Cisco AP 9120 not joining C9800 WLC
ANKUSH_SINGLA
Hi All,
I am C9800-L-F-K9 WLC models (17.6.4)
trying to join AP models (C9120AXE) to above models but seeing this error on both AP's console.
1st AP image AP Running Image : 8.10.130.0
2nd AP AP Running Image : 17.11.0.155
Errors logs :
Note : same error shows on just AO image version change
[*04/24/2023 15:50:51.0750] CAPWAP State: Image Data
[*04/24/2023 15:50:51.0750] AP image version 8.10.130.0 backup 0.0.0.0, Controller 8.10.183.0
[*04/24/2023 15:50:51.0750] Version does not match.
[*04/24/2023 15:50:51.1000] upgrade.sh: Script called with args:[PRECHECK]
[*04/24/2023 15:50:51.1410] do PRECHECK, part1 is active part
[*04/24/2023 15:50:51.1590] upgrade.sh: /tmp space: OK available 100716, required 40000
[*04/24/2023 15:50:51.1590] wtpImgFileReadRequest: request ap1g7, local /tmp/part.tar
[*04/24/2023 15:50:51.3380] AC accepted join request with result code: 0
Any quick help will be appreciated
7 Replies 7
1st AP image AP Running Image : 8.10.130.0:
 To join the AP on the WLC 17.6.4 you need to have at least version 8.10.181.0 on the AP.
The 2st AP should join.
i tried changing IOS for 1st AP but still not joining WLC, same goes to 2nd AP
marce1000
  - Check this thread : https://community.cisco.com/t5/wireless/c9130axi-e-stuck-downloading-image/m-p/4773527#M251543  , you may be experiencing a similar issue.
 M.
Leo Laohoo
Factory reset the offending AP with the command "capwap ap erase all".
Hi Leo,  tried that option already but both AP's are still failing.
Post the complete output to the following commands:
  1. WLC:  sh sysinfo
  2. WLC:  sh time
  3. AP:  sh version
  4. AP:  sh ip interface brief
Rich R
1. "Controller 8.10.183.0" - whatever it's trying to join, it is NOT the 9800 running 17.6.4 - make sure you don't have another AireOS WLC or Mobility Express controller running locally.
2. Attach the COMPLETE console log from the AP from power on here as a .txt file
3. Upgrade the WLC to 17.6.5 or 17.9.3.
17.9.3 is now the TAC recommended version as per the TAC recommended link below.
