is shipped with ver 8.10.x
We will run them on 17.6.2 on WLC 9800-CL
Have found a bug case with now solution https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvm96943
We have tried the old trick with IP-helper and IP forward protocol udp 5246 with no better result.
When we set the IP manually with wlc IP it works and register /upgrades software. If you then delete the static IP you are back in green mode again..
Anyone seen this and hopefully found a solution?
[*03/22/2022 14:32:30.3730] <=== Deactivate Deep Green Mode
[*03/22/2022 14:32:30.3730] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link UP
[*03/22/2022 14:32:45.7260] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link DOWN.
[*03/22/2022 14:32:45.7260] ===> Activate Deep Green Mode
[*03/22/2022 14:32:45.7260] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link DOWN
[*03/22/2022 14:32:47.8330] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link Up at 1000 mbps full duplex
[*03/22/2022 14:32:47.8330] <=== Deactivate Deep Green Mode
[*03/22/2022 14:32:47.8330] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link UP
[*03/22/2022 14:33:02.0820] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link DOWN.
[*03/22/2022 14:33:02.0820] ===> Activate Deep Green Mode
[*03/22/2022 14:33:02.0820] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link DOWN
[*03/22/2022 14:33:04.1890] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link Up at 1000 mbps full duplex
[*03/22/2022 14:33:04.1890] <=== Deactivate Deep Green Mode
[*03/22/2022 14:33:04.1890] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link UP
*03/23/2022 08:44:01.2970] ERROR: return from vap_amsdu_rx_max was -45
[*03/23/2022 08:44:01.6800] DOT11_DRV[1]: set_channel Channel set to 36/20
[*03/23/2022 08:44:02.3790] wl: Unsupported
[*03/23/2022 08:44:02.3790] ERROR: return from vap_amsdu_rx_max was -45
[*03/23/2022 08:44:02.7870] DOT11_DRV[1]: set_channel Channel set to 36/20
[*03/23/2022 08:44:02.9900] DOT11_DRV[1]: set_channel Channel set to 36/20
[*03/23/2022 08:44:03.6900] wl: Unsupported
[*03/23/2022 08:44:03.6910] ERROR: return from vap_amsdu_rx_max was -45
[*03/23/2022 08:44:04.0220] wl: Unsupported
[*03/23/2022 08:44:04.0220] ERROR: return from vap_amsdu_rx_max was -45
[*03/23/2022 08:44:04.6170] DOT11_DRV[1]: set_channel Channel set to 36/20
[*03/23/2022 08:44:07.7050] IOT Bootloader Flash Tool 1.4
[*03/23/2022 08:44:07.7050] Firmware upgrade initiated by ble_init
[*03/23/2022 08:44:07.7050] bundled_ver_split ['2', '7', '20']
[ OK ] Started BLE init service.
[ OK ] Reached target Multi-User System.
[*03/23/2022 08:44:26.1310] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link DOWN.
[*03/23/2022 08:44:26.1310] ===> Activate Deep Green Mode
[*03/23/2022 08:44:26.1310] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link DOWN
[*03/23/2022 08:44:28.2370] <=== Deactivate Deep Green Mode
[*03/23/2022 08:44:28.2370] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link UP
[*03/23/2022 08:44:28.2370] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link Up at 1000 mbps full duplex
[*03/23/2022 08:44:42.4870] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link DOWN.
[*03/23/2022 08:44:42.4870] ===> Activate Deep Green Mode
[*03/23/2022 08:44:42.4870] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link DOWN
[*03/23/2022 08:44:44.5930] <=== Deactivate Deep Green Mode
[*03/23/2022 08:44:44.5930] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link UP
[*03/23/2022 08:44:44.5930] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link Up at 1000 mbps full duplex
tomand
27 Replies 27
joshhunter
Level 4
Level 4
Hello All,
I am also having the same issue with Cisco 9115AXI brand new out of the box.
Most are working fine, but many refuse to obtain IP Addresses and sit looping in DARK GREEN MODE.
If I swap a 'bad' AP for a new AP out of the box, it will work fine. This seems to rule out port configuration, structured cabling, DHCP server etc.
I can get it to connect if I set a static IP Address and define the CAPWAP server address. If I remove the static configuration, the AP gets stuck again in the DHCP loop.
Additionally, I can see the DHCP Server offering a lease to the Access Point. I cannot make any sense of it. Also, had a few with corrupted boot image/partition; the known bug and work-around of deleting/re-creating the boot partition fixed those.
What is your switch port configuration?
Depending on switch port config some APs will work and some won't - element of luck.
The config we came up with from working with TAC which works for all our APs (about 23,000 APs):
interface <interface name>
 switchport trunk native vlan XXX
 switchport mode trunk
 spanning-tree portfast trunk
 spanning-tree portfast edge trunk
 spanning-tree bpdufilter enable
 spanning-tree bpduguard disable
 speed auto
 duplex auto
 cdp enable
end
portfast command variant depends on switch model/IOS version so both are there.
Obviously if you're running Local mode AP on access mode switchport then adjust the config accordingly.
The key points are portfast and the bpdu commands because if the port doesn't come up quickly enough or goes into blocking due to rogue bpdu's sent by the AP then the AP can't start.
Obviously you may also have other port config as required.
Hello, after further investigation, the Microsoft Server is marking entries with BAD ADDRESS, we only see this issue with new Access Points out of the box. From then onwards, after connecting to the Wireless Controller and upgrading their AP image we have not seen any DHCP Issue. So, the issue is only seen on new site roll outs where we are deploying new SD-WAN, New Switches and 20+ Access Points.
We suspect, this could possibly be the issue we are hitting. Either this, or due to the number of access points all requesting a DHCP Address at the same time (new project site install).
Cisco Bug: CSCvj14517
9800 support for "ap dhcp release-override" feature - interop with Microsoft DHCP servers
Symptom:
An access point sends three DHCP RELEASE packets, before attempting to get a new lease. This can happen when, for example, the AP is unable to join its controller for an extended period.
The DHCP server marks the address as "BAD_ADDRESS" ... after some time, as a result, the DHCP scope may run out of addresses.
Conditions:
This problem is seen with the following:
* controller is a 9800 (not AireOS)
* all AP models.
* DHCP server is Microsoft Windows 2008 or 2012 Server
https://quickview.cloudapps.cisco.com/quickview/bug/CSCwc32360
Hi @joshhunter you've listed 2 completely different bugs there.
CSCvj14517 is a well known issue with Cisco APs and Microsoft DHCP server which Cisco have decided not to fix on 9800.  So you either make sure you have a large enough pool to not run out or have regular maintenance to clear those "bad addresses" from the server.
CSCwc32360 affects wireless clients not APs so shouldn't be relevant to your AP problem.  Again this is not being fixed - it's just a reminder to make sure you have enough IPs in the client DHCP pool.  And remember to use "ip overlap" in flex profile if you intend to re-use IP addresses across sites (local switching)
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/c9800-best-practices.html#FlexConnectsitetag
Hello @Rich R , Thank you for your reply.
My bad, I was referring only to CSCvj14517.  I'm sure there were enough IP Addresses in the scope since there were only around 20-30APs and the scope had 115 addresses available, with 57 in Server Pool and 58 in partner pool, available. Deleting the BAD IPs did not seem to help recover the APs only recreating the scope when we tried.
We will continue investigating, and, on the next site roll out will double check what you have suggested.
As for the other bug I listed, my mistake, CSCwc32360, that was something else I was looking into and accidently pasted. You are correct, that Software update and the flex connect setting - IP Overlap was the fix for that issue.
sbirch333
I have 37 x 9120AXI-Z with IOS 17.12.04 at one site, which have been working fine for 12 months until they were rebooted & 17 of them stopped working.
A Wireshark capture shows that they fail to retrieve an IPv6 address via DHCPv6.  IPv6 is not configured anywhere in my organisation.  If I factory reset them, they still do not work.  If I provide a static IPv4 address via the console, they work fine.
Console logs show them stuck in a "Deep Green" mode.
This poses a potential problem for the remaining 3000+ access points.
Cisco TAC is working on it, but presently they have no idea.
What happens to the DHCP server (Option 43)?
Hello @sbirch333 What DHCP server are you using,
If it is Microsoft DHCP Server and you see BAD DHCP/BAD IP entries in the scope.
Please try modify the scope settings (if applicable)
  1. Disable DHCP Microsoft Name Protection
  2. Delay DHCP Offer - i.e. 50ms
I am not getting any "BAD ADDRESS" on the Win2022 DHCP (IPv4) server. Half
the WAPs have decided to only request DHCPv6.
Half the WAPs have decided to only request DHCPv6.
Which is why I suggested to check the preferred-mode configuration! ˅˅˅˅˅˅˅˅˅
@sbirch333 attach the complete console log from one of the problem APs from power-on?
Copy the log into a .txt file and attach rather than pasting hundreds of lines of logs into the message.
What DHCP server are you using?
Is the server on the local subnet or are you relaying to the server?
What logs do you see on the server when one of these APs tries to get an IP?
Does the "ap profile <profile-name>" have "preferred-mode ipv4" configured?
If you do a packet capture on the AP switch port for all DHCP what do you see happening?
How are the AP switch ports configured?
▒to 149/40
[*10/13/2024 23:15:09.1760] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:09.4190] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:10.9920] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:12.4480] dtls_init: Use SUDI certificate
[*10/13/2024 23:15:12.4920]
[*10/13/2024 23:15:12.4920] CAPWAP State: Init
[*10/13/2024 23:15:12.4930]
[*10/13/2024 23:15:12.4930] PNP is not required,
[*10/13/2024 23:15:12.4930] Starting CAPWAP discovery
[*10/13/2024 23:15:12.5000]
[*10/13/2024 23:15:12.5000] CAPWAP State: Discovery
[*10/13/2024 23:15:12.5010] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:15:12.5080]
[*10/13/2024 23:15:12.5080] CAPWAP State: Discovery
[*10/13/2024 23:15:22.3550]
[*10/13/2024 23:15:22.3550] CAPWAP State: Discovery
[*10/13/2024 23:15:22.3560] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:15:26.9310] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:15:32.3580]
[*10/13/2024 23:15:32.3580] CAPWAP State: Discovery
[*10/13/2024 23:15:32.3590] Not sending discovery request, AP does not have an IP!!
Error: Maximum input length exceeded
Login failed, lockout for 4 seconds
[*10/13/2024 23:15:42.3190] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:15:42.3630]
[*10/13/2024 23:15:42.3630] CAPWAP State: Discovery
[*10/13/2024 23:15:42.3630] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:15:42.4110] ip6_port srcr2, ip6local fe80::62aa:1270:3006:b937, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
% Authentication failed
^C^C
No valid user found, please configure a valid user from Controller[*10/13/2024 23:15:52.3710]
[*10/13/2024 23:15:52.3710] CAPWAP State: Discovery
[*10/13/2024 23:15:52.3720] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:02.3770]
[*10/13/2024 23:16:02.3770] CAPWAP State: Discovery
[*10/13/2024 23:16:02.3820] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:03.0010] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:16:12.3790]
[*10/13/2024 23:16:12.3790] CAPWAP State: Discovery
[*10/13/2024 23:16:12.3800] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:18.3860] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:16:22.3820]
[*10/13/2024 23:16:22.3820] CAPWAP State: Discovery
[*10/13/2024 23:16:22.3830] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:32.3860]
[*10/13/2024 23:16:32.3860] CAPWAP State: Discovery
[*10/13/2024 23:16:32.3860] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:38.8420] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:16:42.3880]
[*10/13/2024 23:16:42.3880] CAPWAP State: Discovery
[*10/13/2024 23:16:42.3890] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:42.3890] Discovery failed 9 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:16:42.3900] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:16:43.9750] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:16:49.2620] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:16:49.4270] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:16:55.3930]
[*10/13/2024 23:16:55.3930] CAPWAP State: Discovery
[*10/13/2024 23:16:55.3940] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:55.3940] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:16:59.8210] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:17:05.3990]
[*10/13/2024 23:17:05.3990] CAPWAP State: Discovery
[*10/13/2024 23:17:05.3990] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:17:15.1690] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:17:15.4000]
[*10/13/2024 23:17:15.4000] CAPWAP State: Discovery
[*10/13/2024 23:17:15.4010] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:17:25.4040]
[*10/13/2024 23:17:25.4040] CAPWAP State: Discovery
[*10/13/2024 23:17:25.4050] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:17:30.5180] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:17:35.4070]
[*10/13/2024 23:17:35.4070] CAPWAP State: Discovery
[*10/13/2024 23:17:35.4190] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:17:35.7550] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:17:45.4100]
[*10/13/2024 23:17:45.4100] CAPWAP State: Discovery
[*10/13/2024 23:17:45.4110] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:17:51.1130] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:17:55.4130]
[*10/13/2024 23:17:55.4130] CAPWAP State: Discovery
[*10/13/2024 23:17:55.4140] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:18:05.4160]
[*10/13/2024 23:18:05.4160] CAPWAP State: Discovery
[*10/13/2024 23:18:05.4170] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:18:06.4640] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:18:11.6990] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:18:15.4190]
[*10/13/2024 23:18:15.4190] CAPWAP State: Discovery
[*10/13/2024 23:18:15.4200] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:18:15.4200] Discovery failed 9 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:18:15.4200] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:18:16.8290] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:18:22.1210] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:18:22.2880] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:18:28.4230]
[*10/13/2024 23:18:28.4230] CAPWAP State: Discovery
[*10/13/2024 23:18:28.4240] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:18:28.4240] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:18:32.6780] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:18:38.4280]
[*10/13/2024 23:18:38.4280] CAPWAP State: Discovery
[*10/13/2024 23:18:38.4290] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:18:48.0280] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:18:48.4300]
[*10/13/2024 23:18:48.4300] CAPWAP State: Discovery
[*10/13/2024 23:18:48.4300] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:18:58.4330]
[*10/13/2024 23:18:58.4330] CAPWAP State: Discovery
[*10/13/2024 23:18:58.4340] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:19:03.3730] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:19:08.4360]
[*10/13/2024 23:19:08.4360] CAPWAP State: Discovery
[*10/13/2024 23:19:08.4370] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:19:18.4390]
[*10/13/2024 23:19:18.4390] CAPWAP State: Discovery
[*10/13/2024 23:19:18.4390] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:19:23.7900] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:19:28.4420]
[*10/13/2024 23:19:28.4420] CAPWAP State: Discovery
[*10/13/2024 23:19:28.4430] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:19:38.4530]
[*10/13/2024 23:19:38.4530] CAPWAP State: Discovery
[*10/13/2024 23:19:38.4540] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:19:39.1370] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:19:48.4480]
[*10/13/2024 23:19:48.4480] CAPWAP State: Discovery
[*10/13/2024 23:19:48.4480] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:19:48.4480] Discovery failed 9 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:19:48.4480] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:19:49.3240] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:19:54.7120] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:19:54.7750] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:19:54.9470] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:20:00.4510]
[*10/13/2024 23:20:00.4510] CAPWAP State: Discovery
[*10/13/2024 23:20:00.4520] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:20:00.4520] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:20:10.4540]
[*10/13/2024 23:20:10.4540] CAPWAP State: Discovery
[*10/13/2024 23:20:10.4550] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:20:15.4730] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:20:20.4570]
[*10/13/2024 23:20:20.4570] CAPWAP State: Discovery
[*10/13/2024 23:20:20.4580] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:20:20.7020] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:20:30.4600]
[*10/13/2024 23:20:30.4600] CAPWAP State: Discovery
[*10/13/2024 23:20:30.4610] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:20:36.0750] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:20:40.4630]
[*10/13/2024 23:20:40.4630] CAPWAP State: Discovery
[*10/13/2024 23:20:40.4640] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:20:50.4660]
[*10/13/2024 23:20:50.4660] CAPWAP State: Discovery
[*10/13/2024 23:20:50.4660] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:20:51.4330] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:21:00.4690]
[*10/13/2024 23:21:00.4690] CAPWAP State: Discovery
[*10/13/2024 23:21:00.4700] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:21:10.4720]
[*10/13/2024 23:21:10.4720] CAPWAP State: Discovery
[*10/13/2024 23:21:10.4730] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:21:11.8580] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:21:20.4750]
[*10/13/2024 23:21:20.4750] CAPWAP State: Discovery
[*10/13/2024 23:21:20.4800] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:21:20.4800] Discovery failed 9 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:21:20.4800] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:21:22.0550] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:21:27.4450] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:21:27.5110] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:21:27.6770] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:21:33.4790]
[*10/13/2024 23:21:33.4790] CAPWAP State: Discovery
[*10/13/2024 23:21:33.4800] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:21:33.4800] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:21:43.4840]
[*10/13/2024 23:21:43.4840] CAPWAP State: Discovery
[*10/13/2024 23:21:43.4850] Not sending discovery request, AP does not have an IP!!
No valid user found, please configure a valid user from Controller[*10/13/2024 23:21:48.2030] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:21:53.4850]
[*10/13/2024 23:21:53.4850] CAPWAP State: Discovery
[*10/13/2024 23:21:53.4860] Not sending discovery request, AP does not have an IP!!
e▒▒▒▒m▒ -}X▒&▒mJ▒▒HELO
5.0205HNDRC1a-1.0.38-163.162
CPU0
L1CD
MMUI
MMUA
CODE
ZBBS
MAIN
Boot Strap Register: 0x6fc7b
NVRAM memcfg 0x60607
DDR3-1600 CL11 total 2048MB 4 8bits part[s]
DDR test done successfully
CFE Version: 5
Verifying MASTER U-Boot...
Launching MASTER U-Boot version 0x0062 ...
____ _
/ ___|(_) ___ ___ ___
| | | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
\____||_||___/ \___|\___/
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
U-Boot 2017.09 (Jul 28 2023 - 19:54:06 -0700) Broadcom BCM49408
Board: VANC-i
I2C: ready
DRAM: 2 GiB
enable MMU ... OK
NAND: Status wait timeout: nandsts=0x0 mask=0x40000000, count=0
NAND ECC BCH-8, page size 4096 bytes, spare size used 216 bytes
1024 MiB
MMC:
SF: Detected mx25l6405d with page size 256 Bytes, erase size 4 KiB, total 8 MiB
In: serial
Out: serial
Err: serial
Platform: 4908
pmc_init:PMC using DQM mode
pmc_patch_4908:7 0 265044e 3360330
Board IP address : 192.168.1.1:ffffff00
Host IP address : 192.168.1.200
Gateway IP address : 10.1.1.1
Run from flash/host/tftp (f/h/c) : f
Default host run file name : vmlinux
Default host flash file name : bcm963xx_fs_kernel
Boot delay (0-9 seconds) : 3
Default host ramdisk file name :
Default ramdisk store address :
Board Id (0-18) : VANC_54991
Number of MAC Addresses (1-32) : 11
Base MAC Address : c8:28:e5:6f:a7:14
PSI Size (1-128) KBytes : 48
Enable Backup PSI [0|1] : 0
System Log Size (0-256) KBytes : 0
Auxillary File System Size Percent: 0
flow memory allocation (MB) : 43
buffer memory allocation (MB) : 16
DHD 0 memory allocation (MB) : 0
DHD 1 memory allocation (MB) : 0
DHD 2 memory allocation (MB) : 0
Partition 1 Size (MB) : 0M
Partition 2 Size (MB) : 0M
Partition 3 Size (MB) : 0M
Partition 4 Size (MB) (Data) : 4M
BootImage: MASTER
Found external PHY firmware image
MTDPART Str = (mtdparts=nand:1m(nvram),5888k(bootfs),-(fs))
Net: Registering Ethernet Driver.....
Broadcom BCM 4908 Ethernet driver 0.1
pmc_switch_power_up: Rgmii Tx clock zone1 enable 0 zone2 enable 0.
Setting SGMII Calibration value to 0x9
swap_pair = 0
Detecting PHYs...
84880 A0 ae02:5158 --> N/A
84881 A0 ae02:5150 --> N/A
84884 A0 ae02:5148 --> N/A
84884E A0 ae02:5168 --> N/A
84885 A0 ae02:5178 --> N/A
84886 A0 ae02:5170 --> N/A
84887 A0 ae02:5144 --> N/A
84888 A0 ae02:5140 --> N/A
84888E A0 ae02:5160 --> N/A
84888S A0 ae02:5174 --> N/A
84880 B0 ae02:5159 --> N/A
84881 B0 ae02:5151 --> N/A
84884 B0 ae02:5149 --> N/A
84884E B0 ae02:5169 --> N/A
84885 B0 ae02:5179 --> N/A
84886 B0 ae02:5171 --> N/A
84887 B0 ae02:5145 --> N/A
84888 B0 ae02:5141 --> N/A
84888E B0 ae02:5161 --> N/A
84888S B0 ae02:5175 --> N/A
84891 A0 3590:5090 --> N/A
54991 A0 3590:5094 --> N/A
54991E A0 3590:5098 --> N/A
84891L A0 3590:5080 --> N/A
54991L A0 3590:5084 --> N/A
54991EL A0 3590:5088 --> N/A
84892 A0 3590:50a0 --> N/A
54992 A0 3590:50a4 --> N/A
54992E A0 3590:50a8 --> N/A
84894 A0 3590:50b0 --> N/A
54994 A0 3590:50b4 --> N/A
54994E A0 3590:50b8 --> N/A
54991H A0 3590:50d0 --> N/A
54994H A0 3590:50f0 --> N/A
84891 B0 3590:5091 --> N/A
54991 B0 3590:5095 --> N/A
54991E B0 3590:5099 --> N/A
84891L B0 3590:5081 --> N/A
54991L B0 3590:5085 --> N/A
54991EL B0 3590:5089 --> 0x1f
84892 B0 3590:50a1 --> N/A
54992 B0 3590:50a5 --> N/A
54992E B0 3590:50a9 --> N/A
84894 B0 3590:50b1 --> N/A
54994 B0 3590:50b5 --> N/A
54994E B0 3590:50b9 --> N/A
54991H B0 3590:50d1 --> N/A
54994H B0 3590:50f1 --> N/A
Loading firmware into detected phys...
Firmware version: Blackfin B0 v02-02-03-2020-03-16
Loading firmware into phys: map=0x80000000
Halt the phys processors operation
Upload the firmware into the on-chip memory
100%
Reset the processors to start execution of the code in the on-chip memory
Verify that the processors are running: OK
Verify that the firmware has been loaded with good CRC: OK
Firmware loading completed successfully
Unsupported MII type: 0
bcm4908_eth-0
MAC: c8:28:e5:6f:a7:14
Hit ESC key to stop autoboot: 1 MG link 1G 0
Mounting UBI device fs
ubi0: attaching mtd3
ubi0: scanning is finished
ubi0: attached mtd3 (name "mtd=2", size 1017 MiB)
ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
ubi0: good PEBs: 4059, bad PEBs: 10, corrupted PEBs: 0
ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 32/23, WL threshold: 4096, image sequence number: 38517316
ubi0: available PEBs: 33, total reserved PEBs: 4026, PEBs reserved for bad PEB handling: 70
Load Addr 0x10000000
Mount UBIFS PARTITION part2 ...
Loading file 'part2/part.bin' to addr 0x10000000...
Done
Checking image signing.
Image signing verification success for part part2 continue to run...
Multi Image Header Found
Count = 0 Offset = 0x10000050 Len = 11201184
Count = 1 Offset = 0x10aaeaf0 Len = 3784840
Count = 2 Offset = 0x10e4ab78 Len = 7246
Booting from Partition: part2
arg 0: 0x10000050
arg 1: 0x3000000
arg 2: 0x1800000
## Loading init Ramdisk from Legacy Image at 03000000 ...
Image Name: Simple Ramdisk Image
Created: 2024-07-16 19:38:42 UTC
Image Type: AArch64 Linux RAMDisk Image (lzma compressed)
Data Size: 3784776 Bytes = 3.6 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 01800000
Booting using the fdt blob at 0x1800000
load dtb from fixed memory location directly...
/memory = 0x80000000 bytes @ 0x0
Set Memory to 2147483648l
WARNING: Node's property /reserved-memory/dt_reserved_buffer is not defined
WARNING: Node's property /reserved-memory/dt_reserved_flow is not defined
Appending NVRAM to dtb, ret:0
Loaded DTB from 0x01800000 with size 7246l
Curr Boot Args: console=ttyS0,9600 activepart=part2 activeboot=0 bootver=0x62 boardid=0x2 forceboot=0 coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait crashkernel=128M@0M ttyS0 mtdparts=nand:1m(nvram),5888k(bootfs),-(fs) ubi.mtd=fs BOOT_DEBUG=0
DTB Boot Args (coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait crashkernel=128M@0M)
Bootargs set to setenv bootargs console=$consoledev,$baudrate activepart=part2 activeboot=0 bootver=0x62 boardid=0x2 forceboot=0 coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait crashkernel=128M@0M $console $nandEcc $mtdparts ubi.mtd=fs BOOT_DEBUG=0
Preferred boot heartbeat count: 4
Erasing SPI flash...Writing to SPI flash...done
Cleanup Complete.... ARMv8_secure_init_done!!!
Loading Ramdisk to 4fb09000, end 4fea5048 ... OK
reserving fdt memory region: addr=0 size=20000
Using Device Tree in place at 0000000001800000, end 0000000001804c4d
Starting kernel ...
[01/01/1970 00:00:05.1850] hub 3-0:1.0: config failed, hub doesn't have any ports! (err -19)
[01/01/1970 00:00:05.2770] brcmboard registered
[*01/01/1970 00:00:16.8360] buginf() enabled.
[*01/01/1970 00:00:16.8440] Made it into bootsh: Jul 16 2024 19:21:00 T-d7566c7fa1151e24600b21806f0b6442a72b2b97M-g9c64e512-aut
[*01/01/1970 00:00:25.8050] bootsh mini ramfs booted /bootpart/part2/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
Press S for a shell, or another magic key...
[ OK ] Reached target Timers.
[ OK ] Reached target Cisco File Systems (Pre).
▒▒▒▒&▒ ] Created slice -.slice.
z-▒ ] Created slice system.slice.
[ OK ] Created slice system-sshd\x2dkeygen.slice.
Starting Cisco SE-Linux fixfiles script...
[ OK ] Reached target Slices.
[ OK ] Listening on Delayed Shutdown Socket.
[ OK ] Reached target Sockets.
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting Cisco UBIFS reformat/mount...
[ OK ] Started Cisco UBIFS reformat/mount.
Starting Cisco early mount...
▒▒▒▒&▒ ] Started Cisco early mount.
z-▒ ] Reached target Local File Systems (Pre).
[*01/01/1970 00:00:45.2780] root: Cisco Axel file system mounting
Starting Cisco fips check...
Starting Cisco system time setup...
Starting Cisco seed generation...
Starting Cisco platform file generation...
[ OK ] Started Cisco system time setup.
[ OK ] Started Cisco seed generation.
[*01/05/2023 23:59:59.0200] Last reload time: Oct 13 23:14:33 2024
[*10/13/2024 23:14:33.0000] Setting system time Sun Oct 13 23:14:33 UTC 2024
[*10/13/2024 23:14:33.0670] GCM-128 POST passed
[*10/13/2024 23:14:33.0670] GCM-256 POST passed
[*10/13/2024 23:14:33.1600] Auxiliary radio device detected
[ OK ] Started Cisco fips check.
[ OK ] Started Cisco platform file generation.
Starting Cisco btldr service...
[ OK ] Started Cisco btldr service.
[ OK ] Reached target Local File Systems.
[*10/13/2024 23:14:33.6250]
[*10/13/2024 23:14:33.6250] [10/13/2024 23:15:34] : Shadow is now in-synced with master
Starting Cisco act2 check...
Starting Cisco S10 boot service...
Starting Cisco system time saving...
Starting Cisco pkg install service...
[ OK ] Started Cisco system time saving.
[10/13/2024 23:14:34.5150] bcmlibs: module license 'Proprietary' taints kernel.
[10/13/2024 23:14:34.5930] Disabling lock debugging due to kernel taint
[10/13/2024 23:14:35.0300] bm_base_addr 0xffffffc006000000, size 67108864, bm_base_addr_phys 0x0000000006000000
[10/13/2024 23:14:35.1410] fm_base_addr 0xffffffc002e00000, size 12582912, fm_base_addr_phys 0x0000000002e00000
[10/13/2024 23:14:35.9840] Broadcom Command List Driver v1.0
[10/13/2024 23:14:36.1030] crossbar[0]: Allocated cb_idx=0 int_ep=0
[10/13/2024 23:14:36.1670] crossbar[0]: Add cb_idx=0 ext_ep=0 SERDES:6
[10/13/2024 23:14:36.2430]
[10/13/2024 23:14:36.2430] Detecting PHYs...
[10/13/2024 23:14:36.3210] Lift PHY at address 31 out of Reset by GPIO:31 Active Low
[10/13/2024 23:14:36.4170] 54991EL B0 3590:5089 --> 0x1f
[10/13/2024 23:14:36.4750]
[10/13/2024 23:14:36.4750] Loading firmware into detected PHYs...
[10/13/2024 23:14:36.6050] Firmware version: Blackfin B0 v02-02-03-2020-03-16
[10/13/2024 23:14:36.6870] Loading firmware into PHYs: map=0x80000000 count=1
[10/13/2024 23:14:36.7690] Halt the PHYs processors operation
[10/13/2024 23:14:36.8370] Upload the firmware into the on-chip memory
100%job is runnin start
[10/13/2024 23:14:40.2670] Reset the processors to start execution of the code in the on-chip memory
[10/13/2024 23:14:40.3760] Verify that the processors are running: g for Cisco act2 check (9s / 1min 3s)OK
[10/13/2024 23:14:40.9250] Verify that the firmware has been loaded with good CRC:OK
[10/13/2024 23:14:41.0150] Firmware loading completed successfully
[ 10/13/2024 23:14:41.1130] Adjusted SF2 SGPHY: sphy_ctrl=0x00010c1b
m**10/13/2024 23:14:41.2080] getrcal for res select 5, int 669, ext 642, ratio 122 ratio1 152, rcal 9
[10/13/2024 23:14:41.3140] Setting SGMII Calibration value to 0x9
[10/13/2024 23:14:41.3840] PLL_PON(8051): 0x0250; TX_PON(8067): 0x0048; RX_PON(80b2): 0x0980
m* ] (2 of 4) A start job is running for... install service (10s / 1min 3s)[*10/13/2024 23:14:34.1870] 13
[*10/13/2024 23:14:34.2880] Active version: 17.12.4.22
[*10/13/2024 23:14:34.2910] Backup version: 17.9.4.27
[*10/13/2024 23:14:34.4990] Loading BCM modules ...
[*10/13/2024 23:14:34.4990] Ignore pptp.ko
[*10/13/2024 23:14:34.5010] Ignore pktflow.ko
[*10/13/2024 23:14:34.5040] Ignore pktrunner.ko
[*10/13/2024 23:14:34.5070] Load bcmlibs.ko
[*10/13/2024 23:14:34.6690] BCMLIBS loaded...
[*10/13[10/13/2024 23:14:42.0200] dgasp: kerSysRegisterDyingGaspHandler: bcmsw registered
/2024 23:14:34.6840] Load wlcsm.ko
[*10/13/2024 23:14:34.7100] Load rdp_fpm.ko
[*10/13/2024 23:14:34.7580] Load bdmf.ko
[*10/13/2024 23:14:34.7860] Load proclikefs.ko
[*10/13/2024 23:14:34.8090] Load rdpa_gpl.ko
[*10/13/2024 23:14:34.8320] Load rdpa_gpl_ext.ko
[*10/13/2024 23:14:34.8540] Load rdpa.ko
[*10/13/2024 23:14:34.9240] Load rdpa_usr.ko
[*10/13/2024 23:14:34.9530] Load rdpa_mw.ko
[*10/13/2024 23:14:35.2590] RDP Physical address=0x82200000 Virtual address = 0xffffff8001c80000
[*10/13/2024 23:14:35.2720] configure_runner: NATC keysize 0x100070 key element size 16 contextsize 0x400000 context element size 64
[*10/13/2024 23:14:35.2720] ++++Runner gso_desc_pool created successfully
[*10/13/2024 23:14:35.7590] FPM_BPM phy_addr 0x82c30000,virt_addr 0xffffff800197e000
[*10/13/2024 23:14:35.7590] RDP PKT memory = 64MB : Max Possible Bufs <16384> of size <4096>; Allocating <15360> bufs; RDP enum <5>
[*10/13/2024 23:14:35.9170] Load chipinfo.ko
[*10/13/2024 23:14:35.9280] brcmchipinfo: brcm_chipinfo_init entry
[*10/13/2024 23:14:35.9420] Load rdpa_cmd.ko
[*10/13/2024 23:14:35.9710] Load cmdlist.ko
[*10/13/2024 23:14:36.0830] Load bcm_enet.ko
[*10/13/2024 23:14:36.2430] crossbar Mux: connect cb_idx:0 int_ep 0 to ext_ep 0
[*10/13/2024 23:14:36.2430] crossbar Mux: connect cb_idx:0 int_ep 1 to ext_ep 2
[*10/13/2024 23:14:38.9190]
[*10/13/2024 23:14:38.9190] Authenticating ACT2 ID:C9120 Authenticating SN:FOC26514LG9
[*10/13/2024 23:14:38.9200]
[*10/13/2024 23:14:38.9200] (ACT2Boot) Hardware is Cisco (c) authentic
[*10/13/2024 23:14:38.9270] Seeding /dev/urandom from ACT2
[*10/13/2024 23:14:40.6240] Reading ACT2 SUDI certificates
[*10/13/2024 23:14:41.1960] NOTE: Using Port Grouping for IMP ports : [ 0 --> 4 ] [ 1, 2 --> 5 ] [ 3, 7 --> 8 ]
[*10/13/2024 23:14:42.0200] eth0: Down <28:e5:6f:a7:14> PHY_ID <0x0007f008:0x08: On-chip 1G GPHY> Cfg: ANG.1G; Down
[*10/13/2024 23:14:42.0200] eth1: Down <28:e5:6f:a7:14> PHY_ID <0x0007f009:0x09: On-chip 1G GPHY> Cfg: ANG.1G; Down
[*10/13/2024 23:14:42.0200] eth2: Down <28:e5:6f:a7:14> PHY_ID <0x0007f00a:0x0a: On-chip 1G GPHY> Cfg: ANG.1G; Down
[*10/13/2024 23:14:42.0200] eth3: Down <28:e5:6f:a7:14> PHY_ID <0x0007f00b:0x0b: On-chip 1G GPHY> Cfg: ANG.1G; Down
[*10/13/2024 23:14:42.0200] eth4: Down <28:e5:6f:a7:14>
[*10/13/2024 23:14:42.0200] Chip Port 9, CrossBar Port 0, PHY_ID <0x06100006:0x06: On-chip 2.5G SERDES> Cfg: ANG.2.5G; Down
[*10/13/2024 23:14:42.0200] PHY_ID <0x0388001f:0x1f:External Cascaded 10G EXT3> Cfg: ANG.2.5G; Down
[*10/13/2024 23:14:42.0200] ===> Activate Deep Green Mode
[*10/13/2024 23:14:42.0200] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link DOWN
[*10/13/2024 23:14:42.1670] Auto Detection of Serdes: Enabled
[*10/13/2024 23:14:42.1670] PHY Capabilities: 2.5GFD|1GFD|100MFD
[*10/13/2024 23:14:42.1670] Link is Down.
[*10/13/2024 23:14:42.6250] ret code = 0.
[*10/13/2024 23:14:42.6330] wired0 Link encap:Ethernet HWaddr C8:28:E5:6F:A7:14
[*10/13/2024 23:14:42.6330] UP BROADCAST MULTICAST MTU:2044 Metric:1
[*10/13/2024 23:14:42.6330] RX packets:838 errors:0 dropped:36 overruns:0 frame:0
[*10/13/2024 23:14:42.6330] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
[*10/13/2024 23:14:42.6330] collisions:0 txqueuelen:1000
[*10/13/2024 23:14:42.6330] RX bytes:107566 (105.0 KiB) TX bytes:0 (0.0 B)
[*10/13/2024 23:14:42.6350] C8:28:E5:6F:A7:14
[*10/13/2024 23:14:42.6350] BCM11ax AP: MIC Certificate Present
[*01/05/2023 23:59:59.0180] Last reload time: Oct 13 23:14:33 2024
[*10/13/2024 23:14:33.5760] Last reload reason : 0: unknown
[*10/13/2024 23:14:35.5320] <=== Deactivate Deep Green Mode
[*10/13/2024 23:14:35.5320] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link UP
[*10/13/2024 23:14:35.5320] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link Up at 1000 mbps full duplex
[*10/13/2024 23:14:35.5610]
[*10/13/2024 23:14:35.5610] ACT2 Check passed
[ OK ] Started Cisco SE-Linux fixfiles script.
[ OK ] Started Cisco act2 check.
[ OK ] Started Cisco S10 boot service.
[ OK ] Started Cisco pkg install service.
Starting Cisco nolan service...
Starting Cisco watchdog...
Starting Cisco nss service...
[ OK ] Started Tam server.
Starting Tam server...
Starting Cisco Tam service...
[ OK ] Started Cisco watchdog.
[ OK ] Started Cisco nolan service.
[ OK ] Started Cisco nss service.
Starting Cisco S15platform...
Starting Cisco Kclick...
Starting Cisco nolan USB service...
[ OK ] Started Cisco Tam service.
[*10/13/2024 23:14:37.8450] starting tam services using ACT2...
[ OK ] Started Cisco nolan USB service.
[*10/13/2024 23:14:38.0630] Loading HND Module
Starting Cisco pre-PoE negotiation...
[ OK ] Started Cisco pre-PoE negotiation.
[*10/13/2024 23:14:38.1900] NTKM - ntkm_init - Nitro KM loaded
[ OK ] Started Cisco Kclick.
[ OK ] Started Cisco S15platform.
Starting Cisco sysctl service...
[*10/13/2024 23:14:40.0150] Starting check if backup WiFi NVRAM are available
[*10/13/2024 23:14:40.0150] WiFi backup nvram - crc = 3048188091
[*10/13/2024 23:14:40.0150] WiFi active nvram - crc =617
[*10/13/2024 23:14:40.0150] [WARNING]ACTIVE and BACKUP NVRAM NOT use same data
[*10/13/2024 23:14:40.0340] restore done!
[*10/13/2024 23:14:40.0400] restore done!
Starting Cisco ME service...
Starting Cisco Sku service...
Starting Cisco certificate create service...
[ OK ] Started Cisco Sku service.
[ OK ] Started Cisco sysctl service.
[ OK [10/13/2024 23:14:40.9030] broadcomThermalDrv brcm-therm: init (CPU count 4 4 4 4)
] Started Cisco ME service.
[ OK ] Started Cisco certificate create service.
Starting Cisco synclogd...
[*10/13/2024 23:14:41.2290] crypto worker thread started
[*10/13/2024 23:14:41.2590] Broadcom EAP Forwarder v0.1 is loaded
[*10/13/2024 23:14:41.3120] igs_module_init:867: IGS 18 create network socket successful
[*10/13/2024 23:14:41.4300] Wifi Forwarding Driver is initialized!
[*10/13/2024 23:14:41.7450] wl_module_init: passivemode set to 0x1
[*10/13/2024 23:14:41.7450] wl_module_init: txworkq set to 0x0
[*10/13/2024 23:14:41.7450] wl_pktfwd_sys_init: WL_PKTFWD[1.1.0] Success
[*10/13/2024 23:14:41.7530] wl0: phy_radio_attach: RF Band Cap: 2G:1 5G:1
[*10/13/2024 23:14:41.7840]
[*10/13/2024 23:14:41.7840] WLC_ATTACH routine completed successfully
[*10/13/2024 23:14:41.7850] wl_wfd_bind: wl0 wfd_idx 0 success
[*10/13/2024 23:14:41.7860] apr1v0: Broadcom BCM43684 802.11 Wireless Controller 17.20.10 (r790816 WLTEST)
[*10/13/2024 23:14:41.7960] wl1: phy_radio_attach: RF Band Cap: 2G:1 5G:1
[*10/13/2024 23:14:41.8270]
[*10/13/2024 23:14:41.8270] WLC_ATTACH routine completed successfully
[*10/13/2024 23:14:41.8280] wl_wfd_bind: wl1 wfd_idx 1 success
[*10/13/2024 23:14:41.8280] apr0v0: Broadcom BCM43684 802.11 Wireless Controller 17.20.10 (r790816 WLTEST)
[*10/13/2024 23:14:42.2210] First unregister unused apps
[*10/13/2024 23:14:42.2210] Enumerating apps...
[*10/13/2024 23:14:42.2240] 4 registered apps:
[*10/13/2024 23:14:42.2240] 0: capwapd
[*10/13/2024 23:14:42.2240] 1: IOSd_App
[*10/13/2024 23:14:42.2240] 2: IOXCAF_App
[*10/13/2024 23:14:42.2240] 3: aurora
[*10/13/2024 23:14:42.2240] Finish unregister all unused apps in catalyst mode
Starting Cisco brain service...
Starting rsyslog client...
Starting Cisco S16platfomm...
[ OK ] Started Cisco synclogd.
[ OK ] Started rsyslog client.
[*10/13/2024 23:14:44.0630] sync_log: couldn't open log file: No such file or directory
[*10/13/2024 23:14:44.0750] pid 3874's current affinity mask: f
[*10/13/2024 23:14:44.0750] pid 3874's new affinity mask: e
[*10/13/2024 23:14:44.0770] pid 3867's current affinity mask: f
[*10/13/2024 23:14:44.0770] pid 3867's new affinity mask: e
[*10/13/2024 23:14:44.1450] wl: Not up
[*10/13/2024 23:14:44.1470] wl: Not up
[*10/13/2024 23:14:44.1550] wl: Bad Band
[*10/13/2024 23:14:44.1650] Success.
[*10/13/2024 23:14:44.1670] Success.
[ OK ] Started Cisco brain service.
[ OK ] Started Cisco S16platfomm.
Starting RHL daemon...
[*10/13/2024 23:14:44.8950] chatter: '' not a write handler
[*10/13/2024 23:14:44.9230] chatter: '' not a write handler
[*10/13/2024 23:14:44.9510] chatter: '' not a write handler
[*10/13/2024 23:14:44.9770] chatter: '' not a write handler
[*10/13/2024 23:14:45.0030] chatter: '' not a write handler
[*10/13/2024 23:14:45.0310] chatter: '' not a write handler
[*10/13/2024 23:14:45.0620] chatter: '' not a write handler
[*10/13/2024 23:14:45.0920] chatter: '' not a write handler
[*10/13/2024 23:14:45.1230] chatter: '' not a write handler
[*10/13/2024 23:14:45.1510] chatter: '' not a write handler
[*10/13/2024 23:14:45.1780] chatter: '' not a write handler
[*10/13/2024 23:14:45.2070] chatter: '' not a write handler
[*10/13/2024 23:14:45.2350] chatter: '' not a write handler
[*10/13/2024 23:14:45.2410] chatter: '' not a write handler
[*10/13/2024 23:14:45.2460] sh: /bin/bs: not found
[*10/13/2024 23:14:45.2890] Deep Green Mode feature changed to disabled (DGM status: deactivated)
[*10/13/2024 23:14:45.2890] WIFI Off (*) ==> Disable
[*10/13/2024 23:14:45.2890] DISK Off (*) ==> Disable
[*10/13/2024 23:14:45.2890] PCI ASPM (*) ==> Disable
[*10/13/2024 23:14:45.2890] PCI ASPM control is disabled in this image
[*10/13/2024 23:14:45.2890] UBUS DCM (*) ==> Disable
[*10/13/2024 23:14:45.2890] CPU Off (*) ==> Disable
[*10/13/2024 23:14:45.2890] CPU Wait (*) ==> Disable
[*10/13/2024 23:14:45.2890] CPU Speed (*) ==> Disable
[*10/13/2024 23:14:45.2890] XRDP Gate (*) ==> Disable
[*10/13/2024 23:14:45.2890] NET Down (*) ==> Disable
[*10/13/2024 23:14:45.2890] PHY Down (*) ==> Disable
[*10/13/2024 23:14:45.2890] PHY EEE (*) ==> Disable
[*10/13/2024 23:14:45.2890] PHY APD (*) ==> Disable
[*10/13/2024 23:14:45.2890] SF2 DGM (*) ==> Disable
[*10/13/2024 23:14:45.2890] DRAM SR (*) ==> Disable
[*10/13/2024 23:14:45.2890] AVS (*) ==> Disable
[*10/13/2024 23:14:45.4320]
[*10/13/2024 23:14:45.4320] !!!!! {/opt/cisco/bin/capwap_brain} Dnsmasq.conf file before update:
[*10/13/2024 23:14:45.4320] !!!!! {/opt/cisco/bin/capwap_brain} Dnsmasq.conf new config:
[*10/13/2024 23:14:45.4320] no-resolv
[*10/13/2024 23:14:45.4320] pid-file=/var/run/dnsmasq.vaperr.pid
[*10/13/2024 23:14:45.4320] port=5316
[*10/13/2024 23:14:45.4320] min-port=61000
[*10/13/2024 23:14:45.4320] address=/#/6.0.0.7
[*10/13/2024 23:14:45.4320] !!!!! {/opt/cisco/bin/capwap_brain} Dnsmasq.conf file after update:
[*10/13/2024 23:14:45.8290]
[*10/13/2024 23:14:45.8290] !!!!! {/opt/cisco/bin/capwap_brain} Dnsmasq.conf file before update:
[*10/13/2024 23:14:45.8290] no-resolv
[*10/13/2024 23:14:45.8290] pid-file=/var/run/dnsmasq.vaperr.pid
[*10/13/2024 23:14:45.8290] port=5316
[*10/13/2024 23:14:45.8290] min-port=61000
[*10/13/2024 23:14:45.8290] address=/#/6.0.0.7
[*10/13/2024 23:14:45.8290] !!!!! {/opt/cisco/bin/capwap_brain} Dnsmasq.conf new config:
[*10/13/2024 23:14:45.8300]
[*10/13/2024 23:14:45.8300] !!!!! {/opt/cisco/bin/capwap_brain} Dnsmasq.conf file after update:
[*10/13/2024 23:14:45.8300] no-resolv
[*10/13/2024 23:14:45.8300] pid-file=/var/run/dnsmasq.vaperr.pid
[*10/13/2024 23:14:45.8300] port=5316
[*10/13/2024 23:14:45.8300] min-port=61000
[*10/13/2024 23:14:45.8300] address=/#/6.0.0.7
[*10/13/2024 23:14:45.8930] ip6_port srcr2, ip6local ::, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[*10/13/2024 23:14:46.0740] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:14:46.1490] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link DOWN.
[*10/13/2024 23:14:46.1500] chatter: Device wired0 notify state change link DOWN
[*10/13/2024 23:14:46.2400] Check whether client_ip_table entry need to be cleared 0
[*10/13/2024 23:14:46.2410] Clearing client entry
[*10/13/2024 23:14:47.4920]
[*10/13/2024 23:14:47.4920] TAM init done
[*10/13/2024 23:14:47.4920] Object list for Device=ap-tam App[1] Count= 0
[*10/13/2024 23:14:47.4920] TAMS init: There is no Cloud ID in ACT2!
[*10/13/2024 23:14:48.1250]
[*10/13/2024 23:14:48.1250] Click sched monitor: schedulers = 1
[*10/13/2024 23:14:49.2570] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link Up at 1000 mbps full duplex
[*10/13/2024 23:14:49.2570] chatter: Device wired0 notify state change link UP
[*10/13/2024 23:14:49.8050] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:14:49.9670] Check whether client_ip_table entry need to be cleared 0
[*10/13/2024 23:14:49.9670] Clearing client entry
[*10/13/2024 23:14:51.1920] ip6_port srcr2, ip6local ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[10/13/2024 23:14:51.7670] NXP-RHL-Driver 0001:01:00.0: RHL: AP SKU = 0, pow min,max = -4, 20
[10/13/2024 23:14:51.7670] , Rx Diversity =0, 6g AP = 0, Ithaca Esku =0
[10/13/2024 23:14:51.9630] NXP-RHL-Driver 0001:01:00.0: Final VSPA image size val 0xf30000
[10/13/2024 23:14:52.8570] bcm963xx-pcie: RHL legacy interrupt initialized
[ OK ] Started RHL daemon.
[ OK ] Reached target System Initialization.
j▒▒5▒j▒ OK ] Reached target Basic System.
[*10/13/2024 23:14:51.5310] rhl_reset : got minor 56
[*10/13/2024 23:14:52.0540] V2H call back init
[*10/13/2024 23:14:52.0540] V2H callback registered
Starting Sensord daemon...
Starting platform manager process...
Starting RHL monitor/reset daemon...
[ OK ] Started Serial Getty on ttyS0.
J▒▒▒&▒ Starting Serial Getty on ttyS0...
z-▒ ] Reached target Login Prompts.
Starting Cisco klogd...
Starting RSYNC User Key Generation...
Starting NTP_PROC daemon...
Starting Cisco printkd...
Starting Security Auditing Service...
[ OK ] Started platform manager process.
[ OK ] Started RHL monitor/reset daemon.
[*10/13/2024 23:14:53.9430] reset device opened
[ OK ] Started NTP_PROC daemon.
[ OK ] Started Cisco klogd.
[ OK ] Started Cisco printkd.
Starting ntp file watcher...
[*10/13/2024 23:14:54.2010] No valid NTP source
[*10/13/2024 23:14:54.2010] No valid ntp server info file. Stop NTP!
Starting WCPD process...
Starting ntp watcher...
[ OK ] Started ntp file watcher.
[ OK ] Started Sensord daemon.
[ OK ] Started ntp watcher.
[ OK ] Started WCPD process.
Starting capwapd...
[ OK ] Started capwapd.
Starting Cisco led service...
Starting System Monitor service...
Starting Cisco rtd service...
Starting awips daemon...
Starting gRPC daemon...
Starting Clean Air daemon...
Starting Hostapd process...
[ OK ] Started ble_transport daemon.
Starting ble_transport daemon...
Starting Cisco image/firmware updater service...
Starting DNSmasq...
Starting Fast CGI daemon...
[*10/13/2024 23:14:55.5670] chpasswd: password for user changed
[*10/13/2024 23:14:55.6610] DOT11_TXP[1]:Domain configured: 48 class:Z
[*10/13/2024 23:14:55.7020] EEPRO Starting iCAP daemon...
Starting BLE init service...
Starting Cisco kexec...
Starting AP Trace daemon...
[*10/13/2024 23:14:55.8980] DOT11_TXP[1]:Regdb file: /radio_fw/C9120AXI_power_table_mapping.txt
[*10/13/2024 23:14:55.9020] DOT11_TXP[0]:Domain configured: 0 class:A
[*10/13/2024 23:14:55.9910] DOT11_TXP[0]:Regdb file: /radio_fw/C9120AXI_power_table_mapping.txt
[*10/13/2024 23:14:56.0070] DOT11_TXP[0]:Domain configured: 48 class:Z
[*10/13/2024 23:14:56.2810] DOT11_TXP[0]:Regdb file: /radio_fw/C9120AXI_power_table_mapping.txt
M▒▒▒&▒
z-▒ ] Started RSYNC User Key Generation.
[ OK ] Started System Monitor service.
[*10/13/2024 23:14:56.4660] capwapd log into tam successful
[*10/13/2024 23:14:56.4660] SUCCESS TAM
[*10/13/2024 23:14:56.4660] #### board_data_init: num_slots (2), num_radios (2)
[ OK ] Started awips daemon.
[ OK ] Started iCAP daemon.
[*10/13/2024 23:14:56.8150]
[*10/13/2024 23:14:56.8150] [10/13/2024 23:15:57] updt_util: PHY firmware is up to date
[*10/13/2024 23:14:56.8230]
[*10/13/2024 23:14:56.8230] [10/13/2024 23:15:57] updt_util: All bootloaders are up to date
[ OK ] Started Cisco led service.
[ OK ] Started Cisco image/firmware updater service.
[ OK ] Started Cisco kexec.
[ OK ] Reached target sshd-keygen.target.
Starting CiscoSSH server daemon...
[ OK ] Started Cisco rtd service.
[ OK ] Started AP Trace daemon.
[ OK ] Started Hostapd process.
[ OK ] Started DNSmasq.
[ OK ] Started CiscoSSH server daemon.
[*10/13/2024 23:14:57.8740] EEPROM Size = 65536
[*10/13/2024 23:14:57.8740] loading trx table from EEPROM [*10/13/2024 23:14:57.9970] NZ (NZ/0) NEW ZEALAND
[ OK ] Started Clean Air daemon.
[*10/13/2024 23:14:58.0140] DOT11_DRV[0]: set_channel Channel set to 6/20
[*10/13/2024 23:14:58.0950] nimbus 1 Unable to load host key "/storage/ssh/ssh_host_rsa_key" - incorrect passphrase supplied to decrypt private key
[*10/13/2024 23:14:58.0960] Unable to load host key: /storage/ssh/ssh_host_rsa_key
[ OK ] Started gRPC daemon.
[*10/13/2024 23:14:58.4390] pid 6390's current affinity mask: f
[*10/13/2024 23:14:58.4390] pid 6390's new affinity mask: 2
[*10/13/2024 23:14:59.2300] DOT11_DRV[1]: BCM FIPS POST for CCMP-128 and GCMP-128 passed
[*10/13/2024 23:14:59.2310] DOT11_DRV[1]: Stop Radio1
[*10/13/2024 23:14:59.2310] Stopped Radio 1
[*10/13/2024 23:14:59.2580] NZ (NZ/0) NEW ZEALAND
[*10/13/2024 23:14:59.2650] DOT11_DRV[1]: set_channel Channel set to 36/20
No valid user found, please configure a valid user from Controller[*10/13/2024 23:15:00.0110] DOT11_DRV[2]: off_channel timeout but no req in progress
[*10/13/2024 23:15:00.8970] size: 17477 bytes (48059 left)
[*10/13/2024 23:15:01.1480] DOT11_DRV[0]: set_channel Channel set to 1/20
[*10/13/2024 23:15:02.2140] DOT11_DRV[0]: set_channel Channel set to 1/20
[*10/13/2024 23:15:03.1760] DOT11_DRV[0]: set_channel Channel set to 1/20
[*10/13/2024 23:15:03.5100] DOT11_DRV[0]: set_channel Channel set to 1/20
[*10/13/2024 23:15:04.8060] DOT11_DRV[0]: set_channel Channel set to 1/20
[*10/13/2024 23:15:06.1140] size: 17477 bytes (48059 left)
[*10/13/2024 23:15:06.3670] wl: Bad Channel
[*10/13/2024 23:15:06.3670] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:07.3800] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:08.5780] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:09.6640] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:09.9020] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:11.4660] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:12.9280] dtls_init: Use SUDI certificate
[*10/13/2024 23:15:12.9720]
[*10/13/2024 23:15:12.9720] CAPWAP State: Init
[*10/13/2024 23:15:12.9730]
[*10/13/2024 23:15:12.9730] PNP is not required,
[*10/13/2024 23:15:12.9730] Starting CAPWAP discovery
[*10/13/2024 23:15:12.9800]
[*10/13/2024 23:15:12.9800] CAPWAP State: Discovery
[*10/13/2024 23:15:12.9810] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:15:12.9880]
[*10/13/2024 23:15:12.9880] CAPWAP State: Discovery
[*10/13/2024 23:15:22.8120]
[*10/13/2024 23:15:22.8120] CAPWAP State: Discovery
[*10/13/2024 23:15:22.8130] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:15:32.8150]
[*10/13/2024 23:15:32.8150] CAPWAP State: Discovery
[*10/13/2024 23:15:32.8160] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:15:42.8180]
[*10/13/2024 23:15:42.8180] CAPWAP State: Discovery
[*10/13/2024 23:15:42.8190] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:15:47.8790] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
No valid user found, please configure a valid user from Controller[*10/13/2024 23:15:52.8210]
[*10/13/2024 23:15:52.8210] CAPWAP State: Discovery
[*10/13/2024 23:15:52.8220] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:15:58.1150] ip6_port srcr2, ip6local fe80::62aa:1270:3006:b937, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[*10/13/2024 23:16:02.8250]
[*10/13/2024 23:16:02.8250] CAPWAP State: Discovery
[*10/13/2024 23:16:02.8290] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:02.8290] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:16:02.8300] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:16:03.4880] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:16:03.5520] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:16:08.8340] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:16:09.0000] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:16:14.8280]
[*10/13/2024 23:16:14.8280] CAPWAP State: Discovery
[*10/13/2024 23:16:14.8300] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:24.2860] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:16:24.8310]
[*10/13/2024 23:16:24.8310] CAPWAP State: Discovery
[*10/13/2024 23:16:24.8320] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:34.8360]
[*10/13/2024 23:16:34.8360] CAPWAP State: Discovery
[*10/13/2024 23:16:34.8360] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:39.6410] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:16:44.8380]
[*10/13/2024 23:16:44.8380] CAPWAP State: Discovery
[*10/13/2024 23:16:44.8380] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:44.8700] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:16:54.8410]
[*10/13/2024 23:16:54.8410] CAPWAP State: Discovery
[*10/13/2024 23:16:54.8420] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:54.8420] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:16:54.8420] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:16:55.0640] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:17:00.4440] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:17:00.5060] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:17:00.6710] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:17:05.8440]
[*10/13/2024 23:17:05.8440] CAPWAP State: Discovery
[*10/13/2024 23:17:05.8450] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:17:15.8480]
[*10/13/2024 23:17:15.8480] CAPWAP State: Discovery
[*10/13/2024 23:17:15.8500] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:17:21.0270] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:17:25.8500]
[*10/13/2024 23:17:25.8500] CAPWAP State: Discovery
[*10/13/2024 23:17:25.8510] Not sending discovery request, AP does not have an IP!!
No valid user found, please configure a valid user from Controller[*10/13/2024 23:17:35.8550]
[*10/13/2024 23:17:35.8550] CAPWAP State: Discovery
[*10/13/2024 23:17:35.8670] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:17:36.3760] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:17:45.8560]
[*10/13/2024 23:17:45.8560] CAPWAP State: Discovery
[*10/13/2024 23:17:45.8600] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:17:45.8600] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:17:45.8600] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:17:46.5650] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:17:51.9330] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:17:51.9950] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:17:52.1700] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:17:57.8600]
[*10/13/2024 23:17:57.8600] CAPWAP State: Discovery
[*10/13/2024 23:17:57.8610] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:17:57.8610] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:18:07.8640]
[*10/13/2024 23:18:07.8640] CAPWAP State: Discovery
[*10/13/2024 23:18:07.8650] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:18:12.6840] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:18:17.8680]
[*10/13/2024 23:18:17.8680] CAPWAP State: Discovery
[*10/13/2024 23:18:17.8690] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:18:17.9120] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:18:27.8700]
[*10/13/2024 23:18:27.8700] CAPWAP State: Discovery
[*10/13/2024 23:18:27.8710] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:18:33.2730] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:18:37.8730]
[*10/13/2024 23:18:37.8730] CAPWAP State: Discovery
[*10/13/2024 23:18:37.8740] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:18:37.8740] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:18:37.8740] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:18:38.3950] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:18:43.6530] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:18:43.8180] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:18:49.8770]
[*10/13/2024 23:18:49.8770] CAPWAP State: Discovery
[*10/13/2024 23:18:49.8780] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:18:54.0430] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:18:59.8800]
[*10/13/2024 23:18:59.8800] CAPWAP State: Discovery
[*10/13/2024 23:18:59.8810] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:19:09.3940] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:19:09.8830]
[*10/13/2024 23:19:09.8830] CAPWAP State: Discovery
[*10/13/2024 23:19:09.8840] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:19:19.8860]
[*10/13/2024 23:19:19.8860] CAPWAP State: Discovery
[*10/13/2024 23:19:19.8870] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:19:24.7370] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:19:29.8930]
[*10/13/2024 23:19:29.8930] CAPWAP State: Discovery
[*10/13/2024 23:19:29.8940] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:19:29.8940] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:19:29.8940] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:19:29.9770] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:19:30.0420] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:19:35.3020] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:19:35.4730] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:19:40.8920]
[*10/13/2024 23:19:40.8920] CAPWAP State: Discovery
[*10/13/2024 23:19:40.8930] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:19:45.7010] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:19:50.8960]
[*10/13/2024 23:19:50.8960] CAPWAP State: Discovery
[*10/13/2024 23:19:50.8970] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:19:50.9310] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:20:00.8980]
[*10/13/2024 23:20:00.8980] CAPWAP State: Discovery
[*10/13/2024 23:20:00.8990] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:20:06.2880] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:20:10.9010]
[*10/13/2024 23:20:10.9010] CAPWAP State: Discovery
[*10/13/2024 23:20:10.9020] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:20:20.9040]
[*10/13/2024 23:20:20.9040] CAPWAP State: Discovery
[*10/13/2024 23:20:20.9160] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:20:20.9160] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:20:20.9160] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:20:21.6410] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:20:21.7090] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:20:27.0700] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:20:27.1390] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:20:27.3070] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:20:32.9070]
[*10/13/2024 23:20:32.9070] CAPWAP State: Discovery
[*10/13/2024 23:20:32.9080] Not sending discovery request, AP does not have an IP!!
No valid user found, please configure a valid user from Controller[*10/13/2024 23:20:42.6080] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:20:42.9100]
[*10/13/2024 23:20:42.9100] CAPWAP State: Discovery
[*10/13/2024 23:20:42.9110] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:20:47.8380] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:20:52.9130]
[*10/13/2024 23:20:52.9130] CAPWAP State: Discovery
[*10/13/2024 23:20:52.9140] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:21:02.9160]
[*10/13/2024 23:21:02.9160] CAPWAP State: Discovery
[*10/13/2024 23:21:02.9170] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:21:03.2070] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:21:12.9240]
[*10/13/2024 23:21:12.9240] CAPWAP State: Discovery
[*10/13/2024 23:21:12.9250] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:21:12.9250] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:21:12.9250] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:21:13.4070] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:21:18.8000] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:21:18.8690] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:21:19.0370] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:21:24.9230]
[*10/13/2024 23:21:24.9230] CAPWAP State: Discovery
[*10/13/2024 23:21:24.9240] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:21:24.9240] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:21:34.9260]
[*10/13/2024 23:21:34.9260] CAPWAP State: Discovery
[*10/13/2024 23:21:34.9270] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:21:39.5620] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:21:44.7910] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:21:44.9290]
[*10/13/2024 23:21:44.9290] CAPWAP State: Discovery
[*10/13/2024 23:21:44.9300] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:21:54.9320]
[*10/13/2024 23:21:54.9320] CAPWAP State: Discovery
[*10/13/2024 23:21:54.9330] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:22:00.1630] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:22:04.9350]
[*10/13/2024 23:22:04.9350] CAPWAP State: Discovery
[*10/13/2024 23:22:04.9360] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:22:04.9360] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:22:04.9360] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:22:05.2950] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:22:10.5600] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:22:10.7280] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:22:16.9400]
[*10/13/2024 23:22:16.9400] CAPWAP State: Discovery
[*10/13/2024 23:22:16.9510] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:22:16.9510] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:22:21.1290] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:22:26.9410]
[*10/13/2024 23:22:26.9410] CAPWAP State: Discovery
[*10/13/2024 23:22:26.9420] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:22:36.4910] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:22:36.9440]
[*10/13/2024 23:22:36.9440] CAPWAP State: Discovery
[*10/13/2024 23:22:36.9450] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:22:46.9470]
[*10/13/2024 23:22:46.9470] CAPWAP State: Discovery
[*10/13/2024 23:22:46.9480] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:22:56.9150] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:22:56.9540]
[*10/13/2024 23:22:56.9540] CAPWAP State: Discovery
[*10/13/2024 23:22:56.9550] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:22:56.9550] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:22:56.9550] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:22:56.9910] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:23:02.2710] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:23:02.4390] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:23:07.9530]
[*10/13/2024 23:23:07.9530] CAPWAP State: Discovery
[*10/13/2024 23:23:07.9540] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:23:12.6730] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:23:17.9050] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:23:17.9570]
[*10/13/2024 23:23:17.9570] CAPWAP State: Discovery
[*10/13/2024 23:23:17.9580] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:23:27.9590]
[*10/13/2024 23:23:27.9590] CAPWAP State: Discovery
[*10/13/2024 23:23:27.9600] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:23:33.2670] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:23:37.9620]
[*10/13/2024 23:23:37.9620] CAPWAP State: Discovery
[*10/13/2024 23:23:37.9620] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:23:47.9650]
[*10/13/2024 23:23:47.9650] CAPWAP State: Discovery
[*10/13/2024 23:23:47.9660] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:23:47.9660] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:23:47.9670] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:23:48.6270] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:23:48.6950] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:23:54.0610] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:23:54.1290] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:23:54.2990] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:23:59.9680]
[*10/13/2024 23:23:59.9680] CAPWAP State: Discovery
[*10/13/2024 23:23:59.9690] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:24:09.5960] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:24:09.9720]
[*10/13/2024 23:24:09.9720] CAPWAP State: Discovery
[*10/13/2024 23:24:09.9730] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:24:14.8260] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:24:19.9760]
[*10/13/2024 23:24:19.9760] CAPWAP State: Discovery
[*10/13/2024 23:24:19.9770] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:24:29.9770]
[*10/13/2024 23:24:29.9770] CAPWAP State: Discovery
[*10/13/2024 23:24:29.9780] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:24:30.2120] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:24:39.9800]
[*10/13/2024 23:24:39.9800] CAPWAP State: Discovery
[*10/13/2024 23:24:39.9810] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:24:39.9810] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:24:39.9810] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:24:40.4130] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:24:45.8060] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:24:45.8740] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:24:46.0410] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:24:51.9850]
[*10/13/2024 23:24:51.9850] CAPWAP State: Discovery
[*10/13/2024 23:24:51.9870] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:24:51.9870] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
Login failed, lockout for 4 seconds
% Authentication failed
No valid user found, please configure a valid user from Controller[*10/13/2024 23:25:01.9880]
[*10/13/2024 23:25:01.9880] CAPWAP State: Discovery
[*10/13/2024 23:25:01.9890] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:25:06.5670] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:25:11.7970] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:25:11.9910]
[*10/13/2024 23:25:11.9910] CAPWAP State: Discovery
[*10/13/2024 23:25:11.9920] Not sending discovery request, AP does not have an IP!!
No valid user found, please configure a valid user from Controller[*10/13/2024 23:25:21.9950]
[*10/13/2024 23:25:21.9950] CAPWAP State: Discovery
[*10/13/2024 23:25:21.9950] Not sending discovery request, AP does not have an IP!!
No valid user found, please configure a valid user from Controller[*10/13/2024 23:25:27.1620] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:25:31.9970]
[*10/13/2024 23:25:31.9970] CAPWAP State: Discovery
[*10/13/2024 23:25:31.9970] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:25:31.9980] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:25:31.9980] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:25:32.2950] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:25:37.5870] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:25:37.7540] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:25:43.0000]
[*10/13/2024 23:25:43.0000] CAPWAP State: Discovery
[*10/13/2024 23:25:43.0010] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:25:43.0010] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:25:48.1520] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:25:53.0030]
[*10/13/2024 23:25:53.0030] CAPWAP State: Discovery
[*10/13/2024 23:25:53.0040] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:26:03.0060]
[*10/13/2024 23:26:03.0060] CAPWAP State: Discovery
[*10/13/2024 23:26:03.0070] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:26:03.5130] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:26:13.0080]
[*10/13/2024 23:26:13.0080] CAPWAP State: Discovery
[*10/13/2024 23:26:13.0130] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:26:23.0120]
[*10/13/2024 23:26:23.0120] CAPWAP State: Discovery
[*10/13/2024 23:26:23.0130] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:26:23.0130] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:26:23.0130] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:26:23.9380] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:26:24.0060] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:26:29.2960] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:26:29.4620] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:26:35.0150]
[*10/13/2024 23:26:35.0150] CAPWAP State: Discovery
[*10/13/2024 23:26:35.0280] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:26:39.6970] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:26:44.9250] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:26:45.0180]
[*10/13/2024 23:26:45.0180] CAPWAP State: Discovery
[*10/13/2024 23:26:45.0190] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:26:55.0210]
[*10/13/2024 23:26:55.0210] CAPWAP State: Discovery
[*10/13/2024 23:26:55.0220] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:27:00.2950] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:27:05.0230]
[*10/13/2024 23:27:05.0230] CAPWAP State: Discovery
[*10/13/2024 23:27:05.0240] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:27:15.0270]
[*10/13/2024 23:27:15.0270] CAPWAP State: Discovery
[*10/13/2024 23:27:15.0270] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:27:15.0270] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:27:15.0270] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:27:15.6550] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:27:15.7240] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:27:21.1100] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:27:21.1780] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:27:21.3450] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:27:27.0310]
[*10/13/2024 23:27:27.0310] CAPWAP State: Discovery
[*10/13/2024 23:27:27.0320] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:27:36.6430] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:27:37.0330]
[*10/13/2024 23:27:37.0330] CAPWAP State: Discovery
[*10/13/2024 23:27:37.0340] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:27:41.8760] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:27:47.0370]
[*10/13/2024 23:27:47.0370] CAPWAP State: Discovery
[*10/13/2024 23:27:47.0380] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:27:57.0420]
[*10/13/2024 23:27:57.0420] CAPWAP State: Discovery
[*10/13/2024 23:27:57.0430] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:27:57.2520] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:28:07.0430]
[*10/13/2024 23:28:07.0430] CAPWAP State: Discovery
[*10/13/2024 23:28:07.0430] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:28:07.0430] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:28:07.0430] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:28:07.4480] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:28:12.8110] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:28:12.8800] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:28:13.0480] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:28:19.0460]
[*10/13/2024 23:28:19.0460] CAPWAP State: Discovery
[*10/13/2024 23:28:19.0470] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:28:19.0470] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:28:29.0490]
[*10/13/2024 23:28:29.0490] CAPWAP State: Discovery
[*10/13/2024 23:28:29.0500] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:28:33.5730] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:28:38.8150] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:28:39.0520]
[*10/13/2024 23:28:39.0520] CAPWAP State: Discovery
[*10/13/2024 23:28:39.0520] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:28:49.0540]
[*10/13/2024 23:28:49.0540] CAPWAP State: Discovery
[*10/13/2024 23:28:49.0550] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:28:54.1770] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:28:59.0580]
[*10/13/2024 23:28:59.0580] CAPWAP State: Discovery
[*10/13/2024 23:28:59.0590] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:28:59.0590] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:28:59.0590] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:28:59.3120] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:29:04.6000] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:29:04.7660] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:29:10.0610]
[*10/13/2024 23:29:10.0610] CAPWAP State: Discovery
[*10/13/2024 23:29:10.0610] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:29:10.0620] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:29:15.1610] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:29:20.0640]
[*10/13/2024 23:29:20.0640] CAPWAP State: Discovery
[*10/13/2024 23:29:20.0650] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:29:30.0670]
[*10/13/2024 23:29:30.0670] CAPWAP State: Discovery
[*10/13/2024 23:29:30.0680] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:29:30.5190] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:29:40.0720]
[*10/13/2024 23:29:40.0720] CAPWAP State: Discovery
[*10/13/2024 23:29:40.0730] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:29:50.0730]
[*10/13/2024 23:29:50.0730] CAPWAP State: Discovery
[*10/13/2024 23:29:50.0730] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:29:50.0730] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:29:50.0730] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:29:50.9450] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:29:51.0140] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:29:56.3070] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:29:56.4770] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:30:02.0770]
[*10/13/2024 23:30:02.0770] CAPWAP State: Discovery
[*10/13/2024 23:30:02.0770] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:30:06.7120] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:30:11.9410] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:30:12.0790]
[*10/13/2024 23:30:12.0790] CAPWAP State: Discovery
[*10/13/2024 23:30:12.0800] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:30:22.0830]
[*10/13/2024 23:30:22.0830] CAPWAP State: Discovery
[*10/13/2024 23:30:22.0840] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:30:27.3120] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:30:32.0860]
[*10/13/2024 23:30:32.0860] CAPWAP State: Discovery
[*10/13/2024 23:30:32.0870] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:30:42.0870]
[*10/13/2024 23:30:42.0870] CAPWAP State: Discovery
[*10/13/2024 23:30:42.0880] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:30:42.0880] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:30:42.0880] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:30:42.6680] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:30:42.7370] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:30:48.1350] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:30:48.2020] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:30:48.3680] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:30:54.0910]
[*10/13/2024 23:30:54.0910] CAPWAP State: Discovery
[*10/13/2024 23:30:54.0920] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:31:03.6640] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:31:04.0950]
[*10/13/2024 23:31:04.0950] CAPWAP State: Discovery
[*10/13/2024 23:31:04.0950] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:31:08.8960] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:31:14.0970]
[*10/13/2024 23:31:14.0970] CAPWAP State: Discovery
[*10/13/2024 23:31:14.0980] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:31:24.1040]
[*10/13/2024 23:31:24.1040] CAPWAP State: Discovery
[*10/13/2024 23:31:24.1050] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:31:24.2830] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
No valid user found, please configure a valid user from Controller[*10/13/2024 23:31:34.1040]
[*10/13/2024 23:31:34.1040] CAPWAP State: Discovery
[*10/13/2024 23:31:34.1050] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:31:34.1050] Discovery failed 5 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*10/13/2024 23:31:34.1050] Discovery failed. dhcp_renew being set to true
[*10/13/2024 23:31:34.4810] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:31:39.8470] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:31:39.9150] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:31:40.0820] Check whether client_ip_table entry need to be cleared 1
[*10/13/2024 23:31:46.1070]
[*10/13/2024 23:31:46.1070] CAPWAP State: Discovery
[*10/13/2024 23:31:46.1070] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:31:46.1080] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
e▒▒▒m▒(%]X▒&▒mH▒▒HELO
5.0205HNDRC1a-1.0.38-163.162
CPU0
L1CD
MMUI
MMUA
CODE
ZBBS
MAIN
Boot Strap Register: 0x6fc7b
NVRAM memcfg 0x60607
DDR3-1600 CL11 total 2048MB 4 8bits part[s]
DDR test done successfully
CFE Version: 5
Verifying MASTER U-Boot...
Launching MASTER U-Boot version 0x0062 ...
____ _
/ ___|(_) ___ ___ ___
| | | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
\____||_||___/ \___|\___/
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
U-Boot 2017.09 (Jul 28 2023 - 19:54:06 -0700) Broadcom BCM49408
Board: VANC-i
I2C: ready
DRAM: 2 GiB
enable MMU ... OK
NAND: Status wait timeout: nandsts=0x0 mask=0x40000000, count=0
NAND ECC BCH-8, page size 4096 bytes, spare size used 216 bytes
1024 MiB
MMC:
SF: Detected mx25l6405d with page size 256 Bytes, erase size 4 KiB, total 8 MiB
In: serial
Out: serial
Err: serial
Platform: 4908
pmc_init:PMC using DQM mode
pmc_patch_4908:7 0 23e044e 3370331
Board IP address : 192.168.1.1:ffffff00
Host IP address : 192.168.1.200
Gateway IP address : 10.1.1.1
Run from flash/host/tftp (f/h/c) : f
Default host run file name : vmlinux
Default host flash file name : bcm963xx_fs_kernel
Boot delay (0-9 seconds) : 3
Default host ramdisk file name :
Default ramdisk store address :
Board Id (0-18) : VANC_54991
Number of MAC Addresses (1-32) : 11
Base MAC Address : c8:28:e5:6f:a7:14
PSI Size (1-128) KBytes : 48
Enable Backup PSI [0|1] : 0
System Log Size (0-256) KBytes : 0
Auxillary File System Size Percent: 0
flow memory allocation (MB) : 43
buffer memory allocation (MB) : 16
DHD 0 memory allocation (MB) : 0
DHD 1 memory allocation (MB) : 0
DHD 2 memory allocation (MB) : 0
Partition 1 Size (MB) : 0M
Partition 2 Size (MB) : 0M
Partition 3 Size (MB) : 0M
Partition 4 Size (MB) (Data) : 4M
BootImage: MASTER
Found external PHY firmware image
MTDPART Str = (mtdparts=nand:1m(nvram),5888k(bootfs),-(fs))
Net: Registering Ethernet Driver.....
Broadcom BCM 4908 Ethernet driver 0.1
pmc_switch_power_up: Rgmii Tx clock zone1 enable 0 zone2 enable 0.
swap_pair = 0
Detecting PHYs...
84880 A0 ae02:5158 --> N/A
84881 A0 ae02:5150 --> N/A
84884 A0 ae02:5148 --> N/A
84884E A0 ae02:5168 --> N/A
84885 A0 ae02:5178 --> N/A
84886 A0 ae02:5170 --> N/A
84887 A0 ae02:5144 --> N/A
84888 A0 ae02:5140 --> N/A
84888E A0 ae02:5160 --> N/A
84888S A0 ae02:5174 --> N/A
84880 B0 ae02:5159 --> N/A
84881 B0 ae02:5151 --> N/A
84884 B0 ae02:5149 --> N/A
84884E B0 ae02:5169 --> N/A
84885 B0 ae02:5179 --> N/A
84886 B0 ae02:5171 --> N/A
84887 B0 ae02:5145 --> N/A
84888 B0 ae02:5141 --> N/A
84888E B0 ae02:5161 --> N/A
84888S B0 ae02:5175 --> N/A
84891 A0 3590:5090 --> N/A
54991 A0 3590:5094 --> N/A
54991E A0 3590:5098 --> N/A
84891L A0 3590:5080 --> N/A
54991L A0 3590:5084 --> N/A
54991EL A0 3590:5088 --> N/A
84892 A0 3590:50a0 --> N/A
54992 A0 3590:50a4 --> N/A
54992E A0 3590:50a8 --> N/A
84894 A0 3590:50b0 --> N/A
54994 A0 3590:50b4 --> N/A
54994E A0 3590:50b8 --> N/A
54991H A0 3590:50d0 --> N/A
54994H A0 3590:50f0 --> N/A
84891 B0 3590:5091 --> N/A
54991 B0 3590:5095 --> N/A
54991E B0 3590:5099 --> N/A
84891L B0 3590:5081 --> N/A
54991L B0 3590:5085 --> N/A
54991EL B0 3590:5089 --> 0x1f
84892 B0 3590:50a1 --> N/A
54992 B0 3590:50a5 --> N/A
54992E B0 3590:50a9 --> N/A
84894 B0 3590:50b1 --> N/A
54994 B0 3590:50b5 --> N/A
54994E B0 3590:50b9 --> N/A
54991H B0 3590:50d1 --> N/A
54994H B0 3590:50f1 --> N/A
Loading firmware into detected phys...
Firmware version: Blackfin B0 v02-02-03-2020-03-16
Loading firmware into phys: map=0x80000000
Halt the phys processors operation
Upload the firmware into the on-chip memory
100%
Reset the processors to start execution of the code in the on-chip memory
Verify that the processors are running: OK
Verify that the firmware has been loaded with good CRC: OK
Firmware loading completed successfully
Unsupported MII type: 0
bcm4908_eth-0
MAC: c8:28:e5:6f:a7:14
Hit ESC key to stop autoboot: 0
u-boot> MG link 1G
nknown command 'ry 'help'
u-boot>
Unknown command 'ry 'help'
u-boot> dir flash:
Unknown command 'dir' - try 'help'
u-boot> help
? - alias for 'help'
base - print or set address offset
bdinfo - print Board Info structure
boardinit- Download MFG boardinit bundle and burn images to its repective location
boot - boot default, i.e., run 'bootcmd'
bubt - Burn image to NOR flash boot device
chpart - change active partition
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
crc32 - checksum calculation
dm - Driver model low level access
echo - echo args to console
editenv - edit environment variable
env - environment handling commands
erase - erase FLASH memory
erase_nvram- Erase NVRAM
erase_persistent_data- Erase Persistent Data
exit - exit script
false - do nothing, unsuccessfully
fdt - flattened device tree utility commands
fipsalgval- run algorithm validation on test vector bibnar in memory, default:2000000 (0x02000000)
flinfo - print FLASH memory information
forceboot- force boot from u-boot image
fuse - Fuse sub-system
gpio - Read/Write Gpio Pins
help - print command description/usage
i2c - I2C sub-system
iminfo - print header information for application image
imxtract- extract a part of a multi-image
itest - return true/false on integer compare
ledstate- Set Led State
lzmadec - lzma uncompress a memory region
meminfo - display memory information
mtdparts- define flash/nand partitions
nand - NAND sub-system
nandboot- boot Linux from NAND partition
netboot - boot Linux from network using TFTP/bootp
pci - list and access PCI Configuration Space
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
protect - enable or disable FLASH write protection
reset - Perform RESET of the CPU
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
setboardparms- Set Board Params
setbootline- Set Boot Params
setenv - set environment variables
setexpr - set environment variable as the result of eval expression
sf - SPI flash sub-system
showvar - print local hushshell variables
sleep - delay execution for some time
source - run script from memory
sspi - SPI utility command
test - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
true - do nothing, successfully
ubi - ubi commands
ubifsload- load file from an UBIFS filesystem
ubifsls - list files in a directory
ubifsmount- mount UBIFS volume
ubifsumount- unmount UBIFS volume
usb - USB sub-system
version - print monitor, compiler and linker version
u-boot>
cp - memory copy
exit - exit script
ubi - ubi commands
u-boot> ]
Unknown command ']' - try 'help'
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot> setenv ipaddr 10.148.9.150
u-boot> setenv netmask 255.255.255.128
u-boot> setenv serverip 172.20.154.30
u-boot> setenv gatewayip 10.148.9.129
Unknown command 'setenv' - try 'help'
u-boot> setenv ?
u-boot>
u-boot>
u-boot>
u-boot> setenv tftpdir
u-boot> saveenv
Saving Environment to SPI Flash...
Erasing SPI flash...Writing to SPI flash...done
u-boot> ping 172.20.154.30
Using bcm4908_eth-0 device
host 172.20.154.30 is alive
u-boot> boot
Mounting UBI device fs
ubi0: attaching mtd3
ubi0: scanning is finished
ubi0: attached mtd3 (name "mtd=2", size 1017 MiB)
ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
ubi0: good PEBs: 4059, bad PEBs: 10, corrupted PEBs: 0
ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 32/23, WL threshold: 4096, image sequence number: 38517316
ubi0: available PEBs: 33, total reserved PEBs: 4026, PEBs reserved for bad PEB handling: 70
Load Addr 0x10000000
Mount UBIFS PARTITION part2 ...
Loading file 'part2/part.bin' to addr 0x10000000...
Done
Checking image signing.
Image signing verification success for part part2 continue to run...
Multi Image Header Found
Count = 0 Offset = 0x10000050 Len = 11201184
Count = 1 Offset = 0x10aaeaf0 Len = 3784840
Count = 2 Offset = 0x10e4ab78 Len = 7246
Booting from Partition: part2
arg 0: 0x10000050
arg 1: 0x3000000
arg 2: 0x1800000
## Loading init Ramdisk from Legacy Image at 03000000 ...
Image Name: Simple Ramdisk Image
Created: 2024-07-16 19:38:42 UTC
Image Type: AArch64 Linux RAMDisk Image (lzma compressed)
Data Size: 3784776 Bytes = 3.6 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 01800000
Booting using the fdt blob at 0x1800000
load dtb from fixed memory location directly...
/memory = 0x80000000 bytes @ 0x0
Set Memory to 2147483648l
WARNING: Node's property /reserved-memory/dt_reserved_buffer is not defined
WARNING: Node's property /reserved-memory/dt_reserved_flow is not defined
Appending NVRAM to dtb, ret:0
Loaded DTB from 0x01800000 with size 7246l
Curr Boot Args: console=ttyS0,9600 activepart=part2 activeboot=0 bootver=0x62 boardid=0x2 forceboot=0 coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait crashkernel=128M@0M ttyS0 mtdparts=nand:1m(nvram),5888k(bootfs),-(fs) ubi.mtd=fs BOOT_DEBUG=0
DTB Boot Args (coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait crashkernel=128M@0M)
Bootargs set to setenv bootargs console=$consoledev,$baudrate activepart=part2 activeboot=0 bootver=0x62 boardid=0x2 forceboot=0 coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait crashkernel=128M@0M $console $nandEcc $mtdparts ubi.mtd=fs BOOT_DEBUG=0
Preferred boot heartbeat count: 5
Cleanup Complete.... ARMv8_secure_init_done!!!
Loading Ramdisk to 4fb09000, end 4fea5048 ... OK
reserving fdt memory region: addr=0 size=20000
Using Device Tree in place at 0000000001800000, end 0000000001804c4d
Starting kernel ...
[01/01/1970 00:00:05.1930] hub 3-0:1.0: config failed, hub doesn't have any ports! (err -19)
[01/01/1970 00:00:05.2850] brcmboard registered
[*01/01/1970 00:00:16.8440] buginf() enabled.
[*01/01/1970 00:00:16.8520] Made it into bootsh: Jul 16 2024 19:21:00 T-d7566c7fa1151e24600b21806f0b6442a72b2b97M-g9c64e512-aut
[*01/01/1970 00:00:25.8220] bootsh mini ramfs booted /bootpart/part2/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
Press S for a shell, or another magic key...
[ OK ] Reached target Timers.
[ OK ] Reached target Cisco File Systems (Pre).
[ OK ] Created slice -.slice.
ڵ▒5▒j▒ OK ] Reached target Sockets.wn Socket.
[ OK ] Created slice system.slice.
Starting Cisco SE-Linux fixfiles script...
[ OK ] Created slice system-sshd\x2dkeygen.slice.
[ OK ] Reached target Slices.
Starting Cisco UBIFS reformat/mount...
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Started Cisco UBIFS reformat/mount.
Starting Cisco early mount...
[ OK ] Started Cisco early mount.
[ OK ] Reached target Local File Systems (Pre).
Starting Cisco fips check...
Starting Cisco platform file generation...
Starting Cisco system time setup...
Starting Cisco seed generation...
[ OK ] Started Cisco system time setup.
[ OK ] Started Cisco seed generation.
[*01/01/1970 00:00:45.2870] root: Cisco Axel file system mounting
[*01/05/2023 23:59:59.0170] Last reload time: Oct 13 23:14:33 2024
[*10/13/2024 23:14:33.0000] Setting system time Sun Oct 13 23:14:33 UTC 2024
[*10/13/2024 23:14:33.0800] GCM-128 POST passed
[*10/13/2024 23:14:33.0800] GCM-256 POST passed
[*10/13/2024 23:14:33.1510] Auxiliary radio device detected
[ OK ] Started Cisco fips check.
[ OK ] Started Cisco platform file generation.
Starting Cisco btldr service...
▒▒▒▒&▒ ] Started Cisco btldr service.
z-▒ ] Reached target Local File Systems.
[*10/13/2024 23:14:33.6920]
[*10/13/2024 23:14:33.6920] [10/13/2024 23:15:34] : Shadow is now in-synced with master
Starting Cisco system time saving...
Starting Cisco act2 check...
Starting Cisco pkg install service...
Starting Cisco S10 boot service...
[ OK ] Started Cisco system time saving.
[10/13/2024 23:14:34.6450] bcmlibs: module license 'Proprietary' taints kernel.
[10/13/2024 23:14:34.7230] Disabling lock debugging due to kernel taint
[10/13/2024 23:14:35.1580] bm_base_addr 0xffffffc006000000, size 67108864, bm_base_addr_phys 0x0000000006000000
[10/13/2024 23:14:35.2690] fm_base_addr 0xffffffc002e00000, size 12582912, fm_base_addr_phys 0x0000000002e00000
[10/13/2024 23:14:36.1240] Broadcom Command List Driver v1.0
[10/13/2024 23:14:36.2120] crossbar[0]: Allocated cb_idx=0 int_ep=0
[10/13/2024 23:14:36.2760] crossbar[0]: Add cb_idx=0 ext_ep=0 SERDES:6
[10/13/2024 23:14:36.3520]
[10/13/2024 23:14:36.3520] Detecting PHYs...
[10/13/2024 23:14:36.4300] Lift PHY at address 31 out of Reset by GPIO:31 Active Low
[10/13/2024 23:14:36.5260] 54991EL B0 3590:5089 --> 0x1f
[10/13/2024 23:14:36.5840]
[10/13/2024 23:14:36.5840] Loading firmware into detected PHYs...
[10/13/2024 23:14:36.7130] Firmware version: Blackfin B0 v02-02-03-2020-03-16
[10/13/2024 23:14:36.7960] Loading firmware into PHYs: map=0x80000000 count=1
[10/13/2024 23:14:36.8780] Halt the PHYs processors operation
[10/13/2024 23:14:36.9460] Upload the firmware into the on-chip memory
100%13/2024 23:14:37.0190]
[10/13/2024 23:14:40.2980] Reset the processors to start execution of the code in the on-chip memory
[10/13/2024 23:14:40.4030] Verify that the processors are running: [* ] (1 of 4) A start job is running for... S10 boot service (9s / 3min 3s)[*10/13/2024 23:14:34.3290] 13
[*10/13/2024 23:14:34.4290] Active version: 17.12.4.22
[*10/13/2024 23:14:34.4320] Backup version: OK
[10/13/2024 23:14:40.9620] Verify that the firmware has been loaded with good CRC: OK
[10/13/2024 23:14:41.0530] Firmware loading completed successfully
[10/13/2024 23:14:41.1540] Adjusted SF2 SGPHY: sphy_ctrl=0x00010c1b
17.9.4.27
[*[10/13/2024 23:14:41.2380] getrcal for res select 5, int 669, ext 642, ratio 122 ratio1 152, rcal 9
[10/13/2024 23:14:41.3450] Setting SGMII Calibration value to 0x9
[10/13/2024 23:14:41.4150] PLL_PON(8051): 0x0250; TX_PON(8067): 0x0048; RX_PON(80b2): 0x0980
10/13/2024 23:14:34.6290] Loading BCM modules ...
[*10/13/2024 23:14:34.6290] Ignore pptp.ko
[*10/13/2024 23:14:34.6320] Ignore pktflow.ko
[*10/13/2024 23:14:34.6340] Ignore pktrunner.ko
[*10/13/2024 23:14:34.6370] Load bcmlibs.ko
[*10/13/2024 23:14:34.7990] BCMLIBS loaded...
[*10/13/2024 23:14:34.8130] Load wlcsm.ko
[*10/13/2024 23:14:34.8390] Load rdp_fpm.ko
[*10/13/2024 23:14:34.8860] Load bdmf.ko
[*10/13/2024 23:14:34.9150] Load proclikefs.ko
[*10/13/2024 23:14:34.9370] Load rdpa_gpl.ko
[*10/13/2024 23:14:34.9620[10/13/2024 23:14:42.0760] dgasp: kerSysRegisterDyingGaspHandler: bcmsw registered
] Load rdpa_gpl_ext.ko
[*10/13/2024 23:14:34.9840] Load rdpa.ko
[*10/13/2024 23:14:35.0520] Load rdpa_usr.ko
[*10/13/2024 23:14:35.0860] Load rdpa_mw.ko
[*10/13/2024 23:14:35.3870] RDP Physical address=0x82200000 Virtual address = 0xffffff8001c80000
[*10/13/2024 23:14:35.4000] configure_runner: NATC keysize 0x100070 key element size 16 contextsize 0x400000 context element size 64
[*10/13/2024 23:14:35.4010] ++++Runner gso_desc_pool created successfully
[*10/13/2024 23:14:35.8880] FPM_BPM phy_addr 0x82c30000,virt_addr 0xffffff800197e000
[*10/13/2024 23:14:35.8880] RDP PKT memory = 64MB : Max Possible Bufs <16384> of size <4096>; Allocating <15360> bufs; RDP enum <5>
[*10/13/2024 23:14:36.0460] Load chipinfo.ko
[*10/13/2024 23:14:36.0560] brcmchipinfo: brcm_chipinfo_init entry
[*10/13/2024 23:14:36.0700] Load rdpa_cmd.ko
[*10/13/2024 23:14:36.1070] Load cmdlist.ko
[*10/13/2024 23:14:36.1950] Load bcm_enet.ko
[*10/13/2024 23:14:36.3510] crossbar Mux: connect cb_idx:0 int_ep 0 to ext_ep 0
[*10/13/2024 23:14:36.3510] crossbar Mux: connect cb_idx:0 int_ep 1 to ext_ep 2
[*10/13/2024 23:14:39.0640]
[*10/13/2024 23:14:39.0640] Authenticating ACT2 ID:C9120 Authenticating SN:FOC26514LG9
[*10/13/2024 23:14:39.0640] (ACT2Boot) Hardware is Cisco (c) authentic
[*10/13/2024 23:14:39.0710] Seeding /dev/urandom from ACT2
[*10/13/2024 23:14:40.7680] Reading ACT2 SUDI certificates
[*10/13/2024 23:14:41.2270] NOTE: Using Port Grouping for IMP ports : [ 0 --> 4 ] [ 1, 2 --> 5 ] [ 3, 7 --> 8 ]
[*10/13/2024 23:14:42.0760] eth0: Down <28:e5:6f:a7:14> PHY_ID <0x0007f008:0x08: On-chip 1G GPHY> Cfg: ANG.1G; Down
[*10/13/2024 23:14:42.0760] eth1: Down <28:e5:6f:a7:14> PHY_ID <0x0007f009:0x09: On-chip 1G GPHY> Cfg: ANG.1G; Down
[*10/13/2024 23:14:42.0760] eth2: Down <28:e5:6f:a7:14> PHY_ID <0x0007f00a:0x0a: On-chip 1G GPHY> Cfg: ANG.1G; Down
[*10/13/2024 23:14:42.0760] eth3: Down <28:e5:6f:a7:14> PHY_ID <0x0007f00b:0x0b: On-chip 1G GPHY> Cfg: ANG.1G; Down
[*10/13/2024 23:14:42.0760] eth4: Down <28:e5:6f:a7:14>
[*10/13/2024 23:14:42.0760] Chip Port 9, CrossBar Port 0, PHY_ID <0x06100006:0x06: On-chip 2.5G SERDES> Cfg: ANG.2.5G; Down
[*10/13/2024 23:14:42.0760] PHY_ID <0x0388001f:0x1f:External Cascaded 10G EXT3> Cfg: ANG.2.5G; Down
[*10/13/2024 23:14:42.0760] ===> Activate Deep Green Mode
[*10/13/2024 23:14:42.0760] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link DOWN
[*10/13/2024 23:14:42.3430] Auto Detection of Serdes: Enabled
[*10/13/2024 23:14:42.3430] PHY Capabilities: 2.5GFD|1GFD|100MFD
[*10/13/2024 23:14:42.3430] Link is Down.
[*10/13/2024 23:14:42.8140] ret code = 0.
[*10/13/2024 23:14:42.8220] wired0 Link encap:Ethernet HWaddr C8:28:E5:6F:A7:14
[*10/13/2024 23:14:42.8220] UP BROADCAST MULTICAST MTU:2044 Metric:1
[*10/13/2024 23:14:42.8220] RX packets:13512 errors:0 dropped:1153 overruns:0 frame:0
[*10/13/2024 23:14:42.8220] TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
[*10/13/2024 23:14:42.8220] collisions:0 txqueuelen:1000
[*10/13/2024 23:14:42.8220] RX bytes:1697530 (1.6 MiB) TX bytes:256 (256.0 B)
[*10/13/2024 23:14:42.8250] C8:28:E5:6F:A7:14
[*10/13/2024 23:14:42.8250] BCM11ax AP: MIC Certificate Present
[*01/05/2023 23:59:59.0090] Last reload time: Oct 13 23:14:33 2024
[*10/13/2024 23:14:33.5630] Last reload reason : 0: unknown
[*10/13/2024 23:14:35.3880] <=== Deactivate Deep Green Mode
[*10/13/2024 23:14:35.3880] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link UP
[*10/13/2024 23:14:35.3880] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link Up at 1000 mbps full duplex
[*10/13/2024 23:14:35.5050]
[*10/13/2024 23:14:35.5050] ACT2 Check passed
[ OK ] Started Cisco SE-Linux fixfiles script.
[ OK ] Started Cisco act2 check.
ڵ▒5▒j▒ OK ] Started Cisco S10 boot service.
Starting Cisco nss service...
Starting Cisco nolan service...
Starting Cisco watchdog...
*▒х▒ѥ▒▒▒Tam server...server.
Starting Cisco Tam service...
[ OK ] Started Cisco watchdog.
[ OK ] Started Cisco nss service.
[ OK ] Started Cisco nolan service.
Starting Cisco nolan USB service...
Starting Cisco Kclick...
Starting Cisco S15platform...
[ OK ] Started Cisco Tam service.
[*10/13/2024 23:14:37.4650] starting tam services using ACT2...
[ OK ] Started Cisco nolan USB service.
Starting Cisco pre-PoE negotiation...
[*10/13/2024 23:14:37.6880] Loading HND Module
[ OK ] Started Cisco pre-PoE negotiation.
[*10/13/2024 23:14:37.8120] NTKM - ntkm_init - Nitro KM loaded
[ OK ] Started Cisco Kclick.
[ OK ] Started Cisco S15platform.
Starting Cisco ME service...
[*10/13/2024 23:14:39.6650] Starting check if backup WiFi NVRAM are available
[*10/13/2024 23:14:39.6650] WiFi backup nvram - crc = 3048188091
[*10/13/2024 23:14:39.6650] WiFi active nvram - crc =617
[*10/13/2024 23:14:39.6650] [WARNING]ACTIVE and BACKUP NVRAM NOT use same data
[*10/13/2024 23:14:39.6850] restore done!
[*10/13/2024 23:14:39.6910] restore done!
Starting Cisco certificate create service...
Starting Cisco Sku service...
Starting Cisco sysctl service...
[ OK ] Started Cisco Sku service.
[ OK ] Started Cisco sysctl service.
[10/13/2024 23:14:40.5610] broadcomThermalDrv brcm-therm: init (CPU count 4 4 4 4)
[ OK ] Started Cisco ME service.
[ OK ] Started Cisco certificate create service.
Starting Cisco brain service...
[*10/13/2024 23:14:40.8860] crypto worker thread started
[*10/13/2024 23:14:40.8880] crypto worker thread started
[*10/13/2024 23:14:40.9180] Broadcom EAP Forwarder v0.1 is loaded
[*10/13/2024 23:14:40.9690] igs_module_init:867: IGS 18 create network socket successful
[*10/13/2024 23:14:41.0840] Wifi Forwarding Driver is initialized!
[*10/13/2024 23:14:41.3990] wl_module_init: passivemode set to 0x1
[*10/13/2024 23:14:41.3990] wl_module_init: txworkq set to 0x0
[*10/13/2024 23:14:41.4000] wl_pktfwd_sys_init: WL_PKTFWD[1.1.0] Success
[*10/13/2024 23:14:41.4070] wl0: phy_radio_attach: RF Band Cap: 2G:1 5G:1
[*10/13/2024 23:14:41.4380]
[*10/13/2024 23:14:41.4380] WLC_ATTACH routine completed successfully
[*10/13/2024 23:14:41.4390] wl_wfd_bind: wl0 wfd_idx 0 success
[*10/13/2024 23:14:41.4400] apr1v0: Broadcom BCM43684 802.11 Wireless Controller 17.20.10 (r790816 WLTEST)
[*10/13/2024 23:14:41.4480] wl1: phy_radio_attach: RF Band Cap: 2G:1 5G:1
[*10/13/2024 23:14:41.4790]
[*10/13/2024 23:14:41.4790] WLC_ATTACH routine completed successfully
[*10/13/2024 23:14:41.4800] wl_wfd_bind: wl1 wfd_idx 1 success
[*10/13/2024 23:14:41.4800] apr0v0: Broadcom BCM43684 802.11 Wireless Controller 17.20.10 (r790816 WLTEST)
[*10/13/2024 23:14:41.8270] First unregister unused apps
[*10/13/2024 23:14:41.8270] Enumerating apps...
[*10/13/2024 23:14:41.8290] 4 registered apps:
[*10/13/2024 23:14:41.8290] 0: capwapd
[*10/13/2024 23:14:41.8290] 1: IOSd_App
[*10/13/2024 23:14:41.8290] 2: IOXCAF_App
[*10/13/2024 23:14:41.8290] 3: aurora
[*10/13/2024 23:14:41.8290] Finish unregister all unused apps in catalyst mode
Starting rsyslog client...
Starting Cisco synclogd...
Starting Cisco S16platfomm...
[ OK ] Started Cisco synclogd.
[ OK ] Started rsyslog client.
[*10/13/2024 23:14:43.7370] pid 3869's current affinity mask: f
[*10/13/2024 23:14:43.7370] pid 3869's new[ OK ] Started Cisco brain service.
[ OK ] Started Cisco S16platfomm.
Starting RHL daemon...
[*10/13/2024 23:14:44.4290] chatter: '' not a write handler
[*10/13/2024 23:14:44.5270] chatter: '' not a write handler
[*10/13/2024 23:14:44.5550] chatter: '' not a write handler
[*10/13/2024 23:14:44.5810] chatter: '' not a write handler
[*10/13/2024 23:14:44.6090] chatter: '' not a write handler
[*10/13/2024 23:14:44.6370] chatter: '' not a write handler
[*10/13/2024 23:14:44.6640] chatter: '' not a write handler
[*10/13/2024 23:14:44.6920] chatter: '' not a write handler
[*10/13/2024 23:14:44.7200] chatter: '' not a write handler
[*10/13/2024 23:14:44.7480] chatter: '' not a write handler
[*10/13/2024 23:14:44.7770] chatter: '' not a write handler
[*10/13/2024 23:14:44.8050] chatter: '' not a write handler
[*10/13/2024 23:14:44.8340] chatter: '' not a write handler
[*10/13/2024 23:14:44.8630] chatter: '' not a write handler
[*10/13/2024 23:14:44.8880] chatter: '' not a write handler
[*10/13/2024 23:14:44.8940] chatter: '' not a write handler
[*10/13/2024 23:14:44.8990] sh: /bin/bs: not found
[*10/13/2024 23:14:44.9630] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link DOWN.
[*10/13/2024 23:14:44.9630] ===> Activate Deep Green Mode
[*10/13/2024 23:14:44.9630] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link DOWN
[*10/13/2024 23:14:44.9770] chatter: Device wired0 notify state change link DOWN
[*10/13/2024 23:14:44.9790] <=== Deactivate Deep Green Mode
[*10/13/2024 23:14:44.9790] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link UP
[*10/13/2024 23:14:44.9790] Deep Green Mode feature changed to disabled (DGM status: deactivated)
[*10/13/2024 23:14:44.9790] WIFI Off (*) ==> Disable
[*10/13/2024 23:14:44.9790] DISK Off (*) ==> Disable
[*10/13/2024 23:14:44.9790] PCI ASPM (*) ==> Disable
[*10/13/2024 23:14:44.9790] PCI ASPM control is disabled in this image
[*10/13/2024 23:14:44.9790] UBUS DCM (*) ==> Disable
[*10/13/2024 23:14:44.9790] CPU Off (*) ==> Disable
[*10/13/2024 23:14:44.9790] CPU Wait (*) ==> Disable
[*10/13/2024 23:14:44.9790] CPU Speed (*) ==> Disable
[*10/13/2024 23:14:44.9790] XRDP Gate (*) ==> Disable
[*10/13/2024 23:14:44.9790] NET Down (*) ==> Disable
[*10/13/2024 23:14:44.9790] PHY Down (*) ==> Disable
[*10/13/2024 23:14:44.9790] PHY EEE (*) ==> Disable
[*10/13/2024 23:14:44.9790] PHY APD (*) ==> Disable
[*10/13/2024 23:14:44.9790] SF2 DGM (*) ==> Disable
[*10/13/2024 23:14:44.9790] DRAM SR (*) ==> Disable
[*10/13/2024 23:14:44.9790] AVS (*) ==> Disable
[*10/13/2024 23:14:45.0520]
[*10/13/2024 23:14:45.0520] !!!!! {/opt/cisco/bin/capwap_brain} Dnsmasq.conf file before update:
[*10/13/2024 23:14:45.0520] !!!!! {/opt/cisco/bin/capwap_brain} Dnsmasq.conf new config:
[*10/13/2024 23:14:45.0520] no-resolv
[*10/13/2024 23:14:45.0520] pid-file=/var/run/dnsmasq.vaperr.pid
[*10/13/2024 23:14:45.0520] port=5316
[*10/13/2024 23:14:45.0520] min-port=61000
[*10/13/2024 23:14:45.0520] address=/#/6.0.0.7
[*10/13/2024 23:14:45.0530]
[*10/13/2024 23:14:45.0530] !!!!! {/opt/cisco/bin/capwap_brain} Dnsmasq.conf file after update:
[*10/13/2024 23:14:45.0530] no-resolv
[*10/13/2024 23:14:45.0530] pid-file=/var/run/dnsmasq.vaperr.pid
[*10/13/2024 23:14:45.0530] port=5316
[*10/13/2024 23:14:45.0530] min-port=61000
[*10/13/2024 23:14:45.0530] address=/#/6.0.0.7
[*10/13/2024 23:14:45.4460]
[*10/13/2024 23:14:45.4460] !!!!! {/opt/cisco/bin/capwap_brain} Dnsmasq.conf file before update:
[*10/13/2024 23:14:45.4460] no-resolv
[*10/13/2024 23:14:45.4460] pid-file=/var/run/dnsmasq.vaperr.pid
[*10/13/2024 23:14:45.4460] port=5316
[*10/13/2024 23:14:45.4460] min-port=61000
[*10/13/2024 23:14:45.4460] address=/#/6.0.0.7
[*10/13/2024 23:14:45.4460] !!!!! {/opt/cisco/bin/capwap_brain} Dnsmasq.conf new config:
[*10/13/2024 23:14:45.4470]
[*10/13/2024 23:14:45.4470] !!!!! {/opt/cisco/bin/capwap_brain} Dnsmasq.conf file after update:
[*10/13/2024 23:14:45.4470] no-resolv
[*10/13/2024 23:14:45.4470] pid-file=/var/run/dnsmasq.vaperr.pid
[*10/13/2024 23:14:45.4470] port=5316
[*10/13/2024 23:14:45.4470] min-port=61000
[*10/13/2024 23:14:45.4470] address=/#/6.0.0.7
[*10/13/2024 23:14:45.5150] ip6_port srcr2, ip6local ::, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[*10/13/2024 23:14:47.1130]
[*10/13/2024 23:14:47.1130] TAM init done
[*10/13/2024 23:14:47.1130] Object list for Device=ap-tam App[1] Count= 0
[*10/13/2024 23:14:47.1130] TAMS init: There is no Cloud ID in ACT2!
[*10/13/2024 23:14:47.7440]
[*10/13/2024 23:14:47.7440] Click sched monitor: schedulers = 1
[*10/13/2024 23:14:49.0720] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link Up at 1000 mbps full duplex
[*10/13/2024 23:14:49.0720] chatter: Device wired0 notify state change link UP
[*10/13/2024 23:14:50.0990] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/13/2024 23:14:50.2620] Check whether client_ip_table entry need to be cleared 0
[*10/13/2024 23:14:50.2620] Clearing client entry
[10/13/2024 23:14:51.4150] NXP-RHL-Driver 0001:01:00.0: RHL: AP SKU = 0, pow min,max = -4, 20
[10/13/2024 23:14:51.4150] , Rx Diversity =0, 6g AP = 0, Ithaca Esku =0
[10/13/2024 23:14:51.6130] NXP-RHL-Driver 0001:01:00.0: Final VSPA image size val 0xf30000
[10/13/2024 23:14:52.5070] bcm963xx-pcie: RHL legacy interrupt initialized
[ OK ] Started RHL daemon.
[ OK ] Reached target System Initialization.
[ OK ] Reached target Paths.
[ OK ] Reached target Basic System.
Starting Security Auditing Service...
Starting Cisco printkd...
[*10/13/2024 23:14:51.1790] rhl_reset : got minor 56
[*10/13/2024 23:14:51.4150] ip6_port srcr2, ip6local ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[*10/13/2024 23:14:51.7030] V2H call back init
[*10/13/2024 23:14:51.7030] V2H callback registered
Starting Cisco klogd...
Starting RHL monitor/reset daemon...
Starting NTP_PROC daemon...
Starting Sensord daemon...
[ OK ] Started Serial Getty on ttyS0.
▒▒▒▒&▒ Starting Serial Getty on ttyS0...
z-▒ ] Reached target Login Prompts.
Starting platform manager process...
Starting RSYNC User Key Generation...
[ OK ] Started RHL monitor/reset daemon.
[*10/13/2024 23:14:53.7170] reset device opened
[ OK ] Started NTP_PROC daemon.
[ OK ] Started platform manager process.
[ OK ] Started Cisco printkd.
[ OK ] Started Cisco klogd.
Starting ntp file watcher...
[*10/13/2024 23:14:54.0290] No valid NTP source
[*10/13/2024 23:14:54.0290] No valid ntp server info file. Stop NTP!
Starting WCPD process...
[ OK ] Started ntp file watcher.
Starting ntp watcher...
[ OK ] Started ntp watcher.
[ OK ] Started Sensord daemon.
[ OK ] Started WCPD process.
Starting capwapd...
[ OK ] Started capwapd.
Starting System Monitor service...
Starting gRPC daemon...
[ OK ] Started ble_transport daemon.
Starting ble_transport daemon...
Starting Cisco kexec...
Starting Hostapd process...
Starting Fast CGI daemon...
Starting Cisco rtd service...
Starting DNSmasq...
Starting Cisco led service...
Starting BLE init service...
Starting Cisco image/firmware updater service...
[*10/13/2024 23:14:55.3700] chpasswd: password for user changed
Starting Clean Air daemon...
[*10/13/2024 23:14:55.4950] EEPROM Size = 65536
[*10/13/2024 23:14:55.4950] loading pow table from EEPROM to scratch buf
[*10/13/2024 23:14:55.4950] 10200 bytes copied from RHL EEPROM to scratch buf
[*10/13/2024 23:14:55.5040] DOT11_TXP[0]:Domain configured: 0 class:A
[*10/13/2024 23:14:55.5870] DOT11_TXP[0]:Regdb file: /radio_fw/C9120AXI_power_table_mapping.txt
[*10/13/2024 23:14:55.5970] DOT11_TXP[0]:Domain configured: 48 class:Z
[*10/13/2024 23:14:55.8850] DOT11_TXP[0]:Regdb file: /radio_fw/C9120AXI_power_table_mapping.txt
[*10/13/2024 23:14:55.9010] DOT11_TXP[0]:Domain configured: 48 class:Z
Starting iCAP daemon...
[*10/13/2024 23:14:56.1620] DOT11_TXP[0]:Regdb file: /radio_fw/C9120AXI_power_table_mapping.txt
[*10/13/2024 23:14:56.2710] capwapd log into tam successful
[*10/13/2024 23:14:56.2710] SUCCESS TAM
[*10/13/2024 23:14:56.2720] #### board_data_init: num_slots (2), num_radios (2)
Starting AP Trace daemon...
Starting awips daemon...
[ OK ] Started RSYNC User Key Generation.
[ OK ] Started System Monitor service.
[ OK ] Started BLE init service.
[ OK ] Started iCAP daemon.
[*10/13/2024 23:14:56.8220]
[*10/13/2024 23:14:56.8220] [10/13/2024 23:15:57] updt_util: PHY firmware is up to date
[*10/13/2024 23:14:56.8310]
[*10/13/2024 23:14:56.8310] [10/13/2024 23:15:57] updt_util: All bootloaders are up to date
[ OK ] Started awips daemon.
[ OK ] Started Cisco kexec.
[ OK ] Started Cisco led service.
[ OK ] Started Cisco image/firmware updater service.
[ OK ] Reached target sshd-keygen.target.
Starting CiscoSSH server daemon...
[ OK ] Started Cisco rtd service.
[*10/13/2024 23:14:57.5580] EEPROM Size = 65536
[*10/13/2024 23:14:57.5580] loading trx table from EEPROM to DTC[ OK ] Started AP Trace daemon.
[ OK ] Started Hostapd process.
[ OK ] Started DNSmasq.
[ OK ] Started CiscoSSH server daemon.
[*10/13/2024 23:14:57.8530] DOT11_DRV[0]: BCM FIPS POST for CCMP-128 and GCMP-128 passed
[*10/13/2024 23:14:57.8530] DOT11_DRV[0]: Stop Radio0
[*10/13/2024 23:14:57.8530] Stopped Radio 0
[*10/13/2024 23:14:57.9020] NZ (NZ/0) NEW ZEALAND
[*10/13/2024 23:14:57.9200] DOT11_DRV[0]: set_channel Channel set to 6/20
[*10/13/2024 23:14:57.9290] pid 6377's current affinity mask: f
[*10/13/2024 23:14:57.9290] pid 6377's new affinity mask: 2
[*10/13/2024 23:14:58.1840] nimbus 1 Unable to load host key "/storage/ssh/ssh_host_rsa_key" - incorrect passphrase supplied to decrypt private key
[*10/13/2024 23:14:58.1850] Unable to load host key: /storage/ssh/ssh_host_rsa_key
[ OK ] Started Clean Air daemon.
[*10/13/2024 23:14:59.1880] DOT11_DRV[1]: BCM FIPS POST for CCMP-128 and GCMP-128 passed
[*10/13/2024 23:14:59.1880] DOT11_DRV[1]: Stop Radio1
[*10/13/2024 23:14:59.1880] Stopped Radio 1
[*10/13/2024 23:14:59.2190] NZ (NZ/0) NEW ZEALAND
[*10/13/2024 23:14:59.2250] DOT11_DRV[1]: set_channel Channel set to 36/20
No valid user found, please configure a valid user from Controller[*10/13/2024 23:14:59.9620] DOT11_DRV[2]: off_channel timeout but no req in progress
[*10/13/2024 23:15:00.8790] size: 17477 bytes (48059 left)
[*10/13/2024 23:15:01.1330] DOT11_DRV[0]: set_channel Channel set to 1/20
[*10/13/2024 23:15:02.2230] DOT11_DRV[0]: set_channel Channel set to 1/20
[*10/13/2024 23:15:03.1820] DOT11_DRV[0]: set_channel Channel set to 1/20
[*10/13/2024 23:15:03.5130] DOT11_DRV[0]: set_channel Channel set to 1/20
[*10/13/2024 23:15:04.8360] DOT11_DRV[0]: set_channel Channel set to 1/20
[*10/13/2024 23:15:06.1290] size: 17477 bytes (48059 left)
[*10/13/2024 23:15:06.3830] wl: Bad Channel
[*10/13/2024 23:15:06.3840] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:07.3970] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:08.5760] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:09.6860] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:09.9250] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:11.4970] DOT11_DRV[1]: set_channel Channel set to 149/40
[*10/13/2024 23:15:12.9640] dtls_init: Use SUDI certificate
[*10/13/2024 23:15:13.0080]
[*10/13/2024 23:15:13.0080] CAPWAP State: Init
[*10/13/2024 23:15:13.0090]
[*10/13/2024 23:15:13.0090] PNP is not required,
[*10/13/2024 23:15:13.0090] Starting CAPWAP discovery
[*10/13/2024 23:15:13.0160]
[*10/13/2024 23:15:13.0160] CAPWAP State: Discovery
[*10/13/2024 23:15:13.0170] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:15:13.0240]
[*10/13/2024 23:15:13.0240] CAPWAP State: Discovery
[*10/13/2024 23:15:22.8400]
[*10/13/2024 23:15:22.8400] CAPWAP State: Discovery
[*10/13/2024 23:15:22.8410] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:15:27.4610] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:15:32.6940] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:15:32.8430]
[*10/13/2024 23:15:32.8430] CAPWAP State: Discovery
[*10/13/2024 23:15:32.8440] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:15:42.8470]
[*10/13/2024 23:15:42.8470] CAPWAP State: Discovery
[*10/13/2024 23:15:42.8480] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:15:42.9300] ip6_port srcr2, ip6local fe80::62aa:1270:3006:b937, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[*10/13/2024 23:15:48.2670] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:15:52.8500]
[*10/13/2024 23:15:52.8500] CAPWAP State: Discovery
[*10/13/2024 23:15:52.8540] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:02.8580]
[*10/13/2024 23:16:02.8580] CAPWAP State: Discovery
[*10/13/2024 23:16:02.8580] Not sending discovery request, AP does not have an IP!!
[*10/13/2024 23:16:03.6520] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:16:08.8860] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*10/13/2024 23:16:12.8560]
[*10/13/2024 23:16:12.8560] CAPWAP State: Discovery
[*10/13/2024 23:16:12.8560] Not sending discovery request, AP does not have an IP!!
u▒▒▒▒▒ P▒m▒&▒mH▒▒HELO
CPU0
L1CD
MMUI
MMUA
CODE
ZBBS
MAIN
CFE Version: 5
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
Board: VANC-i
I2C: ready
DRAM: 2 GiB
enable MMU ... OK
1024 MiB
MMC:
In: serial
Out: serial
Err: serial
Platform: 4908
pmc_patch_4908:7 0 241044e 32f0337
BootImage: MASTER
swap_pair = 0
Detecting PHYs...
100%
bcm4908_eth-0
Hit ESC G link 1Gop autoboot: 0
Unknown command 'etenv' - try 'help'
u- 50
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
base bdinfo boardinit boot boot_image bootd bootefi bootelf booti bootm
bootp bootvx bubt chpart cisco_booti cmp coninfo cp ...
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot>
u-boot> saveenv
u-boot>
That would have much been easier to read in a text file rather than an extraordinarily long post!
But anyway ... using static IP from u-boot you can ping 172.20.154.30 suggesting that the AP LAN interface is working but doesn't tell us why AP-COS is not getting an IPv4 address from DHCP when it boots.  So back to my previous questions ...
What DHCP server are you using? From your other answer: Win2022 DHCP (IPv4) server.
Is the server on the local VLAN/subnet or are you relaying to the server? ?
What logs do you see on the server when one of these APs tries to get an IP? I think you're saying no logs at all?
Does the "ap profile <profile-name>" have "preferred-mode ipv4" configured? The fact that they're only requesting v6 suggests the preferred-mode might be configured to ipv6 which would obviously be a problem!  Suggest to check that config is set to ipv4 and do factory default reset on AP again if it was wrong.
If you do a packet capture on the AP switch port for all traffic from the AP what do you see happening - any DHCP requests at all?
How are the AP switch ports configured?  (lets see the switch port config?) This is important - incorrectly configured switch port could result in APs intermittently going into this state.
